linopasc
Problems with icon object
Apr 14, 2012 1:40 AM
Tags: #acrobat_professional #icons_object
Hi! I hope someone can help me with the icons object.
When I use the following code (document level) in a PDF file  I created (with Acrobat 8)
app.alert (this.icons.length)
try {
app.alert (this.icons[0].name)
catch(e)
for (var i in e)
app.alert(i +":"+e[i])
I get 8 for the length and the error message
this.icons[0] has no properties
This happens for this.icons[1].name, ..... this.icons[7].name
Although there should be eigth icons I can't get any name.
Furthermore if I use app.alert(this.icons) I get  the following string ",,,,,,,". There is a simple way to remove this corrupted (I think) object?
Sorry for my bad english
Thank you, linopasc
  • George Johnson
    Aug 11, 2002
    Apr 14, 2012 10:18 AM   in reply to linopasc
    Did you attempt to add document icons in the first place? If so, what method did you use? Can you post the file somewhere so we can take a look at the file?
  • George Johnson
    Aug 11, 2002
    Apr 16, 2012 11:32 AM   in reply to linopasc
    Acrobat has a document icon related bug where it removes all icons when a Save As operation is performed. The workaround is to place them in buttons as soon as you import them. These buttons can be hidden and thier icons can be retrieved using the buttonGetIcon method.
