When I select an image and move it to another folder, what gets moved? Is it the RAW file? What about the exported file?
For example, I go the the Library, and select a Virtual Image that has been Exported and select to move it to another folder. What gets moved?
I'd like to move the RAW image to one folder, and the processed JPG to another. They are in different folders now. Not sure how this works.
Thanks.
Thanks b_gossweiler and Cornelia-I for the answers.
Just to be sure, what is visible on the grid looks like the processed image, but it is the image I worked on to apply the settings. I am assuming that although it looks like the processed JPG it is actually the RAW file and that is what gets moved.
If I then move the exported file, which I did not specifically enter into the catalog, then I would do that manually, outside of LR as it has no implication for LR.
Is this correct?
Thanks.
1) If you want to know what the image in the Grid is, you can:
If it shows it's a raw image, then the raw image will be moved.
2) If you did not add the exported images to your catalog (neither by importing nor by having "Add to this Catalog" checked in the export dialog),
then you can (must) move them manually using Finder/Explorer from outside of LR, without implications on LR.
You can also find out whether they are part of your catalog or not by choosing "All Photographs" in Grid view and see if you have a JPEG shown next to your Raw, or if your Raw shows a stack sign (number in thumbnail).
Beat
One more question.
If I have virtual copies not entered into the catalog and want to move them (I guess I am only really moving the original RAW), does it matter if I only select the non Virtual Copy? Or, do I select all the Virtual Copies too when I want to move to a different folder? Or is it irrelevant?
Thanks.
