elimann
set spawn points for each sprite?
Apr 14, 2012 7:56 AM
heres my dilema
i currently have 5 sprites and 5 different set co ordinates for each one to spawn into with individual behaviour scripts, however i want each sprite to spawn into one of the set co ordinate without more than one of them spawning into the same point.
so eventually each sprite will spawn into a random set co ordinate
so something like
pRandomStartingLoc = (200,100) (300,100) (400,100) so each sprite spawns into only one set of cordinates without more than one spawning into the same one
    Apr 14, 2012 8:25 AM   in reply to elimann
    You want something like the following:
    --  Random Set behavior
    property  pSetNum
    property  pMySet
    On GetPropertyDescriptionList me
      Props = [:]
      Props[#pSetNum] = [#default:#1, #format:#integer, #Range:[#min:1, #max:5], #comment:"Choose a set."]
      return Props
    end GetPropertyDescriptionList
    on beginSprite me
      Case pSetNum of
        1:  pMySet = [point(200,100), point(300,100), point(400,100)]
        2:  pMySet = [point(200,100), point(300,100), point(400,100)]
        3:  pMySet = [point(200,100), point(300,100), point(400,100)]
        4:  pMySet = [point(200,100), point(300,100), point(400,100)]
        5:  pMySet = [point(200,100), point(300,100), point(400,100)]
      end case
      put pMySet
    end beginSprite
    Apr 14, 2012 9:24 AM   in reply to elimann
    Yes you would use one behavior for all five sprites.
    You need to modify the code I wrote and add it to your behavior. And, of course each "pMySet" property in the case statement would be set to a different list of points.
    The general idea is that if a set of sprites all have the same behavior but some of their properties need to be set to different values, then you use the " GetPropertyDescriptionList()" handler to set those differenct values.
    Apr 14, 2012 9:52 AM   in reply to elimann
    The code I posted is Not complete. You need to write the "spawning" code. I only show how to pick a different set of points for each sprite.
    If your spawing code continues to not work, post your code so we can see what is not working.
    Apr 14, 2012 10:11 AM   in reply to elimann
    I thought perhaps you were using some variation of the code Mister MUX wrote.
    Here's a more complete version:
    property  pSetNum
    property  pMySet
    property  pSp
    property  pStartLoc
    On GetBehaviorDescription me
      return "Sets sprite to a random location based off a predefined set."
    end GetBehaviorDescription
      Props = [:]
      return Props
    on beginSprite me
      pSp = Sprite(me.spriteNum)
      -- get my location choice set
      Case pSetNum of
          -- *** Change these value to what you want *****
        2:  pMySet = [point(100,200), point(500,105)]
        3:  pMySet = [point(50,70), point(478,387)]
        4:  pMySet = [point(400,500), point(623,245)]
        5:  pMySet = [point(600,400), point(284,470)]
      end case
      pSp.loc = pMySet[random(pMySet.count)]   -- set my location
      pStartLoc = pSp.loc  -- store current location in case you want to return to it
    end beginSprite
    on goToStartLoc me
      pSp.loc = pStartLoc
    end
    Apr 14, 2012 10:36 AM   in reply to elimann
    I'm not sure what you want. Is this closer?
    property  pPosNum
    property  pSp
    property  pStartLoc
      Props = [:]
      Props[#pPosNum] = [#default:#1, #format:#integer, #Range:[#min:1, #max:5], #comment:"Choose a set."]
      return Props
    on beginSprite me
      pSp.loc = [point(200,100), point(300,100), point(400,100), point(500,100), point(600,100)][pPosNum]   -- set my location
    end beginSprite
    on goToStartLoc me
      pSp.loc = pStartLoc
    end
    Apr 14, 2012 11:02 AM   in reply to elimann
    Okay fourth time may be the charm.
    This behavior contains a Single Locations list that is global to all sprites with this behavior attached. Each sprite picks a random loc from the list and then deletes that value from the list so that no other sprite can use it.
    Note: This uses some advanced Lingo, but you should only need to replace the point values in the list of point values.
    property  pSp   -- this sprite
    property  pStartLoc  -- this sprites location at beginsprite
    -- global/static behavior property
    property  curLocs  -- list of sprite locations used by ALL sprites with this behavior attached
    on beginSprite me
      -- define our quasi global locations list if it is not defined or is empty
      if me.script.curLocs.voidP OR me.script.curLocs = [] then
        me.script.curLocs = [point(200,100), point(300,100), point(400,100), point(500,100), point(600,100)]  -- Define Sprite Locs Here
      end if
      Locs = me.script.curLocs
      pSp.loc = Locs[random(Locs.count)]   -- set my location to random point from list
      Locs.deleteOne(pSp.loc)  -- remove this Loc from list so that no other sprite can use it.
      -- debug code. Check message window
      put "Sprite " & me.spriteNum & " is at location " & pSp.loc
    end beginSprite
    on goToStartLoc me
      pSp.loc = pStartLoc
    end
    on endSprite me
      me.script.curLocs = void
    end
    on reset me
      me.endSprite()
      me.beginSprite()
    end
    Apr 14, 2012 11:46 AM   in reply to elimann
    pStartLoc holds the starting location point and you can use that to modify the code, or you can just call the goToStartLoc() handler. As in:
    sprite(5).goToStartLoc()
    sendAllSprites(#goToStartLoc)
    Delete the "reset()" handler above. It will not work correctly. I would delete it from the forum but the forum won't let me at the moment.
    Apr 18, 2012 6:15 PM   in reply to elimann
    Apr 20, 2012 6:05 AM   in reply to elimann
    The code I posted works exactly the way you want it to work. Each sprite returns to the random location that was picked on beginSprite. If it does not do that then you perhaps changed some code or have another behavior attached to the sprites that is causing your problem.
