Hi gang,
My system:
3.06 Ghz Intel Core i3
4 GB 1333 MHz DDR3
Mac OSX 10.6.8
My Premiere files crash on startup (when it's loading everything into my sequence) about 70% of the time. I've kept notches and the record so far has been 7 crashes in a row before I was able to even get into my file.
When I am able to get in there, I am trying to render a reletively low quality H.264 Quicktime that usually crashes anywhere from 40% to 75%
If it helps to know I use mostly .swf files for the video content & my Premiere files are pretty simple, just video and audio. I sometimes use AE clips but rarely.
Also, since I found out quickly how often the program crashes, I now never open Premiere before first restarting my Mac & making sure nothing else is running.
The crashes are getting to be a nuissence, as like most people here I have deadlines & the program itself is quite pricey to be not functioning properly 70% of the time.
Hopefully anyone has any tips!
Cheers!!
CM
Hi hiof,
It might help to only edit standard DV material on such an underpowered system and see if that works at all, even if only slowly. If that works you can then try to present it with more complex material like H.264 if you are the patient type and like to work slower than a normal snail. .swf are not meant for editing, only for display.
Based on your specs, anything more difficult than standard DV material might just be too much for this system.
I managed to get the file open and this time it just seemed to crash randomly before I could try to render, here's the crash log from that:
Process: Adobe Premiere Pro CS5.5 [758]
Path: /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/MacOS/Adobe Premiere Pro CS5.5
Identifier: com.adobe.AdobePremierePro
Version: 5.5.2 (5.5.2)
Code Type: X86-64 (Native)
Parent Process: launchd [118]
Date/Time: 2012-04-13 22:31:54.071 -0700
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 304405 sec
Crashes Since Last Report: 23
Per-App Interval Since Last Report: 35180 sec
Per-App Crashes Since Last Report: 21
Anonymous UUID: C8F05825-A2DB-4966-BD8E-D31FD12F4048
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007fff5fc8f000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x00007fff882de0b6 __kill + 10
1 com.adobe.dvacore.framework 0x000000010021535e (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 638
2 libSystem.B.dylib 0x00007fff882f01ba _sigtramp + 26
3 ??? 0x00007fff5fbfbcd0 0 + 140734799789264
4 AuthPlayLib 0x00000001312cbad6 ExternalPlayer_Initialize + 2507638
5 AuthPlayLib 0x00000001312cbcd4 ExternalPlayer_Initialize + 2508148
6 AuthPlayLib 0x00000001312cc2ce ExternalPlayer_Initialize + 2509678
7 AuthPlayLib 0x0000000130f21e08 0x130c33000 + 3075592
8 AuthPlayLib 0x0000000130f5585c 0x130c33000 + 3287132
9 AuthPlayLib 0x0000000130e8a836 0x130c33000 + 2455606
10 AuthPlayLib 0x0000000130c69787 0x130c33000 + 223111
11 AuthPlayLib 0x0000000130f839fc 0x130c33000 + 3475964
12 AuthPlayLib 0x0000000130eabd2a 0x130c33000 + 2592042
13 AuthPlayLib 0x0000000130f77047 0x130c33000 + 3424327
14 AuthPlayLib 0x0000000130f76bdc 0x130c33000 + 3423196
15 AuthPlayLib 0x0000000130f76848 0x130c33000 + 3422280
16 AuthPlayLib 0x0000000130f886bf 0x130c33000 + 3495615
17 AuthPlayLib 0x0000000130f83f89 0x130c33000 + 3477385
18 AuthPlayLib 0x0000000130f860a4 0x130c33000 + 3485860
19 AuthPlayLib 0x0000000130ea3cb1 0x130c33000 + 2559153
20 AuthPlayLib 0x0000000130f96c5a 0x130c33000 + 3554394
21 AuthPlayLib 0x0000000130f9c00c 0x130c33000 + 3575820
22 AuthPlayLib 0x000000013109342f ExternalPlayer_Initialize + 179407
23 com.apple.Foundation 0x00007fff822a345f __NSThreadPerformPerform + 219
24 com.apple.CoreFoundation 0x00007fff802a43d1 __CFRunLoopDoSources0 + 1361
25 com.apple.CoreFoundation 0x00007fff802a25c9 __CFRunLoopRun + 873
26 com.apple.CoreFoundation 0x00007fff802a1d8f CFRunLoopRunSpecific + 575
27 com.apple.HIToolbox 0x00007fff83a2f7ee RunCurrentEventLoopInMode + 333
28 com.apple.HIToolbox 0x00007fff83a2f551 ReceiveNextEventCommon + 148
29 com.apple.HIToolbox 0x00007fff83a2f4ac BlockUntilNextEventMatchingListInMode + 59
30 com.apple.AppKit 0x00007fff84d82eb2 _DPSNextEvent + 708
31 com.apple.AppKit 0x00007fff84d82801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
32 com.apple.AppKit 0x00007fff84d4868f -[NSApplication run] + 395
33 com.adobe.premiere.frontend 0x000000010c7b4aa4 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 164
34 com.adobe.premiere.frontend 0x000000010c7621a7 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 2503
35 com.adobe.premiere.frontend 0x000000010c7b7c1d AppMain + 253
36 com.adobe.premiere.startup 0x000000010c9343e8 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 232
37 com.adobe.AdobePremierePro 0x0000000100003540 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 288
38 com.adobe.AdobePremierePro 0x0000000100003ac7 main + 167
39 com.adobe.AdobePremierePro 0x00000001000033a8 start + 52
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff882a8c0a kevent + 10
1 libSystem.B.dylib 0x00007fff882aaadd _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff882aa7b4 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff882aa2de _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff882a9c08 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff882a9aa5 start_wqthread + 13
Thread 2:
0 libSystem.B.dylib 0x00007fff882caa6a __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff882ce881 _pthread_cond_wait + 1286
2 com.adobe.amt.services 0x000000010f752247 C_AMTUISwitchSuppressUpdates + 16439
3 com.adobe.amt.services 0x000000010f74b39e C_EULA_SetState + 1742
4 com.adobe.amt.services 0x000000010f7522b2 C_AMTUISwitchSuppressUpdates + 16546
5 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
6 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 3:
2 ...ple.CoreServices.CarbonCore 0x00007fff83e3ed87 TSWaitOnCondition + 118
3 ...ple.CoreServices.CarbonCore 0x00007fff83dadff8 TSWaitOnConditionTimedRelative + 177
4 ...ple.CoreServices.CarbonCore 0x00007fff83da7efb MPWaitOnQueue + 215
5 ...obe.ASLFoundation.framework 0x00000001004a2470 ASL::(anonymous namespace)::TaskProc(void*) + 96
6 ...ple.CoreServices.CarbonCore 0x00007fff83d800d1 PrivateMPEntryPoint + 63
7 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
8 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 4:
5 com.adobe.dvacore.framework 0x000000010018d38f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
6 com.adobe.dvacore.framework 0x000000010011e616 boost::function0<void>::operator()() const + 38
7 com.adobe.dvacore.framework 0x0000000100185773 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
8 ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
9 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
10 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 5:
Thread 6:
1 ...dobe.dvatransport.framework 0x000000010069496e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
2 ...dobe.dvatransport.framework 0x0000000100695a25 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reac tor<false> >::run(boost::system::error_code&) + 517
3 ...dobe.dvatransport.framework 0x0000000100672abc SkyConnectionEnv::MainLoop() + 76
4 ...dobe.dvatransport.framework 0x0000000100672b29 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
5 ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
6 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 7:
2 ...dobe.dvatransport.framework 0x0000000100695b5f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reac tor<false> >::run(boost::system::error_code&) + 831
3 ...dobe.dvatransport.framework 0x0000000100696755 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver _service<boost::asio::ip::tcp>::work_io_service_runner>::run() + 53
4 ...dobe.dvatransport.framework 0x000000010067b6a9 asio_detail_posix_thread_function + 25
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
0 libSystem.B.dylib 0x00007fff8828fd7a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff882903ed mach_msg + 59
2 com.apple.CoreFoundation 0x00007fff802a2902 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff802a1d8f CFRunLoopRunSpecific + 575
4 com.apple.audio.CoreAudio 0x00007fff888ff786 HALRunLoop::OwnThread(void*) + 152
5 com.apple.audio.CoreAudio 0x00007fff888ec755 CAPThread::Entry(CAPThread*) + 125
Thread 14:
0 libSystem.B.dylib 0x00007fff8828fdda semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x00007fff882ce772 _pthread_cond_wait + 1015
2 ...ple.CoreServices.CarbonCore 0x00007fff83dae018 TSWaitOnConditionTimedRelative + 209
3 ...ple.CoreServices.CarbonCore 0x00007fff83da7efb MPWaitOnQueue + 215
4 com.adobe.dvacore.framework 0x000000010018d38f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
5 com.adobe.dvacore.framework 0x000000010011e616 boost::function0<void>::operator()() const + 38
6 com.adobe.dvacore.framework 0x0000000100185773 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
7 ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
8 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
9 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 15:
Thread 16:
4 com.apple.CoreFoundation 0x00007fff802a1b16 CFRunLoopRun + 70
5 com.adobe.dvacore.framework 0x0000000100178db9 dvacore::threads::RunPlatformEventLoop() + 89
6 com.adobe.dvacore.framework 0x000000010017d903 dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPo int&) + 179
7 com.adobe.dvacore.framework 0x000000010011e616 boost::function0<void>::operator()() const + 38
8 com.adobe.dvacore.framework 0x0000000100185773 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
9 ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
10 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
11 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 17:
1 libSystem.B.dylib 0x00007fff882ca8f9 nanosleep + 148
2 ...e.ScriptLayerPPro.framework 0x0000000106e7589b ScObjects::Thread::sleep(unsigned int) + 59
3 ...e.ScriptLayerPPro.framework 0x0000000106e603f3 ScObjects::BridgeTalkThread::run() + 163
4 ...e.ScriptLayerPPro.framework 0x0000000106e75996 ScObjects::Thread::go(void*) + 166
Thread 18:
0 libSystem.B.dylib 0x00007fff882d3956 recvfrom + 10
1 ServiceManager-Launcher.dylib 0x0000000125eb1562 Invoke + 54020
2 ServiceManager-Launcher.dylib 0x0000000125eb06bf Invoke + 50273
3 ServiceManager-Launcher.dylib 0x0000000125eaf706 Invoke + 46248
4 ServiceManager-Launcher.dylib 0x0000000125eaf761 Invoke + 46339
5 ServiceManager-Launcher.dylib 0x0000000125eaf7e2 Invoke + 46468
6 ServiceManager-Launcher.dylib 0x0000000125ea9eed Invoke + 23695
7 ServiceManager-Launcher.dylib 0x0000000125eaa086 Invoke + 24104
8 ServiceManager-Launcher.dylib 0x0000000125eaab0f Invoke + 26801
9 ServiceManager-Launcher.dylib 0x0000000125eaabfd Invoke + 27039
10 ServiceManager-Launcher.dylib 0x0000000125eadeff Invoke + 40097
11 ServiceManager-Launcher.dylib 0x0000000125eae1a5 Invoke + 40775
12 ServiceManager-Launcher.dylib 0x0000000125eae764 Invoke + 42246
13 ServiceManager-Launcher.dylib 0x0000000125eae951 Invoke + 42739
14 ServiceManager-Launcher.dylib 0x0000000125ea067f Login + 1773
15 ServiceManager-Launcher.dylib 0x0000000125ea1d01 Login + 7535
16 ServiceManager-Launcher.dylib 0x0000000125eaee88 Invoke + 44074
17 ServiceManager-Launcher.dylib 0x0000000125eb12a1 Invoke + 53315
18 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
19 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 19:
Thread 20:
2 ...ple.CoreServices.CarbonCore 0x00007fff83e3c4df TS_exception_listener_thread + 126
3 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
4 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 21:
2 com.apple.audio.CoreAudio 0x00007fff888ec68c CAGuard::WaitFor(unsigned long long) + 168
3 com.apple.audio.CoreAudio 0x00007fff888eec1b CAGuard::WaitUntil(unsigned long long) + 185
4 com.apple.audio.CoreAudio 0x00007fff888ecd85 HP_IOThread::WorkLoop() + 1369
5 com.apple.audio.CoreAudio 0x00007fff888ec827 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
6 com.apple.audio.CoreAudio 0x00007fff888ec755 CAPThread::Entry(CAPThread*) + 125
Thread 22:
2 ...obe.ImporterFlash.framework 0x000000012d0a9e15 void boost::condition_variable_any::wait<boost::unique_lock<boost::recursi ve_mutex> >(boost::unique_lock<boost::recursive_mutex>&) + 101
3 ...obe.ImporterFlash.framework 0x000000012d0a60ca ImporterFlash::SingleThreadExecutor::ThreadProcedure() + 266
4 com.adobe.dvacore.framework 0x000000010011e616 boost::function0<void>::operator()() const + 38
5 com.adobe.dvacore.framework 0x0000000100185773 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
6 ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
Thread 23:
2 AuthPlayLib 0x0000000131041dbd 0x130c33000 + 4255165
3 AuthPlayLib 0x0000000130c4aea1 0x130c33000 + 97953
4 AuthPlayLib 0x0000000131041cdc 0x130c33000 + 4254940
5 AuthPlayLib 0x000000013104218d 0x130c33000 + 4256141
Thread 24:
Thread 25:
Thread 26:
Thread 27:
4 com.apple.CoreMediaIOServices 0x00007fff87d6f5f7 MIO::DAL::RunLoop::OwnThread(void*) + 147
5 com.apple.CoreMediaIOServices 0x00007fff87d711c2 CAPThread::Entry(CAPThread*) + 140
Thread 28:
2 AuthPlayLib 0x0000000131041d80 0x130c33000 + 4255104
3 AuthPlayLib 0x0000000130f5f14f 0x130c33000 + 3326287
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33: com.apple.CFSocket.private
0 libSystem.B.dylib 0x00007fff882d3932 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x00007fff802c4468 __CFSocketManager + 824
2 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
3 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55:
Thread 56:
Thread 57:
Thread 58:
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
Thread 65:
Thread 66:
Thread 67:
Thread 68:
Thread 69:
0 libSystem.B.dylib 0x00007fff882a9a2a __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff882a9e3c _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff882a9aa5 start_wqthread + 13
Thread 70:
2 com.mainconcept.mc_bc_dec_avc 0x000000016e6be77d h264in_Video_GetAPIExt + 546717
3 com.mainconcept.mc_bc_dec_avc 0x000000016e644415 h264in_Video_GetAPIExt + 46133
4 libSystem.B.dylib 0x00007fff882c8fd6 _pthread_start + 331
5 libSystem.B.dylib 0x00007fff882c8e89 thread_start + 13
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 77:
Thread 78:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000000000000000b rcx: 0x00007fff5fbfb6b8 rdx: 0x0000000000000000
rdi: 0x00000000000002f6 rsi: 0x000000000000000b rbp: 0x00007fff5fbfb760 rsp: 0x00007fff5fbfb6b8
r8: 0x00000001002c3d98 r9: 0x0000000124414030 r10: 0x00007fff70ed3650 r11: 0x0000000000000206
r12: 0x00007fff5fbfb6e0 r13: 0x00007fff5fbfb6d0 r14: 0x00007fff5fbfb710 r15: 0x00000001002c3dd8
rip: 0x00007fff882de0b6 rfl: 0x0000000000000206 cr2: 0x00007fff5fc8f000
Binary Images:
0x100000000 - 0x100003fff +com.adobe.AdobePremierePro 5.5.2 (5.5.2) <84A17290-347B-C378-A0FD-08DA8F2C806F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/MacOS/Adobe Premiere Pro CS5.5
0x100008000 - 0x10000dffd +com.adobe.AdobeCrashReporter 3.0 (5.5.20101001) <5625AF72-323C-27C5-0094-213D09698D11> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A /AdobeCrashReporter
0x100011000 - 0x100083ff7 +com.adobe.amtlib amtlib 4.0.0.21 (4.0.0.21) <E604CBB8-A3F0-69D1-510B-3D8156D37D29> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x10009a000 - 0x1000a1fff +com.adobe.boost_date_time.framework boost_date_time version 5.5.2 (5.5.2.3) <F800B271-F74D-A6D2-AD53-0AC1E9A21D15> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/bo ost_date_time
0x1000bc000 - 0x1000c4ff7 +com.adobe.boost_threads.framework boost_threads version 5.5.2 (5.5.2.3) <AA7436D6-CF07-3808-DBD4-B47AC00A9DDE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boos t_threads
0x1000da000 - 0x100266fef +com.adobe.dvacore.framework dvacore version 5.5.2 (5.5.2.3) <FDD07401-A563-B6E3-6D03-5CC410214E97> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x100415000 - 0x100436fef +com.adobe.dvamediatypes.framework dvamediatypes version 5.5.2 (5.5.2.3) <BFA74C42-F9D5-9562-0325-0F7BBCA2F781> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvam ediatypes
0x100461000 - 0x100462fff +com.adobe.PRM.framework PRM version 5.5.2 (5.5.2.0) <486DFDE7-B583-FBC6-CA07-7611D0A01196> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x100468000 - 0x1004cfff7 +com.adobe.ASLFoundation.framework ASLFoundation version 5.5.2 (5.5.2.0) <DB1F0251-905B-5208-4B85-0179FE257858> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLF oundation
0x1005ce000 - 0x1005e4fff +com.adobe.ASLMessaging.framework ASLMessaging version 5.5.2 (5.5.2.0) <792B4D39-2C64-FFC5-53D3-0C8827E19708> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMe ssaging
0x100609000 - 0x10060afff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <F7D46AF4-5BFC-B4A3-BA7A-C1D23F0C2926> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x100611000 - 0x100623ff7 +com.adobe.ASLUnitTesting.framework ASLUnitTesting version 5.5.2 (5.5.2.0) <10EB2DFF-790D-099A-73B4-0EA724ECEC4C> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASL UnitTesting
0x100641000 - 0x100642fff +com.adobe.boost_system.framework boost_system version 5.5.2 (5.5.2.3) <89BFE4D4-9F1A-9840-B655-8A3DE98EDC85> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost _system
0x10064b000 - 0x1006c3fff +com.adobe.dvatransport.framework dvatransport version 5.5.2 (5.5.2.3) <66DCC466-6B59-0D77-EE05-D8C649FAE9B1> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatr ansport
0x10075b000 - 0x10079bfff +com.adobe.dvamarshal.framework dvamarshal version 5.5.2 (5.5.2.3) <DC321D6D-C96C-3E80-B8A9-EA49B619731B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamars hal
0x100838000 - 0x100a28fe7 +com.adobe.dynamiclink.framework dynamiclink version 5.5.2 (5.5.2.3) <4B6EFE43-DB79-4002-E245-925DBE3545BF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynami clink
0x100ba6000 - 0x100be5fe7 +com.adobe.MediaFoundation.framework MediaFoundation version 5.5.2 (5.5.2.0) <D869454D-8240-AE1D-E49F-39116436AB38> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/Me diaFoundation
0x100c44000 - 0x100cc2fe7 +com.adobe.AudioRenderer.framework AudioRenderer version 5.5.2 (5.5.2.0) <F915AE34-18F0-9A1D-F7F7-B74B3D5F4B68> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/Audi oRenderer
0x100d74000 - 0x100d9efff +com.adobe.dvacaptioning.framework dvacaptioning version 5.5.2 (5.5.2.3) <F781C7F7-A8D0-26BA-1855-DA06D48F92A5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvac aptioning
0x100dcc000 - 0x101908ff7 +com.adobe.Backend.framework Backend version 5.5.2 (5.5.2.0) <6007758B-DDAE-111C-CE12-22F96485CA29> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x102811000 - 0x1029e1fe7 +com.adobe.ImageRenderer.framework ImageRenderer version 5.5.2 (5.5.2.0) <F32B949D-5673-862B-BE41-34140991C3E9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/Imag eRenderer
0x102ae9000 - 0x102b2aff7 +com.adobe.MLFoundation.framework MLFoundation version 5.5.2 (5.5.2.0) <BD587B6E-099F-C662-5363-42B94B8769BC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFou ndation
0x102b90000 - 0x102bebff7 +com.adobe.VideoFrame.framework VideoFrame version 5.5.2 (5.5.2.0) <5A8EE666-51EC-5736-DF0F-9410D206233B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFr ame
0x102c6d000 - 0x102ca7ff7 +com.adobe.PluginSupport.framework PluginSupport version 5.5.2 (5.5.2.0) <457CE22A-C007-3DC1-C09A-AC098AE7566D> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/Plug inSupport
0x102cf7000 - 0x102d37fff +com.adobe.SweetPeaSupport.framework SweetPeaSupport version 5.5.2 (5.5.2.0) <08F8C026-EDB9-5E7B-6BBD-8EC2082654B0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/Sw eetPeaSupport
0x102d98000 - 0x102ddafe7 +com.adobe.AudioSupport.framework AudioSupport version 5.5.2 (5.5.2.0) <8A3DD752-7CC1-98B1-54B6-A907FAB11325> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/Audio Support
0x102e2e000 - 0x102e31ff7 +com.adobe.MediaUtils.framework MediaUtils version 5.5.2 (5.5.2.0) <12349A87-82E8-E060-1B5D-47B00F71C02C> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUt ils
0x102e38000 - 0x102e55ff7 +com.adobe.AudioFilterHost.framework AudioFilterHost version 5.5.2 (5.5.2.0) <972B5D48-6FFB-A4FE-B7A7-D9A1134FB6E2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/Au dioFilterHost
0x102e85000 - 0x102ee3ffd +com.adobe.AdobeXMPCore Adobe XMP Core 5.2 -c 3 (61.141987) <37A7128D-857A-F1CF-A00D-497983A42017> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x102ef3000 - 0x102f97fef +com.adobe.AdobeXMPFiles Adobe XMP Files 5.2 -f 17 (61.141987) <C504760D-5727-CC17-08BD-74688712F2C4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/Adob eXMPFiles
0x102fca000 - 0x103003fef +com.adobe.AudioFilters.framework AudioFilters version 5.5.2 (5.5.2.0) <87F318ED-E1D6-83EE-6DC0-DE24CA6BDBF9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/Audio Filters
0x10307d000 - 0x103089ff7 +com.adobe.boost_signals.framework boost_signals version 5.5.2 (5.5.2.3) <CD6CB578-3BA9-4F69-D59C-6BB1020BD6D5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boos t_signals
0x1030a2000 - 0x103407fef +com.adobe.dvaui.framework dvaui version 5.5.2 (5.5.2.3) <FB3E34E3-B6A3-4586-0C1B-7EBC06A76E78> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x103828000 - 0x103ad7fff +com.adobe.UIFramework.framework UIFramework version 5.5.2 (5.5.2.3) <2F0F77EC-3950-E93D-044B-3933A7BB2B0F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFram ework
0x103ec6000 - 0x103ff3ff7 +com.adobe.VideoRenderer.framework VideoRenderer version 5.5.2 (5.5.2.0) <7ADC87EE-191A-3DEF-F631-A9D970BB5771> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/Vide oRenderer
0x10418d000 - 0x10435efff +com.adobe.ImporterHost.framework ImporterHost version 5.5.2 (5.5.2.0) <325AB15C-2FE4-23BE-5230-B2C04B1D2C74> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/Impor terHost
0x10458c000 - 0x104659ff7 +com.adobe.ExporterHost.framework ExporterHost version 5.5.2 (5.5.2.0) <DD581D06-6D44-6346-1090-A558A54513CF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/Expor terHost
0x104798000 - 0x10481bfff +com.adobe.PlayerHost.framework PlayerHost version 5.5.2 (5.5.2.0) <2EB83E8C-3C3E-A271-BE99-807F980E6A07> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerH ost
0x1048de000 - 0x104950ff7 +com.adobe.RecorderHost.framework RecorderHost version 5.5.2 (5.5.2.0) <F6AB63F9-DACC-CD26-EC5B-743B8C4EA2BC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/RecorderHost.framework/Versions/A/Recor derHost
0x1049e8000 - 0x1049f7ff7 +com.adobe.ProjectConverterHost.framework ProjectConverterHost version 5.5.2 (5.5.2.0) <B5B2EFC6-E8A0-FE45-AF99-E0C78A1AA47B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ProjectConverterHost.framework/Versions /A/ProjectConverterHost
0x104a0f000 - 0x104ae9fff +com.adobe.VideoFilterHost.framework VideoFilterHost version 5.5.2 (5.5.2.0) <4C4F672B-B920-D2FF-CF5B-539D64C28433> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/Vi deoFilterHost
0x104bc5000 - 0x104bd4ff7 +com.adobe.ProjectSupport.framework ProjectSupport version 5.5.2 (5.5.2.0) <243A33AC-9E30-0507-8632-90B4D81CF1B7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/Pro jectSupport
0x104bed000 - 0x104c05ff7 +com.adobe.AMEAppFoundation.framework AMEAppFoundation version 5.5.2 (5.5.2.0) <40CE749E-6DEF-A80F-7918-03A139C3AA46> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/A MEAppFoundation
0x104c2f000 - 0x104c52fff +com.adobe.PostEncodeHost.framework PostEncodeHost version 5.5.2 (5.5.2.0) <B095A93A-AC29-6E6D-72E7-8DC9370993EA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/Pos tEncodeHost
0x104c87000 - 0x104cc6ff7 +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.5.2 (5.5.2.3) <B6DB811F-2501-3EE9-68BB-96D3F0752F53> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dva temporalxmp
0x104ce2000 - 0x104cfffff +com.adobe.BIB AdobeBIB 1.2.02.12659 (1.2.02.12659) <6819BA1B-DF86-5EE8-C777-4E011D616A39> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x104d0a000 - 0x104daafef +com.adobe.AdobeScCore ScCore 4.1.28 (4.1.28.13048) <83CA2291-5B56-AB69-AF81-A1FBD64AA937> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeS cCore
0x104df3000 - 0x104e97ffb +com.adobe.AdobeExtendScript ExtendScript 4.1.28 (4.1.28.13048) <3022B3E5-07EC-A68B-5E75-41996620745F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/ AdobeExtendScript
0x104efc000 - 0x104f53fff +com.adobe.BravoInitializer.framework BravoInitializer version 5.5.2 (5.5.2.0) <0B7466ED-C533-8D59-B827-4329C2A8D727> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/B ravoInitializer
0x104fd8000 - 0x105116ff7 +com.adobe.ACE AdobeACE 2.18.00.12659 (2.18.00.12659) <50F24A33-D8E9-5F39-22C8-75B097EE97B8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x105140000 - 0x10548afe7 +com.adobe.AGM AdobeAGM 4.20.70.12659 (4.20.70.12659) <085E87D9-3079-EA53-25DC-85800CCBB0DF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x105563000 - 0x105894fe7 +com.adobe.CoolType AdobeCoolType 5.07.124.12659 (5.07.124.12659) <C36D0E60-9ACD-1302-CBDC-07722DD97DE9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/Adob eCoolType
0x105936000 - 0x1059f9ff7 +com.adobe.AMEWrapper.framework AMEWrapper version 5.5.2 (5.5.2.0) <AF481A92-F577-BC35-7206-0A1F7F713AB5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrap per
0x105acf000 - 0x105be8fff +com.adobe.EncoderHost.framework EncoderHost version 5.5.2 (5.5.2.0) <9A1022EF-7475-19C8-B11C-35DF162A7537> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/Encode rHost
0x105d0a000 - 0x105da1ff7 +com.adobe.MBCProvider.framework MBCProvider version 5.5.2 (5.5.2.3) <889F0A32-7A00-639C-C3A0-834A118B6D92> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCPro vider
0x105e3b000 - 0x106534fff +com.adobe.Mezzanine.framework Mezzanine version 5.5.2 (5.5.2.3) <351D42C9-A35E-4348-472E-6F111E47EDA8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanin e
0x106b81000 - 0x106b92ff8 +com.adobe.ahclientframework 1.6.0.20 (1.6.0.20) <AD464E16-20D1-A4FC-878D-CF44322F72BC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x106b9f000 - 0x106c54ff7 +com.adobe.dvaworkspace.framework dvaworkspace version 5.5.2 (5.5.2.3) <B06027A7-F5A0-EA2A-6F67-C3C1EA08E908> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawo rkspace
0x106d51000 - 0x106ee0fff +com.adobe.ScriptLayerPPro.framework ScriptLayerPPro version 5.5.2 (5.5.2.3) <A8846352-98B5-0BAD-181D-8FA4A9D6B398> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/Sc riptLayerPPro
0x107120000 - 0x1071f7fe7 +com.adobe.dvaeve.framework dvaeve version 5.5.2 (5.5.2.3) <6F584F94-FFF4-C481-6E5A-61C941B5009A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x107355000 - 0x1073d1ff7 +com.adobe.MediaCoreUI.framework MediaCoreUI version 5.5.2 (5.5.2.0) <C258E83F-0241-2CFB-340F-B3C028B6FA22> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaC oreUI
0x107459000 - 0x107650ff7 +com.adobe.SettingsUI.framework SettingsUI version 5.5.2 (5.5.2.0) <700842D7-5708-3FB7-5BA0-64B928580510> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/Setting sUI
0x1078eb000 - 0x107a6afef +com.adobe.HSL.framework HSL version 5.5.2 (5.5.2.3) <909EFF44-0D70-AD81-ABE9-2F9C6F38A4A5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
0x107c4e000 - 0x107fd8fff +com.adobe.Dialogs.framework Dialogs version 5.5.2 (5.5.2.3) <DF43B550-6261-C063-3EBF-9269D422D09A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
0x108361000 - 0x108371fff +com.adobe.HandlerAudioMiniMixer.framework HandlerAudioMiniMixer version 5.5.2 (5.5.2.3) <D5C2541E-5FC4-8982-5407-3FF72B8C0015> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Version s/A/HandlerAudioMiniMixer
0x108396000 - 0x10842ffff +com.adobe.HandlerAudioMixer.framework HandlerAudioMixer version 5.5.2 (5.5.2.3) <919DD38C-ECF4-1840-8D9F-10D63CB17FF1> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/ HandlerAudioMixer
0x108506000 - 0x10859bfff +com.adobe.HandlerCapture.framework HandlerCapture version 5.5.2 (5.5.2.3) <E5CF228C-5794-DB1A-2A96-8F74DD464A44> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/Han dlerCapture
0x108674000 - 0x10868fff7 +com.adobe.HandlerCSXS.framework HandlerCSXS version 5.5.2 (5.5.2.3) <8C722B47-1759-387A-7B49-24F0B3F2C556> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/Handle rCSXS
0x1086cc000 - 0x108900fff +com.adobe.HandlerEffectControls.framework HandlerEffectControls version 5.5.2 (5.5.2.3) <03308BD8-C849-5BA6-ADEE-9FADA8B13D3A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEffectControls.framework/Version s/A/HandlerEffectControls
0x108b69000 - 0x108bcdfff +com.adobe.HandlerEffects.framework HandlerEffects version 5.5.2 (5.5.2.3) <ED535612-9467-079C-6118-4DCC5C03DD56> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/Han dlerEffects
0x108c48000 - 0x108c54fff +com.adobe.HandlerEvents.framework HandlerEvents version 5.5.2 (5.5.2.3) <F69BF96D-3A4C-F717-B6DC-1A4B47C55C7C> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/Hand lerEvents
0x108c7a000 - 0x108c8bfff +com.adobe.HandlerGetProperties.framework HandlerGetProperties version 5.5.2 (5.5.2.3) <2CEE872D-7B14-45DE-7724-E46384A3469A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerGetProperties.framework/Versions /A/HandlerGetProperties
0x108cad000 - 0x108cc4ff7 +com.adobe.HandlerHistory.framework HandlerHistory version 5.5.2 (5.5.2.3) <E2394525-D439-FD29-D583-A13D0DA70C00> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/Han dlerHistory
0x108cf2000 - 0x108d3cff7 +com.adobe.HandlerInfo.framework HandlerInfo version 5.5.2 (5.5.2.3) <2E84F2EC-A030-3652-3CF3-99C25DCEFC62> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/Handle rInfo
0x108da3000 - 0x108dfcff7 +com.adobe.HandlerMetadataEditor.framework HandlerMetadataEditor version 5.5.2 (5.5.2.3) <C37ADADE-B96A-CCB3-8D3C-4BD442F1E88E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMetadataEditor.framework/Version s/A/HandlerMetadataEditor
0x108e9c000 - 0x108f00ff7 +com.adobe.HandlerMediaBrowser.framework HandlerMediaBrowser version 5.5.2 (5.5.2.3) <4AE58731-71E7-F8D1-588A-3AAE285488A0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/ A/HandlerMediaBrowser
0x108f9b000 - 0x108fbfff7 +com.adobe.HandlerMulticam.framework HandlerMulticam version 5.5.2 (5.5.2.3) <4059480A-6042-84DC-540A-4C6ACC566C56> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMulticam.framework/Versions/A/Ha ndlerMulticam
0x109004000 - 0x109097fff +com.adobe.HandlerProgramMonitor.framework HandlerProgramMonitor version 5.5.2 (5.5.2.3) <96178728-3272-7534-DD89-6C62F99BB806> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerProgramMonitor.framework/Version s/A/HandlerProgramMonitor
0x109180000 - 0x109335ff7 +com.adobe.HandlerProject.framework HandlerProject version 5.5.2 (5.5.2.3) <D25C05CF-022B-CBFA-15F4-F9E2E9DA1156> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerProject.framework/Versions/A/Han dlerProject
0x109559000 - 0x10964cff7 +com.adobe.HandlerSourceMonitor.framework HandlerSourceMonitor version 5.5.2 (5.5.2.3) <78482872-C0D9-C2F9-D411-8903E1DA0245> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions /A/HandlerSourceMonitor
0x109764000 - 0x10995bff7 +com.adobe.HandlerTimeline.framework HandlerTimeline version 5.5.2 (5.5.2.3) <152F60CF-2C1E-F999-3768-F0E5C74056D9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/Ha ndlerTimeline
0x109b83000 - 0x109beaff7 +com.adobe.FontEngine.framework FontEngine version 5.5.2 (5.5.2.3) <182F4EF8-A9A0-7BD3-F1F3-4F8E2E7952F3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEng ine
0x109c89000 - 0x109cb9fff +com.adobe.TitleLayer.framework TitleLayer version 5.5.2 (5.5.2.3) <C8BACDDF-845A-F404-6484-711AA1C5D75F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLa yer
0x109e6b000 - 0x109e79fe7 +com.adobe.TitleImageManager.framework TitleImageManager version 5.5.2 (5.5.2.3) <B3517480-22BC-B731-27F0-04083E282E40> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/ TitleImageManager
0x109e95000 - 0x109f36ff7 +com.adobe.TitleCharacterFactory.framework TitleCharacterFactory version 5.5.2 (5.5.2.3) <B8A5AEBF-5CC1-A844-7592-DC70E3838406> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleCharacterFactory.framework/Version s/A/TitleCharacterFactory
0x109fa1000 - 0x10a0d1fef +com.adobe.TitleCG.framework TitleCG version 5.5.2 (5.5.2.3) <EF844075-43CB-884D-EF2D-96189AF1D590> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
0x10a1b2000 - 0x10a525ff7 +com.adobe.TitleLayout.framework TitleLayout version 5.5.2 (5.5.2.3) <3691FA12-2646-4D30-DF71-F86AE9DB0493> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleL ayout
0x10ac80000 - 0x10acfdfff +com.adobe.TitleRenderer.framework TitleRenderer version 5.5.2 (5.5.2.3) <46CB560F-2D52-B188-1FAE-0176A08F44C1> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/Titl eRenderer
0x10adc9000 - 0x10b619fff +com.adobe.premiere.HandlerTitler 1.0 (1.0) <FAA083E1-8A73-A262-BC22-3B49047F4F1E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/Hand lerTitler
0x10c128000 - 0x10c26bfef +WRServices ??? (???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServi ces
0x10c2b7000 - 0x10c2e7ff7 +com.adobe.HandlerTools.framework HandlerTools version 5.5.2 (5.5.2.3) <0C005737-D71D-8247-4E3B-D09AC9432793> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTools.framework/Versions/A/Handl erTools
0x10c387000 - 0x10c3c6fff +com.adobe.HandlerTrim.framework HandlerTrim version 5.5.2 (5.5.2.3) <0B9CFDA9-B9E6-286B-C235-9346B96E1140> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTrim.framework/Versions/A/Handle rTrim
0x10c429000 - 0x10c438ff7 +com.adobe.HandlerVSTEditor.framework HandlerVSTEditor version 5.5.2 (5.5.2.3) <44C25A93-85B6-66E3-053A-CEEA3C3921EE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerVSTEditor.framework/Versions/A/H andlerVSTEditor
0x10c45b000 - 0x10c476fff +com.adobe.CSXSManager.framework CSXSManager version 5.5.2 (5.5.2.3) <64F0C1C3-CFA3-9674-9BDA-661432402EB9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSMa nager
0x10c49e000 - 0x10c63bfff +com.adobe.PlugPlug 2.5.0.232 (2.5.0.232) <09F6FBA4-E768-BDFB-35AE-C7EB8EBA2D1A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x10c6e9000 - 0x10c70efff +com.adobe.PrRegistration.framework PrRegistration version 5.5.2 (5.5.2.3) <F419B401-633C-1979-82B5-2290A82876AA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrR egistration
0x10c72e000 - 0x10c809fff +com.adobe.premiere.frontend 1.0 (1.0) <A3BC0E00-2185-BA2D-0797-46DD35A97E71> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
0x10c92d000 - 0x10c94efff +com.adobe.premiere.startup 1.0 (1.0) <DA6A82E1-2E01-1CFB-2D76-550A459045B5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
0x10c96a000 - 0x10ca50fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
0x10caa8000 - 0x10cd80fe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libxerces-c-3.0.dylib
0x10cefa000 - 0x10cf21ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.40804) <AC47EA6A-1549-A7DA-EDF8-ABE11C38D179> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/mc_enc_dv.framework/Versions/8.5/mc_enc _dv
0x10cf35000 - 0x10cf35ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
0x10cf38000 - 0x10cf90ff7 +com.adobe.GPUFoundation.framework GPUFoundation version 5.5.2 (5.5.2.0) <DBA4D2C4-73ED-B850-6614-B652F0D3ADFD> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUF oundation
0x10d0fb000 - 0x10d1b1fff +com.adobe.exo.framework exo version 5.5.2 (5.5.2.3) <C5CBC875-0F2F-A863-1F93-D89DE1C22BDE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x10d2df000 - 0x10d32efff +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.5.2 (5.5.2.3) <AD74F190-EDDE-CAA6-7B3A-D27C7D27808E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dyna miclinkui
0x10d3a6000 - 0x10d3d2ff7 +com.adobe.amefoundation.framework amefoundation version 5.5.2 (5.5.2.0) <5ABD8D02-0C57-AFAE-60E0-E72221B871B6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amef oundation
0x10d41c000 - 0x10d446fff +com.adobe.ameproperties.framework ameproperties version 5.5.2 (5.5.2.0) <1DF09B18-73AF-EA39-F723-F5098A995F13> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ameproperties.framework/Versions/A/amep roperties
0x10d499000 - 0x10d4bafff +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <57E822F5-271D-A9EE-A92C-88C8835DCC68> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/Adob eBIBUtils
0x10d4c9000 - 0x10d4cffff +com.adobe.AppServices.framework AppServices version 5.5.2 (5.5.2.0) <D69CC275-29DD-3457-227D-4DB3C9B0A286> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppSer vices
0x10d4dd000 - 0x10d535feb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1263) <3CCEC733-BC2D-63D5-7DD6-FA2616C67B9E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSess ion
0x10d57b000 - 0x10d581ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <564457E1-7F6A-E398-8254-4B04EF0546E5> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x10d588000 - 0x10d5e3ff7 +com.adobe.dvametadata.framework dvametadata version 5.5.2 (5.5.2.3) <D4EF4E33-5E3D-DB12-98E1-01B467CF1272> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvamet adata
0x10d670000 - 0x10d778ff7 +com.adobe.dvametadataDB.framework dvametadataDB version 5.5.2 (5.5.2.3) <2BAC9C70-E483-DD79-5C82-DF0AD6E2BE7A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvam etadataDB
0x10d7c4000 - 0x10d85dff7 +com.adobe.dvametadataUI.framework dvametadataUI version 5.5.2 (5.5.2.3) <D240FB74-92EF-CA7A-44EC-CC8ADD66F062> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvam etadataUI
0x10d908000 - 0x10d927ff7 +com.adobe.dvastoryparser.framework dvastoryparser version 5.5.2 (5.5.2.3) <B23B2766-188C-BF32-4384-CC021EF9FFD2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dva storyparser
0x10d945000 - 0x10d989fff +com.adobe.DynamicLinkMedia.framework DynamicLinkMedia version 5.5.2 (5.5.2.0) <E09D3B9B-28F0-3634-8025-14BF3915E0C2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/D ynamicLinkMedia
0x10da0d000 - 0x10da71ff7 +com.adobe.QT32Client.framework QT32Client version 5.5.2 (5.5.2.0) <69EF9B5F-C29B-105E-BD7E-7FC199BD46B4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Cli ent
0x10daf8000 - 0x10dc65fe7 +com.adobe.Display.framework Display version 5.5.2 (5.5.2.0) <E1375A37-C28E-8F45-5EB5-41F8D32EDAFB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Display.framework/Versions/A/Display
0x10df81000 - 0x10dfe6fff +aif_core ??? (???) <EAA3F3F9-E79F-47E1-EF45-AD39EF3D704B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
0x10e00a000 - 0x10e23fff7 +aif_ogl ??? (???) <A6B80B6F-FE3B-964A-426D-72CCFF391A52> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
0x10e359000 - 0x10e378fff +image_runtime ??? (???) <0C53AFDB-DBA6-F60E-B26E-BE0BE7D5E6C0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/image_runtime.framework/Versions/A/imag e_runtime
0x10e39d000 - 0x10e45afef +com.diaquest.pro4.omf 1.0.0.1022 (1.0.0.1022) <C735F37D-4D03-1648-4A2E-F94E65070BD0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
0x10e482000 - 0x10e49bfeb +libtbb.dylib ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libtbb.dylib
0x10e4ac000 - 0x10e4b2feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libtbbmalloc.dylib
0x10e4b9000 - 0x10e4bdff8 +com.adobe.ape.shim adbeape version 3.1.74.12761 (3.1.74.12761) <09559AEB-61DE-8DE8-4315-BFA0A7D6394B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x10e4c2000 - 0x10e53eff7 +com.adobe.PProDynamicLinkServer.framework PProDynamicLinkServer version 5.5.2 (5.5.2.3) <AA87B909-1396-2B7A-8154-C78DE08C07C0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PProDynamicLinkServer.framework/Version s/A/PProDynamicLinkServer
0x10e61e000 - 0x10e625fff +com.adobe.dvacaptioningui.framework dvacaptioningui version 5.5.2 (5.5.2.3) <40A5D8D1-76B3-775F-8773-52979E5C7D32> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dv acaptioningui
0x10e6e3000 - 0x10e6ebfff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0x10f1af000 - 0x10f1b0ff7 +com.adobe.PProAEFilter.Bevel_Edges ??? (1.0) <2F895581-8FBC-608A-7CE2-AF722D1A7D04> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/ Bevel_Edges
0x10f1d7000 - 0x10f1dcfff +com.adobe.PProAEFilter.Twirl ??? (1.0) <73306B7F-74FF-0D87-0EFA-D70DCCFB5969> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
0x10f700000 - 0x10f726fff GLRendererFloat ??? (???) <38621D22-8F49-F937-851B-E21BD49A8A88> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
0x10f72e000 - 0x10f7a2ff3 +com.adobe.amt.services AMTServices 4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00) (4.0.0.21) <1B6C37A0-570C-14D0-52A3-87C835F530BB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtser vices
0x121000000 - 0x121193fe7 GLEngine ??? (???) <BCE83654-81EC-D231-ED6E-1DD449B891F2> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
0x1211c4000 - 0x1215e0fff com.apple.ATIRadeonX2000GLDriver 1.6.36 (6.3.6) <EBE273B9-6BF7-32B1-C5A2-2B3C85D776AA> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
0x1216af000 - 0x121727fef +com.adobe.adobe_caps adobe_caps 4.0.42.0 (4.0.42.0) <7AAC7875-787B-A4BA-F319-2B4425511ED4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_c aps
0x1225b5000 - 0x1225b7fef com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x122998000 - 0x12299cfff com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <917E3DC8-E34D-B130-F61F-50808466E674> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x1229a1000 - 0x1229a7ff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <C35BDA60-35FC-4BE7-B378-DCC73D99E2C9> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x122b9f000 - 0x122ba5fff +com.adobe.ExporterCoreAudio.framework ExporterCoreAudio version 5.5.2 (5.5.2.0) <4381B446-9F5E-7F27-6B46-08CA5BDBE3E9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterCoreAudio.bundle/Contents/ MacOS/ExporterCoreAudio
0x1251bb000 - 0x1251caff7 +com.adobe.PremiereFiltersMetaPlugin.framework PremiereFiltersMetaPlugin version 5.5.2 (5.5.2.0) <37074ADB-2622-5E09-DB95-941F9662F5C6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Con tents/MacOS/PremiereFiltersMetaPlugin
0x125406000 - 0x125422fff +com.adobe.VXMLPresetReader.framework VXMLPresetReader version 5.5.2 (5.5.2.0) <00B63A1C-A105-F360-DE9F-69522A99205B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VXMLPresetReader.framework/VXMLPresetRe ader
0x12545c000 - 0x12546efe7 +com.adobe.TransitionsMetaPlugin.framework TransitionsMetaPlugin version 5.5.2 (5.5.2.0) <BE7B587C-10BB-719A-D814-4DE6B86060AF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Content s/MacOS/TransitionsMetaPlugin
0x12548d000 - 0x125500fff +com.adobe.PlayerMediaCore.framework PlayerMediaCore version 5.5.2 (5.5.2.0) <87CE6497-C843-E9C5-411B-A85B79B3BE8D> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/Ma cOS/PlayerMediaCore
0x125579000 - 0x1255afff7 com.apple.AVCVideoServices 1.0 (42) <BB30152F-6E44-DE66-36B0-7DB69CE81C57> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/A VCVideoServices
0x1255e7000 - 0x125608fef +com.adobe.AudioVideoIO.framework AudioVideoIO version 5.5.2 (5.5.2.0) <17FEC2E8-EE8E-BAE7-4565-F332EA8D33C3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/Audio VideoIO
0x125800000 - 0x12580ffef +com.adobe.AudioConverter.framework AudioConverter version 5.5.2 (5.5.2.0) <6C82ABF3-5331-D41A-CCEE-86717FBD5913> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/Aud ioConverter
0x125824000 - 0x125a16ff7 com.apple.audio.codecs.Components 2.0.4 (2.0.4) <D674F6B1-EA1B-F541-CDA8-8AED81AB5375> /System/Library/Components/AudioCodecs.component/Contents/MacOS/Audio Codecs
0x125a87000 - 0x125aaeff7 +com.adobe.ExporterQuickTimeHost.framework ExporterQuickTimeHost version 5.5.2 (5.5.2.0) <09A9A1FE-5A4C-97F6-1E08-624681253319> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Conte nts/MacOS/ExporterQuickTimeHost
0x125ae6000 - 0x125b2bfff +com.adobe.ImporterQuickTime.framework ImporterQuickTime version 5.5.2 (5.5.2.0) <B350C4AB-912A-A2BF-FCE8-BECF0B7C68D2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/ MacOS/ImporterQuickTime
0x125b75000 - 0x125b8efff +com.adobe.QTParser.framework QTParser version 5.5.2 (5.5.2.0) <DBB825E1-4FA0-E10F-6AD7-698E62869829> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
0x125ba7000 - 0x125c88fff +com.adobe.IPPMPEGDecoder.framework IPPMPEGDecoder version 5.5.2 (5.5.2.0) <275470B9-4AF5-D8B1-A560-06DD44F16F52> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/IPPMPEGDecoder.framework/IPPMPEGD ecoder
0x125e6f000 - 0x125e8fff7 +com.adobe.ape adbeapecore version 3.1.74.12761 (3.1.74.12761) <48D74CFC-E9C7-143A-F971-2C7F0ACF7602> /Library/Application Support/Adobe/APE/3.101/adbeapecore.framework/adbeapecore
0x125e9e000 - 0x125ec6fef +ServiceManager-Launcher.dylib 236.0.0 (compatibility 2.5.0) <DBEE8529-7074-635B-2CAD-DF7BA597D909> /Library/Application Support/Adobe/CS5.5ServiceManager/lib/ServiceManager-Launcher.dylib
0x12a0a2000 - 0x12a0a8fe7 libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <87272933-FB21-81D0-00E6-92BC3D7583FB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libFontStreams.A .dylib
0x12a18a000 - 0x12a18cff7 +com.adobe.Motion.framework Motion version 5.5.2 (5.5.2.0) <A3022092-48BC-5FDA-BED4-8CA3A02B9A2D> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motio n
0x12a390000 - 0x12a392fff +com.adobe.PProAEFilter.Circle ??? (1.0) <23741D79-7F38-DC50-5B2F-7FB8C8F1310D> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Circle.bundle/Contents/MacOS/Circl e
0x12a93f000 - 0x12a941ff7 +com.adobe.Opacity.framework Opacity version 5.5.2 (5.5.2.0) <AE3BA694-AEF3-2DAF-0FD3-0F4C32664129> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opac ity
0x12b413000 - 0x12b415fff +com.adobe.ImporterColorMatte.framework ImporterColorMatte version 5.5.2 (5.5.2.0) <4CD6591C-449A-CE28-A616-636E95137045> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterColorMatte.bundle/Contents /MacOS/ImporterColorMatte
0x12b41b000 - 0x12b41cfff +com.adobe.PProAEFilter.Mosaic ??? (1.0) <BE253BF6-0FB5-CD0E-3FDB-83FBF8D533A4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosai c
0x12b429000 - 0x12b42afff +com.adobe.ImporterTransparentMatte.framework ImporterTransparentMatte version 5.5.2 (5.5.2.0) <99B7049E-302E-7842-6D62-2BF5358A953E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterTransparentMatte.bundle/Co ntents/MacOS/ImporterTransparentMatte
0x12b505000 - 0x12b508fff +com.adobe.PProAEFilter.Noise ??? (1.0) <4BE128EE-AE53-9DAD-53FE-AC26BA0A7DA4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Noise.bundle/Contents/MacOS/Noise
0x12b581000 - 0x12b583ff7 +com.adobe.AEFilterGaussianBlur.framework AEFilterGaussianBlur version 5.5.2 (5.5.2.0) <C30941A5-1BFC-1D9A-0673-7353615A5621> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/AEFilterGaussianBlur.bundle/Conten ts/MacOS/AEFilterGaussianBlur
0x12b59a000 - 0x12b5dcfef +com.adobe.pip ??? (5.5.0.1265) <D81C0CE8-05D5-6072-E1CE-0EDD333D009D> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x12b5fd000 - 0x12b600fe7 +com.adobe.AEFilterTrackMatteKey.framework AEFilterTrackMatteKey version 5.5.2 (5.5.2.0) <A630EC95-2287-7F27-5DDE-4E59CF3DED1B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/AEFilterTrackMatteKey.bundle/Conte nts/MacOS/AEFilterTrackMatteKey
0x12b63e000 - 0x12b641ff7 +com.adobe.FlashPlayerWrapper.framework FlashPlayerWrapper version 5.5.2 (5.5.2.0) <2863ED4C-BBD3-462D-FD28-A97E3BB2EF49> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/FlashPlayerWrapper.framework/Versions/A /FlashPlayerWrapper
0x12b64b000 - 0x12b650fff +com.adobe.ImporterAiff.framework ImporterAiff version 5.5.2 (5.5.2.0) <44370B2A-B77D-A7B4-A66F-77EA4683C2A0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterAiff.bundle/Contents/MacOS /ImporterAiff
0x12b657000 - 0x12b661ff7 +libMXF_SDK_GenericContainer_AES3.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_AES3.dylib.4.3.4
0x12baf4000 - 0x12bafefff +libMXF_SDK_GenericContainer_AES3_S302M.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_AES3_S302M.dylib.4.3.4
0x12bb07000 - 0x12bb0dfff +libMXF_SDK_GenericContainer_AVI.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_AVI.dylib.4.3.4
0x12bfa3000 - 0x12bfaafff +libMXF_SDK_GenericContainer_Binary.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_Binary.dylib.1.2.6
0x12c54b000 - 0x12c554fff +libMXF_SDK_GenericContainer_MPEG_MPEGPS.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_MPEG_MPEGPS.dylib.4.3.4
0x12cfc4000 - 0x12cfc9fff +libMXF_SDK_Modules_DataIO.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Modules_ DataIO.dylib.1.2.6
0x12d049000 - 0x12d061ff7 +com.adobe.ExporterMPEGPreview.framework ExporterMPEGPreview version 5.5.2 (5.5.2.0) <01C523D3-6165-2D94-9FCF-E1CDE4B7ABF0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Content s/MacOS/ExporterMPEGPreview
0x12d077000 - 0x12d086ffd +com.mainconcept.mc_enc_mpa 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_enc_mpa.framework/mc_enc_mpa
0x12d0a3000 - 0x12d0b4fff +com.adobe.ImporterFlash.framework ImporterFlash version 5.5.2 (5.5.2.0) <366DFFF7-9DA1-4894-6651-E1288D10D8E6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterFlash.bundle/Contents/MacO S/ImporterFlash
0x12d0d7000 - 0x12d0e3ff7 +libMXF_SDK_GenericContainer_D10.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_D10.dylib.4.3.4
0x12d0eb000 - 0x12d0f5fe7 +libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_MPEG_ESAudio.dylib.4.3.4
0x12d3e4000 - 0x12d3f2fff +libMXF_SDK_GenericContainer_JPEG2000.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_JPEG2000.dylib.4.3.4
0x12d6c8000 - 0x12d6f1fef com.apple.mio.DAL.VDC_4 140.0 (1496) <E22DEEC2-EE3D-03AD-9E02-BDE03CE73588> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/VDC.plugin/Contents/MacOS/VDC
0x12d900000 - 0x12da12fef +com.mainconcept.mc_enc_mp2v 8.6 (8.6.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_enc_mp2v.framework/mc_enc_mp2v
0x12da67000 - 0x12db3cff3 +com.mainconcept.mc_mux_mp2 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_mux_mp2.framework/mc_mux_mp2
0x12dc71000 - 0x12dcafff7 com.apple.DP.ScreenInputDevice 13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/AppleScreenInputDevice.plugin/Contents/MacOS/AppleScreenInputDevi ce
0x12dd20000 - 0x12dd2bfff +libMXF_SDK_GenericContainer_MPEG_MPEGTS.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_MPEG_MPEGTS.dylib.4.3.4
0x12de76000 - 0x12de91fef +libMXF_SDK_GenericContainer_DV.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_DV.dylib.4.3.4
0x12dea3000 - 0x12deacfff +libMXF_SDK_GenericContainer_SystemScheme1.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_SystemScheme1.dylib.4.3.4
0x12ed2b000 - 0x12ed4efff +com.adobe.ImporterFastMPEG.framework ImporterFastMPEG version 5.5.2 (5.5.2.0) <BFBD6471-D4E5-7217-09F5-9ADC092591F2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterFastMPEG.bundle/Contents/M acOS/ImporterFastMPEG
0x12ed75000 - 0x12ed85fff +libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_MPEG_MPEG2Video.dylib.4.3.4
0x12f561000 - 0x12f59fff7 +com.adobe.ImporterXDCAMEX.framework ImporterXDCAMEX version 5.5.2 (5.5.2.0) <33652F2E-EDDC-4C8E-4903-434855392802> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterXDCAMEX.bundle/Contents/Ma cOS/ImporterXDCAMEX
0x12f5ed000 - 0x12f635ff7 +com.adobe.ImporterMPEG.framework ImporterMPEG version 5.5.2 (5.5.2.0) <34E1B1ED-431D-C06A-E1D9-3C412D6EC327> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterMPEG.bundle/Contents/MacOS /ImporterMPEG
0x12f67a000 - 0x12f6b0ff7 +libMOG_Framework.dylib.2.1.2 ??? (???) <5A9BAF1B-8BE6-A8BD-5505-068D06FD0DE0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.dy lib.2.1.2
0x12f6cd000 - 0x12f6e0ff7 +libMXF_SDK_GenericContainer_MPEG_MPEG4.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_MPEG_MPEG4.dylib.4.3.4
0x12f6eb000 - 0x12f6fcfff +libMXF_SDK_GenericContainer_Wave.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_Wave.dylib.4.3.4
0x12f70c000 - 0x12f717fff +libMXF_SDK_Metadata_RP224.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Metadata _RP224.dylib.4.3.4
0x12f71e000 - 0x12f72fff7 +libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMeta data_BinaryLoader.dylib.4.3.4
0x12f73f000 - 0x12f757ffb +libMXF_SDK_MetaMetadata_XSDLoader.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMeta data_XSDLoader.dylib.4.3.4
0x12f768000 - 0x12f774ffa +libMXF_SDK_XMLUtils.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_XMLUtils .dylib.4.3.4
0x12f77e000 - 0x12f781fef libLatinSuppConverter.dylib 49.0.0 (compatibility 1.0.0) <227677D0-9CF3-E007-E4C0-8DCECDA1AE9B> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
0x130276000 - 0x130298ff8 +libMXF_SDK_MetaMetadata_XSDLoader2.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMeta data_XSDLoader2.dylib.4.3.4
0x1302b0000 - 0x130317fe7 +libMXF_SDK_AvidTools.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_AvidTool s.dylib.1.2.6
0x13034a000 - 0x13035aff7 +libMXF_SDK_GenericContainer_AIFF.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_AIFF.dylib.1.2.6
0x130366000 - 0x130373fff +libMXF_SDK_GenericContainer_Blind.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_Blind.dylib.1.2.6
0x13037c000 - 0x1303a9ff8 +libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_MPEG_AVC.dylib.1.2.6
0x1303c0000 - 0x1303c8fff +com.adobe.ImporterWave.framework ImporterWave version 5.5.2 (5.5.2.0) <19B6735E-3357-5DEE-6BE8-1D00975612F5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterWave.bundle/Contents/MacOS /ImporterWave
0x130c33000 - 0x1315deff7 +AuthPlayLib ??? (???) <E3BD9C67-118F-E375-B72C-F2F8736911F6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AuthPlayLib.bundle/Contents/MacOS/AuthP layLib
0x1316fa000 - 0x131762fff +com.mainconcept.mc_mfimport 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_mfimport.framework/mc_mfimport
0x131b46000 - 0x131b53fff +libMXF_SDK_GenericContainer_MPEG_MP4.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_MPEG_MP4.dylib.1.2.6
0x131b5b000 - 0x131b69fff +libMXF_SDK_GenericContainer_VC3.dylib.1.2.6 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericC ontainer_VC3.dylib.1.2.6
0x1324af000 - 0x132693fe7 +libMXF_SDK.dylib.4.3.4 ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.dylib.4. 3.4
0x132812000 - 0x132843ff3 +libMXF_SDK_XMLBuilder.dylib.1.2.6 ??? (???) <E0DC74E6-7B1E-F8CE-9F4F-F3C76707711F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_XMLBuild er.dylib.1.2.6
0x132867000 - 0x132b33ff6 +libxerces-c-3.0.dylib ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libxerces-c-3.0.dyl ib
0x132cc9000 - 0x132cf5ff7 +com.adobe.ImporterMP3.framework ImporterMP3 version 5.5.2 (5.5.2.0) <A064E118-65C8-274C-8298-7CE99ADDE07D> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterMP3.bundle/Contents/MacOS/ ImporterMP3
0x1338fb000 - 0x133cd0fef +libxqilla.5.dylib 6.0.0 (compatibility 6.0.0) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libxqilla.5.dylib
0x13b900000 - 0x13b90bff7 +com.adobe.AEFilterTimecode.framework AEFilterTimecode version 5.5.2 (5.5.2.0) <894350E5-7CEA-3918-B3F3-D654ABC0DD18> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/AEFilterTimecode.bundle/Contents/M acOS/AEFilterTimecode
0x13f736000 - 0x13f773feb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 2.0.0.15 (2.0.0.15) <188E3565-26D6-6A54-01E2-1BBBF73AE24E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions /A/UpdaterNotifications
0x15e55e000 - 0x15e62ffff +com.mainconcept.mc_demux_mp4 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_demux_mp4.framework/mc_demux_m p4
0x15e65e000 - 0x15e695fff +com.mainconcept.mc_dec_aac 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_dec_aac.framework/mc_dec_aac
0x16e632000 - 0x16e89bfef +com.mainconcept.mc_bc_dec_avc 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_bc_dec_avc.framework/mc_bc_dec _avc
0x7fff5fc00000 - 0x7fff5fc3bdef dyld 132.1 (???) <472D950D-70F8-B810-A959-9184C2AA6C74> /usr/lib/dyld
0x7fff801d7000 - 0x7fff801e2ff7 com.apple.HelpData 2.0.5 (34.1.1) <24DC6CD3-02B7-9332-FF6D-F0C545857B55> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
0x7fff80256000 - 0x7fff803cdfe7 com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x7fff80412000 - 0x7fff8041dff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <F0DDF27E-DB55-07CE-E548-C62095BE8167> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x7fff8045e000 - 0x7fff80461ff7 com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x7fff804a1000 - 0x7fff8057efff com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x7fff8058b000 - 0x7fff805d7fff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
0x7fff805dd000 - 0x7fff80645fff com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x7fff80646000 - 0x7fff806c3fef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff806c4000 - 0x7fff8070cff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8070d000 - 0x7fff80997fe7 com.apple.security 6.1.2 (55002) <FD0B5AD4-74DB-7ED8-90D3-6EC56FFA8557> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff80998000 - 0x7fff809d5fff com.apple.LDAPFramework 2.0 (120.1) <16383FF5-0537-6298-73C9-473AEC9C149C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff809e2000 - 0x7fff80ebefef com.apple.RawCamera.bundle 3.12.0 (614) <E0F08224-8A63-BBCE-BE85-8B0BAB22A7DA> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x7fff80ebf000 - 0x7fff8102ffff com.apple.QTKit 7.7 (1789) <212AE7F7-EFDB-275D-88FB-33B9CF809842> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff81030000 - 0x7fff810edfff com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x7fff8191f000 - 0x7fff81966fff com.apple.QuickLookFramework 2.3 (327.6) <11DFB135-24A6-C0BC-5B97-ECE352A4B488> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff81b09000 - 0x7fff81bbefe7 com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x7fff81bbf000 - 0x7fff81bc5fff libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <D2F8C7E3-CBA1-2E66-1376-04AA839DABBB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage. A.dylib
0x7fff81bc6000 - 0x7fff81bc6ff7 com.apple.Carbon 150 (152) <9B37A262-F678-6D59-878E-BD11A17EE402> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff81bc7000 - 0x7fff81bc7ff7 com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff81c95000 - 0x7fff81d22fff com.apple.iLifeMediaBrowser 2.5.5 (468.2.2) <0A7B422E-5D79-9980-2477-05DC2CB5CF7C> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Version s/A/iLifeMediaBrowser
0x7fff81d23000 - 0x7fff81d43ff7 com.apple.DirectoryService.Framework 3.6 (621.11) <AD76C757-6701-BDB5-631E-1CB77D669586> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x7fff81d69000 - 0x7fff81d69ff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x7fff81e43000 - 0x7fff81e49ff7 IOSurface ??? (???) <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff81ea2000 - 0x7fff81f42fff com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff81f43000 - 0x7fff81fddfff com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x7fff81fde000 - 0x7fff81ffffff libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib
0x7fff82113000 - 0x7fff821e7fe7 com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff82210000 - 0x7fff8227afe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8227b000 - 0x7fff824fdfff com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff824fe000 - 0x7fff82608ff7 com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitIO.framework/Versions/A/MeshKitIO
0x7fff82609000 - 0x7fff82e13fe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x7fff82e14000 - 0x7fff82e2fff7 com.apple.openscripting 1.3.1 (???) <FD46A0FE-AC79-3EF7-AB4F-396D376DDE71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x7fff82e30000 - 0x7fff82ea1ff7 com.apple.AppleVAFramework 4.10.27 (4.10.27) <6CDBA3F5-6C7C-A069-4716-2B6C3AD5001F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
0x7fff83178000 - 0x7fff8317cff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff8317d000 - 0x7fff8333bfff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <4274FC73-A257-3A56-4293-5968F3428854> /usr/lib/libicucore.A.dylib
0x7fff8357f000 - 0x7fff839c2fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff839c3000 - 0x7fff83a00ff7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <F743389F-F25A-A77D-4FCA-D6B01AF2EE6D> /usr/lib/libssl.0.9.8.dylib
0x7fff83a01000 - 0x7fff83cfffff com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x7fff83d50000 - 0x7fff83d78fff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff83d79000 - 0x7fff840adfef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff840c7000 - 0x7fff840ccfff libGIF.dylib ??? (???) <1888A176-22D5-C663-22D0-336D9D213BD6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff840cd000 - 0x7fff8415dfff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x7fff84265000 - 0x7fff84266ff7 com.apple.TrustEvaluationAgent 1.1 (1) <74800EE8-C14C-18C9-C208-20BBDB982D40> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x7fff84267000 - 0x7fff84317fff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff84318000 - 0x7fff8435bff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff843a6000 - 0x7fff84408fe7 com.apple.datadetectorscore 2.0 (80.7) <34592AFF-B1B8-2277-B013-70193E4E1691> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x7fff84409000 - 0x7fff84410fff com.apple.OpenDirectory 10.6 (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x7fff84446000 - 0x7fff84476fef com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
0x7fff84477000 - 0x7fff84591fff libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x7fff84592000 - 0x7fff847ccfef com.apple.imageKit 2.0.3 (1.0) <9EA216AF-82D6-201C-78E5-D027D85B51D6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
0x7fff847cd000 - 0x7fff847defff com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
0x7fff847df000 - 0x7fff847e4ff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x7fff847e5000 - 0x7fff849a3ff7 com.apple.ImageIO.framework 3.0.5 (3.0.5) <4CF96F2C-B7BB-4C57-E352-3C678CA2B2B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff849a4000 - 0x7fff84a30fef SecurityFoundation ??? (???) <D844BB57-386A-0A43-249E-9BE035C2AB53> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x7fff84a31000 - 0x7fff84a35ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x7fff84a36000 - 0x7fff84a69ff7 libTrueTypeScaler.dylib ??? (???) <B7BA8104-FA18-39A2-56E1-922EE7A660AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff84b63000 - 0x7fff84c19ff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
0x7fff84c1a000 - 0x7fff84c1cfff com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x7fff84c31000 - 0x7fff84c72fef com.apple.CoreMedia 0.484.60 (484.60) <6B73A514-C4D5-8DC7-982C-4E4F0231ED77> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/Core Media
0x7fff84c73000 - 0x7fff84d3efff ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <86982FBB-B224-CBDA-A9AD-8EE97BDB8681> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/C olorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x7fff84d3f000 - 0x7fff85739ff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8573a000 - 0x7fff85a5cfef com.apple.JavaScriptCore 6534.55 (6534.55.2) <F360FF8A-97DE-327E-A366-EDE97321E795> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
0x7fff85a5d000 - 0x7fff85a82ff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff85a83000 - 0x7fff85a97ff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff85a98000 - 0x7fff85a9afff libRadiance.dylib ??? (???) <E08CD209-E3E4-2753-AF8A-90DD12ED556F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff86230000 - 0x7fff8627fff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <01B370FB-D524-F660-3826-E85B7F0D85CD> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
0x7fff86280000 - 0x7fff863befff com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff863bf000 - 0x7fff86444ff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff86445000 - 0x7fff86507fe7 libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff86508000 - 0x7fff86519ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717> /usr/lib/libz.1.dylib
0x7fff8667b000 - 0x7fff8668dfe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff86698000 - 0x7fff866d6fe7 libFontRegistry.dylib ??? (???) <395D7C0D-36B5-B353-0DC8-51ABC0B1C030> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff866d7000 - 0x7fff866d8ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff866eb000 - 0x7fff8672cfff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x7fff8672d000 - 0x7fff86777ff7 com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x7fff86778000 - 0x7fff8679fff7 libJPEG.dylib ??? (???) <921A3A14-A69B-F393-1678-5A5D32D4BDF2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff867a0000 - 0x7fff86885fef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x7fff86886000 - 0x7fff868b5ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
0x7fff868b6000 - 0x7fff868ccfe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x7fff86983000 - 0x7fff869bffe7 libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <F2C8D087-6BAC-6EC5-B5F3-895BBC04BD2D> /usr/lib/libcurl.4.dylib
0x7fff869c0000 - 0x7fff869cffef com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff869d0000 - 0x7fff869d1fff com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
0x7fff86b2a000 - 0x7fff86b30ff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x7fff86b54000 - 0x7fff86bb4fe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff86c00000 - 0x7fff86e69fff com.apple.QuartzComposer 4.2 ({156.30}) <C05B97F7-F543-C329-873D-097177226D79> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
0x7fff86e6a000 - 0x7fff86e9bfff libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x7fff86f11000 - 0x7fff86f58ff7 com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff86f74000 - 0x7fff86f89ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff86f8a000 - 0x7fff86f8aff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x7fff86f8b000 - 0x7fff86fa1fef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
0x7fff87185000 - 0x7fff871bffff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <7982734A-B66B-44AA-DEEC-364D2C10009B> /usr/lib/libcups.2.dylib
0x7fff871fe000 - 0x7fff871fffff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff873ff000 - 0x7fff8746bfe7 com.apple.CorePDF 1.4 (1.4) <06AE6D85-64C7-F9CC-D001-BD8BAE31B6D2> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
0x7fff8746c000 - 0x7fff874adfef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x7fff874ae000 - 0x7fff87501ff7 com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x7fff8752c000 - 0x7fff87c28ff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff87c29000 - 0x7fff87c3dfff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x7fff87c68000 - 0x7fff87c93ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <8AB4CA9E-435A-33DA-7041-904BA7FA11D5> /usr/lib/libxslt.1.dylib
0x7fff87c94000 - 0x7fff87ca1fe7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff87ca2000 - 0x7fff87cbfff7 libPng.dylib ??? (???) <A6D093D2-CA9D-2035-9C11-0AE98585C6F1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff87cd1000 - 0x7fff87d60fff com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
0x7fff87d61000 - 0x7fff87da6fff com.apple.CoreMediaIOServices 140.0 (1496) <D93293EB-0B84-E97D-E78C-9FE8D48AF58E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versi ons/A/CoreMediaIOServices
0x7fff87da7000 - 0x7fff87dc0fff com.apple.CFOpenDirectory 10.6 (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff87dc1000 - 0x7fff87dc1ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x7fff87dc2000 - 0x7fff87ee1fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff87ee2000 - 0x7fff87f37ff7 com.apple.framework.familycontrols 2.0.2 (2020) <F09541B6-5E28-1C01-C1AE-F6A2508670C7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x7fff87f38000 - 0x7fff87f38ff7 com.apple.quartzframework 1.5 (1.5) <5BFE5998-26D9-0AF1-1522-55C78E41F778> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff87f39000 - 0x7fff87f88fef libTIFF.dylib ??? (???) <2DDC5A18-35EE-5B59-10D8-0F6925DB3858> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff87fea000 - 0x7fff8811ffff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x7fff88120000 - 0x7fff88120ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8817b000 - 0x7fff881c4fef libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x7fff881c5000 - 0x7fff881feff7 com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKi t
0x7fff8827f000 - 0x7fff8828efff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8828f000 - 0x7fff88450fef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
0x7fff88459000 - 0x7fff88467ff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
0x7fff8882a000 - 0x7fff88875fef com.apple.ImageCaptureCore 1.1 (1.1) <F23CA537-4F18-76FC-8D9C-ED6E645186FC> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
0x7fff88876000 - 0x7fff88899fff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff888a0000 - 0x7fff888b7fff com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x7fff888b8000 - 0x7fff888beff7 com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff888bf000 - 0x7fff888c9fff com.apple.DisplayServicesFW 2.3.3 (289) <97F62F36-964A-3E17-2A26-A0EEF63F4BDE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
0x7fff888ca000 - 0x7fff888cdfff com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x7fff888ce000 - 0x7fff8894dfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff88993000 - 0x7fff889d6fef libtidy.A.dylib ??? (???) <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
0x7fff889d7000 - 0x7fff88a55ff7 com.apple.CoreText 151.12 (???) <5BE797B7-C903-B664-ADD9-7514B1A6EF9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x7fff88a56000 - 0x7fff88a59ff7 libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x7fff89ac4000 - 0x7fff89ac4ff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff89ac5000 - 0x7fff89b7efff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff89b7f000 - 0x7fff8a085ff7 com.apple.VideoToolbox 0.484.60 (484.60) <F55EF548-56E4-A6DF-F3C9-6BA4CFF5D629> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
0x7fff8a0be000 - 0x7fff8a1d5fef libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <1B27AFDD-DF87-2009-170E-C129E1572E8B> /usr/lib/libxml2.2.dylib
0x7fff8a1d6000 - 0x7fff8a258fff com.apple.QuickLookUIFramework 2.3 (327.6) <9093682A-0E2D-7D27-5F22-C96FD00AE970> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
0x7fff8a259000 - 0x7fff8a294fff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x7fff8a295000 - 0x7fff8a632fe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8a633000 - 0x7fff8a75bff7 com.apple.MediaToolbox 0.484.60 (484.60) <F921A5E6-E260-03B4-1458-E5814FA1924D> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
0x7fff8a75c000 - 0x7fff8a81dfef com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8a844000 - 0x7fff8a849fff libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
Model: iMac11,2, BootROM IM112.0057.B00, 2 processors, Intel Core i3, 3.06 GHz, 4 GB, SMC 1.64f5
Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.14.6
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: SAMSUNG HD502HJ, 465.76 GB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: FreeAgent GoFlex, 0x0bc2 (Seagate LLC), 0x5021, 0xfa140000 / 6
USB Device: Microsoft Basic Optical Mouse v2.0, 0x045e (Microsoft Corporation), 0x00cb, 0xfa130000 / 5
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfa120000 / 4
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 3
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0xfa111000 / 7
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: DTK-2100, 0x056a (WACOM Co., Ltd.), 0x00cc, 0xfd140000 / 5
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd110000 / 4
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000 / 3
".swf are not meant for editing, only for display."
Could you elaborate on this? Premeire's ability to read swf files is the main reason I chose to purchase it, as Flash won't export to any high quality video formats that I can use. Being able to just import swfs is a life saver. Do the swf files bog down Premiere?
.swf files have already been compressed severely at creation, similar to DivX files. If you want to do more than play them, for instance edit them, you start with heavily compressed material, that must be unpacked again and after the editing be compressed again. This causes severe quality hits because of these generation losses, that for many is unacceptable.
Thanks Harm & Wil
In this particular Premeire file, there are 35 scenes (.swf files) and 2 of them have effects on them via AE. This is the most effects heavy I've ever gotten so I'm figuring that is the problem.
I'm going to run a couple of tests for the two scenes by exporting them as uncompressed quicktimes instead of swf's & see if I'm still getting the lag & crashes.
I'll report back!
So after a few crashes here & there, converting the FX scenes with uncompressed Quicktime files seems to have helped. I was able to render without crashing & the file played on the timeline wihtout stuttering like it was doing before. So in the future I can prioritize any shots that will need FX and make sure to render QT's for those.
Thanks for the help guys & if you have any more tips I'd surely appreciate it!
CM
