I have several slide shows whch use similar slides, so I wish to copy and paste to save time.
When I copy from previous slideshows they appear reduced in size in the new one. I'm using 5.5
Any ideas how to solve this?
Hi there
My guess is that if you opened each project and clicked Modify > Rescale Project you will find each project has a different resolution.
The thing is, if you are copying slides from one project to another, it behooves you to ensure that both projects are sharing the same project resolution. Otherwise, you will encounter exactly what you are seeing.
Your only options at this point are to either rescale one project so it is the same dimensions as the other, or manipulate the content after you copy and paste the slide(s).
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
