This site has a Flash Slideshow banner thingie -
- that I wouls like to replace with something jQuery or other AJAXie solution for the obvious reasons of cross-platform compatibility. I've seen a few sites, well, many many sites that do this i some fashion or another and my next step is to go digging through the code to see what's being used and how. But I thought I'd start here first to maybe get a head start if anyone can point me to any scripts or solutions.
The requirements are pretty basic, but they are requirements. From experience, I know that a lot of these scripts can maybe do 3 out of 4 things out of the box, but that 4th thing can end up being troublesome. So it needs to -
Anyone have any favorite solutions for this? Thanks!
Lon
I use this jQuery slidebox on my site (customized to my requirements).
http://manos.malihu.gr/slidebox-jquery-banner-rotator
Adobe Widget Exchange has Spry Content Slideshow
http://alt-web.com/sandbox/Spry-test.html
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
Thank you to all! I'm sure I'll be able to make at least one of those work as needed from the initial look, I'll have to dig a little deeper now.
The Project Seven is appealing because it's an extension, but it's a little pricey. And often, there are limits to customizing extension output, or at best, it involves the same amount of work as starting with an open source script. I posted a Pre sales question on their form with some specific questions about customization, so I'll see what they have to say about it.
Thanks again! All the replies are helpful, and none are incorrect. Can I mark them all as correct answers?
Getting back to this after a spell -
I've been working with the Cycle plug in but may have to move in to something else - I'm running into too many browser inconsistencies. I've found many many plugins, and would purchase but so far each one lacks something another has and so on.
The Project Seven extension looks good, but only offers two transition types. Perhaps the Spry widget will work out will it play well with a Spry accordion on the same page?
Lon, you can use multiple Dreamweaver plugins and multiple "Widgets" on the same page.
Here's a pseudo-code example:
(within the <head> section):
<script type="text/javascript" src="js/jquery-1.5.1.min.js"></script>
<script type="text/javascript" src="js/widget1.js"></script>
<script type="text/javascript" src="js/widget2.js"></script>…
Then, to the extent your widgets call styles, place the links to stylesheets below that.
</head>
<body>
place your widgets in the body as divs, either as a Class or an ID and don't forget to close the tags.
</body>
</html>
You can have multiple Spry widgets on the same page however it works best if you use the same Spry UI version for all.
This working demo shows one page with:
View the source code to see which Spry support files are common to all widgets and which are specific to each widget.
http://alt-web.com/DEMOS/Spry-test.html
Nancy O.
