JOHNCHAP2AD
CS4 32 bit will not open under Win 7 64 bit.
Apr 14, 2012 12:13 PM
Upgraded from Win 32 bit XP to Win 7 64 bit. While in the process of rebuilding my system downloaded and installed Beta versions of CS6 and Bridge for CS6, before trying to install my current CS4 version. I do not know whether this is causing any of the following problems that I am experiencing.
 A short time later I installed CS4, ending up with both the 32 and 64 bit versions of CS4. Interestingly, this install did not install a CS4 version of Bridge in either 32 bit or 64 bit, possibly because the Beta CS6 version of Bridge was installed?
However, from a previous system backup I was able to retrieve a copy of the CS4 version (presumably 32 bit version) of Bridge, which I simply copied to the new system and found that it works fine. Interestingly now the CS6 version of Bridge loads one of the two CS4 versions and not the Beta CS6, but I cannot tell which one of the CS4 versions. Question: how does one determine whether the loaded version is the 32 or 64 bit version? If I click on System Info it does say X64 which I assume means the 64 bit version is loaded. Is this the way to tell?
The CS4 version of Bridge now apparently defaults to the 64 bit version of CS4 on opens.
I have now read that most if not all my previous plugins will not run under CS4 64 bit, so I really need to be able to run CS4 32 bit. Unfortunately, when I try to open CS4-32, it fails with the following msgs: "Adobe Photoshop CS4 Has Stopped Working." Then,
"Problem signature:
Problem Event Name: APPCRASH
Application Name: Photoshop.exe
Application Version: 11.0.0.0
Application Timestamp: 48d3882e
Fault Module Name: MSVCR80.dll
Fault Module Version: 8.0.50727.6195
Fault Module Timestamp: 4dcddbf3
Exception Code: c0000005
Exception Offset: 0002880f
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt"
The CS4-64 version continues to run as it should.
Assuming that CS6 will come with a 32 bit version when it hits the market I will be upgrading, but for now I really need a working 32 bit version of CS4.
Please help.
  • Noel Carboni
    Dec 23, 2006
    Apr 14, 2012 12:23 PM   in reply to JOHNCHAP2AD
    Help - System Info will tell you whether you're running the 64 bit or 32 bit version (look at the end of the first line).  EDIT:  Note that originally said Help - About and have corrected this.
    Yes, Photoshop CS6 provides both a 32 and 64 bit version.  In fact, it should have installed both on your system.
    Normally the two versions don't get into eachothers' hair, EXCEPT for file associations, which may explain the mixup you're having where Bridge runs the last version installed.  I doubt it has to do with your crash though.
    Have you copied any plug-ins or set an Extra plug-ins folder so that there could be a mixup between the two versions?
    Have you checked to see if your display driver has been updated?  Go to the web site of the maker of your video card and download the version that matches your hardware and OS.  Display driver updates solve many problems.
    -Noel
    Apr 14, 2012 12:58 PM   in reply to JOHNCHAP2AD
    You're missing a couple of updates (11.0.2).  And do you have any third party plugins?   Did you install the TWAIN plugin (which might crash because of a bad driver)?
