Hello,
InDesign CS5 Hangs on launch at "Calling Late Initializers"
Has been fine, just started doing it.
Win7 64 generates the following error report
Problem signature:
Problem Event Name: APPCRASH
Application Name: InDesign.exe
Application Version: 7.0.4.553
Application Timestamp: 4d890440
Fault Module Name: Public.dll
Fault Module Version: 7.0.4.553
Fault Module Timestamp: 4d8903ca
Exception Code: c0000005
Exception Offset: 000deed2
Any insight is greatly appreciated. I read the threads I could find and all I could see to try was changing permissions on the appdata/local/adobe dir, but that didn't do anything. Also trashed preferences.
YOu said that it has worked before so any chages you made , like installing som enew software or updating the app.
Also check after trashing the prefs manually :
These are normally hidden files, so you will need to set your system to show them. They will be found in various places depending on the OS, and the version of InDesign.
InDesign Defaults:
Windows XP: C:\Documents and Settings\<USER>\Application Data\Adobe\InDesign\<Version #>\<language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
Windows Vista or Windows 7: C:\Users\<USER>\AppData\Roaming\Adobe\InDesign\<Version #>\<Language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
InDesign SavedData:
Windows XP: C:\Documents and Settings\<USER>\Local Settings\Application Data\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
Windows Vista or Windows 7: C:\Users\<USER>\AppData\Local\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
Well, if it doesn't work with a new user account, removing files from your first user account is unlikely to help.
Sounds like the installation is borked.
Uninstall, run the Creative Suite Cleaner Tool, http://www.adobe.com/support/contact/cscleanertool.html,
and reinstall.
