InDesign CS5 Crashing on Launch
Apr 14, 2012 2:06 PM
Hello,
InDesign CS5 Hangs on launch at "Calling Late Initializers"
Has been fine, just started doing it.
Win7 64 generates the following error report
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    InDesign.exe
  Application Version:    7.0.4.553
  Application Timestamp:    4d890440
  Fault Module Name:    Public.dll
  Fault Module Version:    7.0.4.553
  Fault Module Timestamp:    4d8903ca
  Exception Code:    c0000005
  Exception Offset:    000deed2
Any insight is greatly appreciated. I read the threads I could find and all I could see to try was changing permissions on the appdata/local/adobe dir, but that didn't do anything. Also trashed preferences.
  • John Hawkinson
    Jun 25, 2009
    Apr 14, 2012 2:07 PM   in reply to B r e t t
    Did you do so by holding down keys at startup? If not, please try that instead.
  • John Hawkinson
    Jun 25, 2009
    Apr 14, 2012 2:15 PM   in reply to B r e t t
    Try a different user account, please.
    Apr 14, 2012 2:21 PM   in reply to B r e t t
    YOu said that it has worked before so any chages you made , like installing som enew software or updating the app.
    Also check after trashing the prefs manually :
    These are normally hidden files, so you will need to set your system to show them. They will be found in various places depending on the OS, and the version of InDesign.
    InDesign Defaults:
    Windows XP: C:\Documents and Settings\<USER>\Application Data\Adobe\InDesign\<Version #>\<language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
    Windows Vista or Windows 7: C:\Users\<USER>\AppData\Roaming\Adobe\InDesign\<Version #>\<Language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
    InDesign SavedData:
    Windows XP: C:\Documents and Settings\<USER>\Local Settings\Application Data\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
    Windows Vista or Windows 7: C:\Users\<USER>\AppData\Local\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
  • John Hawkinson
    Jun 25, 2009
    Apr 14, 2012 5:33 PM   in reply to B r e t t
    Well, if it doesn't work with a new user account, removing files from your first user account is unlikely to help.
    Sounds like the installation is borked.
    Uninstall, run the Creative Suite Cleaner Tool, http://www.adobe.com/support/contact/cscleanertool.html,
    and reinstall.
  • John Hawkinson
    Jun 25, 2009
    Apr 14, 2012 5:45 PM   in reply to B r e t t
    Available granularity varies depending on your exact install mechanism.
    Run the tool and it will present you with options. It won't remove anything until you tell it to.
