dandypandy12
Adobe Flash Cs4 is missing a Panel layout
Apr 15, 2012 1:57 AM
Tags: #cs4 #missing #adobe #flash #layout #panel #essentials #essentials.xml
The error message that came up was...
XML parsing fatal error: Invalid document structure, Line:1, File: /Users/(my name)/Library/Application Support/Adobe Flash CS4/en/Configuration/Workspace/Essentials.xml
When i click OK the same message comes up again. WHen i Click OK on this box it comes up with..
The following panel layout is missing and cannot be read
The application will not have a correct layout. please load one from Windows -> Workspace
When i went to look at The essentials file It was empty and had no writing in it.
I have no Windows folder (i belive) but i do have a windowsSWF folder
What do i need to do? I have seen similar problems when ive searched the forums but none of them have helped me.
I have tried to reinstall it and the problem was still there.
  • kglad
    Jul 21, 2002
    Apr 15, 2012 7:32 AM   in reply to dandypandy12
    here are the cs4 Essentials.xml contents:
    <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
    <panelset>
      <application/>
      <document maximize="true" rect="0 0 500 500"/>
      <panelframe dock="right" iconmodewidth="118">
        <panelcontainer expanded="true" height="692" visible="true">
          <panel height="692" id="droverproperties" unconstrainedheight="114" unconstrainedwidth="260" width="260"/>
          <panel column0id="1" column0width="230.00" column1id="2" column1width="230.00" column2id="3" column2width="70.00" column3id="4" column3width="135.00" column4id="5" column4width="70.00" filename="" height="692" id="droverlibrary" previewwithgrid="0" previewwithmoviebackground="1" sortasending="1" sortcolumn="1" splitter="0.06" unconstrainedheight="114" unconstrainedwidth="260" width="260"/>
        </panelcontainer>
      </panelframe>
      <panelframe dock="right" height="724" width="34" x="2" y="25">
        <panelcontainer expanded="true" height="724" visible="true">
          <panel height="1422" id="tools" unconstrainedheight="175" unconstrainedwidth="189" width="24"/>
        </panelcontainer>
      </panelframe>
      <panelframe dock="bottom" height="204" x="1" y="1">
        <panelcontainer expanded="true" height="180" visible="true">
          <panel height="180" id="drovertimeline" isInLayerMode="false" unconstrainedheight="180" unconstrainedwidth="600"/>
          <panel height="180" id="keyframeeditor" unconstrainedheight="180" unconstrainedwidth="600" width="1100"/>
          <panel height="180" id="output" unconstrainedheight="180" unconstrainedwidth="600" visibleTab="false"/>
          <panel height="180" id="compiler errors" unconstrainedheight="180" unconstrainedwidth="600" visibleTab="false"/>
        </panelcontainer>
      </panelframe>
    </panelset>
    Aug 24, 2012 7:14 PM   in reply to kglad
    WHAT do i do with?
  • kglad
    Jul 21, 2002
    Aug 25, 2012 11:35 AM   in reply to shinysword17
    that was a response to dp12 who should have copied that code, saved it to Essentials.xml in the correct directory.
