New to Actionscript 3
Apr 14, 2012 9:14 AM
I am new to actionscript 3.  I have text appearing in a text field with the appearence of a typewriter effect. How do I write the code so that present text after a 3 second delay is replaced by new text?
  • kglad
    Jul 21, 2002
    Apr 14, 2012 9:42 AM   in reply to rleach26
    use a timer.  i assume you have a function (eg, twEffectF) or class that accepts the text you want displayed with that effect and accepts the textfield (eg, tf) where you want that displayed.  if so, use:
    var textA:Array=["first string to display","next string","last string"] ;
    var t:Timer=new Timer(3000,0);
    t.addEventListener(TimerEvent.TIMER,timerF);
    t.start();
    function timerF(e:TimerEvent):void{
    tsEffectF(tf,textA[(Timer(e.currentTarget).repeatCount-1)%textA.length ]);
  • kglad
    Jul 21, 2002
    Apr 14, 2012 3:11 PM   in reply to kglad
    use:
    t.start();
    twEffectF(textA[(Timer(e.currentTarget).repeatCount-1)%textA.length ]);
    function twEffect(s:String):void{
    textField.text="";
    this.myArray=s.split("");
    addEventListener(Event.ENTER_FRAME,frameHandler);
    function frameHandler(event:Event):void{
      if(myArray.length > 0) {
       textField.appendText(myArray.shift());
      else
       removeEventListener(Event.ENTER_FRAME, frameHandler);
      textField.text="";
  • kglad
    Jul 21, 2002
    Apr 15, 2012 7:27 AM   in reply to rleach26
    use:
    var textA:Array=["first string to display","next string","last string"];
    var myArray:Array = [];
    t.start();
    function timerF(e:TimerEvent):void {
        twEffectF(textA[(Timer(e.currentTarget).currentCount-1)%textA.length ]);
    function twEffectF(s:String):void {
        trace(1,s,2)
        textField.text="";
    function frameHandler(event:Event):void {
        if (myArray.length>0) {
        } else {
            textField.text="";
    p.s.  please mark helpful/correct responses, if there are any.
  • kglad
    Jul 21, 2002
    Apr 15, 2012 1:06 PM   in reply to rleach26
  • kglad
    Jul 21, 2002
    Apr 15, 2012 10:33 PM   in reply to rleach26
    use:
    var t:Timer=new Timer(3000,textA.length);
    t.start();
        trace(1,s,2)
        textField.text="";
        } else {
            textField.text="";
    p.s.  you should mark the actual correct and helpful answers, not just any response of mine.  other people use those as shortcuts to find answers quickly, especially the correct answer which is linked in your original post.
