theErez
LocalConnection works when it should fail
Apr 15, 2012 12:41 AM
Tags: #localconnection
in my page i have a main swf, which should check the existence of a second swf - if its missing, the main swf should display a certain message to the user, otherwise it should work as planned.
i thought to achieve this by using LocalConnection - the main swf is set as the sending swf, and it should call a certain function on the other swf.  i was thinking that if the second swf is missing, the local connection would fail - either throw an error or its STATUS event listener would receive an 'error' message.
if you think as i did - well think again.  no error was thrown and the listener got a 'status' message, although there's nobody to handle the LocalConnection 'send' method.
what did i miss?  or is there a better way to achieve my goal?
cheers,
eRez
  • kglad
    Jul 21, 2002
    Apr 15, 2012 7:19 AM   in reply to theErez
    show your localconnetion code (only) including your statusevent listener.
  • kglad
    Jul 21, 2002
    Apr 15, 2012 1:04 PM   in reply to theErez
    use:
    protected function onEnterFrame(event:Event):void
              removeEventListener(Event.ENTER_FRAME, onEnterFrame);
              var conn:LocalConnection = new LocalConnection();
              conn.addEventListener(StatusEvent.STATUS,onLCStatus);
              //conn.connect("toolbarCheck");
              conn.send("toolbarCheck","checkForToolbar");
    private function onLCStatus(event:StatusEvent):void
          if (event.level == "error")
              // display message
          else
             // keep on going...
