gradient annotator missing
Apr 15, 2012 9:02 AM
my gradient annotator is missing in cs5 though i have it set to show in view window. please help!
    Apr 15, 2012 9:18 AM   in reply to jackcomeaux1962
    Jack,
    Presuming you have Window>Gradient ticked, a document open, and a path with a gradient chosen, what is missing?
    Apr 15, 2012 9:28 AM   in reply to jackcomeaux1962
    Are you editing a live paint object? Then there will be no annotator
    Apr 15, 2012 9:47 AM   in reply to jackcomeaux1962
    You may be just fooled by an Illustrator interface weakness.
    That is, if you see the Show Gradient annotator item in the View menu, it actually means that the annotator is hidden. Click the item to turn it on.
    If you see the Hide Gradient annotator item, it means that it is turned on.
    Perhaps it would be better to rename the items to something like Annotator is on and Annotator is off. Additionaly I'd place it as an option box straight on the Gradient palette.
    Apr 15, 2012 10:09 AM   in reply to Kurt Gold
    perhaps even more clear is a "radio" button style (perhaps better with 'dot in circle'   instead of x / _ )
    x show  _ hide : Gradient Annotator
    opposite/change to/setting;
    _ show   x hide : Gradient Annotator
    Apr 15, 2012 10:10 AM   in reply to jackcomeaux1962
    That may be too simple, but just to clarify: When the Gradient annotator is turned on, is it still hidden when you select the grad object and then take the Gradient tool in the Tools palette?
    Apr 15, 2012 12:21 PM   in reply to jackcomeaux1962
    Are you going to share what exactly went wrong?
    Apr 15, 2012 1:43 PM   in reply to Kurt Gold
    LOL! I'll take a guess, the Op selected the object and filled it with a graadient and no gradient annotator! Not relizing they have to select the tool itseklf in order to see the annotator.
    This derives me crazy all the time.
    Clicking on the tool should fill the object with a gradient and bring the panel into focus and make it active. It seems silly to have to click on the panel activate the gradient fill and then select the gradient annotator to manipulate it.
    Aug 9, 2013 4:30 PM   in reply to Kurt Gold
    Just had the same problem, I was using the gradient tool in a shape that had been created by expanding a live paint group. The gradient annotator wasn't showing in some shapes, while in others, it showed just fine. In my case, somehow the problematic shapes were contained within a group (consisting of only the shape itself, go figure), that wouldn't go to isolation mode if I double-clicked it. Used "ungroup" on them and things got back to normal. If this fail, try to create a graphic style out of the shapes where the Grad Annotator is showing, then apply this style on the problematic shapes, or try to find if there's something wrong showing on the Appearance panel.
