LocalConnection works when it should fail
Participant ,
Apr 15, 2012 Apr 15, 2012
in my page i have a main swf, which should check the existence of a second swf - if its missing, the main swf should display a certain message to the user, otherwise it should work as planned.
i thought to achieve this by using LocalConnection - the main swf is set as the sending swf, and it should call a certain function on the other swf.  i was thinking that if the second swf is missing, the local connection would fail - either throw an error or its STATUS event listener would receive an 'error' message.
if you think as i did - well think again.  no error was thrown and the listener got a 'status' message, although there's nobody to handle the LocalConnection 'send' method.
what did i miss?  or is there a better way to achieve my goal?
cheers,
eRez
ActionScript
630
Community Expert , Apr 15, 2012 Apr 15, 2012
use:
protected function onEnterFrame(event:Event):void
          removeEventListener(Event.ENTER_FRAME, onEnterFrame);
          var conn:LocalConnection = new LocalConnection();
          conn.addEventListener(StatusEvent.STATUS,onLCStatus);
          //conn.connect("toolbarCheck");
          conn.send("toolbarCheck","checkForToolbar");
private function onLCStatus(event:StatusEvent):void
      if (event.level == "error")
          // display message
      else
show your localconnetion code (only) including your statusevent listener.
Participant ,
there you go:
          // display message
      else
         // keep on going...
and as i mentioned - at this point, there isn't any other swf which handles this call
use:
          // display message
      else
         // keep on going...
