milly molly muffin eater
Thin red line treatment
Apr 15, 2012 4:11 PM
Tags: #line #playback #slow #title #red #problems
Thin red line treatment when adding title.  Playback slows to a crawl and I can't sync.  No obvious incompatiblties.  Using Vista with dual core Athon - 3 GB ram. Any ideas anyone?
    Apr 15, 2012 4:39 PM   in reply to milly molly muffin eater
    When dragging Imported Clips to the Timeline, if one initially gets a red line above those Clips, it indicates a mis-match between the Clip and the Project's Preset.
    Please let us know the full specs. of the Clips, and then the Project's Preset, chosen at New Project.
    Good luck,
    Hunt
    Apr 15, 2012 5:31 PM   in reply to milly molly muffin eater
    If that is correct, when you drag the DV-AVI to the DV Timeline, there should NOT be a red line there. If is, then something is wrong.
    Now, if you add an Effect, or any sort of overlay, such as a Title, PiP or Transition, you WILL get a red line there.
    Good luck,
    Hunt
    Apr 16, 2012 1:11 AM   in reply to milly molly muffin eater
    That's fine. It is PRE's way of telling you that you have adjusted a clip. If playback is jerky you can press [Enter] and PRE will render the timeline for a smoother preview. If you have lots of red lines and only want to render a small piece then set the WorkAreaBar to cover just that piece.
    Note that none of this is necessary and it makes no difference to your final output as PRE always renders the entire timeline during the Share process.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Apr 30, 2012 1:59 AM   in reply to milly molly muffin eater
    As nealeh said, whenever you see a red line, it means for smoother playback experience, you need to render timeline. (Simply press ENTER) It takes time usually, but its better to do it sooner than later.
