Bridge freezes when applying camera raw settings to large number of files
Apr 13, 2012 1:23 PM
Tags: #crash #bridge_cs6 #cs6-beta
I have a folder with 32,000 frames from a time-lapse project that I'm doing. I'd like to apply the same camera raw adjustments to all of these files, and so follow one of the two methods below - neither of which are working with such a large set of files:
Method 1:
  1. Select all files, open in camera raw.
  2. Apply changes to the first image
  3. Select all images, then synchronize the changes to all other images.
Unfortunately selecting "Open in Camera Raw..." just leaves bridge to hang. It's using a lot of memory and processor time, so I would assume it's working, but there's no progress bar or similar to indicate that it is.
Method 2:
  1. Open first file in Camera Raw
  2. Apply all changes, and exit camera raw.
  3. Select all files in Bridge, right click on one and select "Develop Settings -> Previous Conversion"
Unfortunately the final step again leaves bridge just thinking. I waited around an hour, closed bridge, but unfortunately when I opened it again there was no sign that it had copied the camera raw settings onto any of the other files. My computer's pretty slow (see below) but it should have written one xmp file in an hour.
Question:
Does anyone have any workarounds other than repeating the process 32 times for 1000 images at a time?
System Info From Photoshop:
Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
Operating System: Windows Vista 64-bit
Version: 6.0 Service Pack 2
System architecture: AMD CPU Family:15, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3
Physical processor count: 1
Processor speed: 1808 MHz
Built-in memory: 8062 MB
Free memory: 4508 MB
Memory available to Photoshop: 7140 MB
Memory used by Photoshop: 70 %
Image tile size: 132K
Image cache levels: 4
OpenGL Drawing: Disabled.
OpenGL Drawing Mode: Basic
OpenGL Allow Normal Mode: False.
OpenGL Allow Advanced Mode: False.
OpenGL Allow Old GPUs: Not Detected.
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: GeForce 6150SE nForce 430/PCI/SSE2
Display: 1
Display Bounds:=  top: 0, left: 0, bottom: 1024, right: 1280
Video Card Number: 1
Video Card: NVIDIA GeForce 6150SE nForce 430
OpenCL Unavailable
Driver Version: 8.17.12.7533
Driver Date: 20110521050100.000000-000
Video Card Driver: nvd3dumx.dll,nvd3dum
Video Mode: 1280 x 1024 x 4294967296 colors
Video Card Caption: NVIDIA GeForce 6150SE nForce 430
Video Card Memory: 128 MB
Video Rect Texture Size: 4096
Serial number: Tryout Version
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
Temporary file path: C:\Users\MARTIN~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  H:\, 279.5G, 50.4G free
  D:\, 149.0G, 108.1G free
  E:\, 74.5G, 46.1G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
Additional Plug-ins folder: not set
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
   adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
   AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
   AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
   AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
   AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1642
   AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
   AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
   AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
   adobe_caps.dll   Adobe CAPS   5,0,10,0
   AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
   ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
   aif_core.dll   AIF   3.0   62.490293
   aif_ocl.dll   AIF   3.0   62.490293
   aif_ogl.dll   AIF   3.0   62.490293
   amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
   ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
   AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
   AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
   Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
   BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
   boost_date_time.dll   DVA Product   6.0.0
   boost_signals.dll   DVA Product   6.0.0
   boost_system.dll   DVA Product   6.0.0
   boost_threads.dll   DVA Product   6.0.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
   CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
   data_flow.dll   AIF   3.0   62.490293
   dvaaudiodevice.dll   DVA Product   6.0.0
   dvacore.dll   DVA Product   6.0.0
   dvamarshal.dll   DVA Product   6.0.0
   dvamediatypes.dll   DVA Product   6.0.0
   dvaplayer.dll   DVA Product   6.0.0
   dvatransport.dll   DVA Product   6.0.0
   dvaunittesting.dll   DVA Product   6.0.0
   dynamiclink.dll   DVA Product   6.0.0
   ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
   FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
   filter_graph.dll   AIF   3.0   62.490293
   hydra_filters.dll   AIF   3.0   62.490293
   icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   image_compiler.dll   AIF   3.0   62.490293
   image_flow.dll   AIF   3.0   62.490293
   image_runtime.dll   AIF   3.0   62.490293
   JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
   LogSession.dll   LogSession   2.1.2.1640
   mediacoreif.dll   DVA Product   6.0.0
   MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
   msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CS6   CS6
   Plugin.dll   Adobe Photoshop CS6   CS6
   PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
   PSArt.dll   Adobe Photoshop CS6   CS6
   PSViews.dll   Adobe Photoshop CS6   CS6
   SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
   ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
   tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
   WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Accented Edges 13.0
   Adaptive Wide Angle 13.0
   ADM 3.11x01
   Angled Strokes 13.0
   Average 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Bas Relief 13.0
   BMP 13.0
   Camera Raw 7.0
   Chalk & Charcoal 13.0
   Charcoal 13.0
   Chrome 13.0
   Cineon 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Collada 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Color Halftone 13.0
   Colored Pencil 13.0
   CompuServe GIF 13.0
   Conté Crayon 13.0
   Craquelure 13.0
   Crop and Straighten Photos 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Crop and Straighten Photos Filter 13.0
   Crosshatch 13.0
   Crystallize 13.0
   Cutout 13.0
   Dark Strokes 13.0
   De-Interlace 13.0
   Dicom 13.0
   Difference Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Diffuse Glow 13.0
   Displace 13.0
   Dry Brush 13.0
   Eazel Acquire 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Embed Watermark 4.0
   Entropy 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Extrude 13.0
   FastCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Fibers 13.0
   Film Grain 13.0
   Filter Gallery 13.0
   Flash 3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Fresco 13.0
   Glass 13.0
   Glowing Edges 13.0
   Google Earth 4 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Grain 13.0
   Graphic Pen 13.0
   Halftone Pattern 13.0
   HDRMergeUI 13.0
   IFF Format 13.0
   Ink Outlines 13.0
   JPEG 2000 13.0
   Kurtosis 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Lens Blur 13.0
   Lens Correction 13.0
   Lens Flare 13.0
   Liquify 13.0
   Matlab Operation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Maximum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Mean 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Measurement Core 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Median 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Mezzotint 13.0
   Minimum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   MMXCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Mosaic Tiles 13.0
   Multiprocessor Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Neon Glow 13.0
   Note Paper 13.0
   NTSC Colors 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Ocean Ripple 13.0
   Oil Paint 13.0
   OpenEXR 13.0
   Paint Daubs 13.0
   Palette Knife 13.0
   Patchwork 13.0
   Paths to Illustrator 13.0
   PCX 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Photocopy 13.0
   Photoshop 3D Engine 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Picture Package Filter 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Pinch 13.0
   Pixar 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Plaster 13.0
   Plastic Wrap 13.0
   PNG 13.0
   Pointillize 13.0
   Polar Coordinates 13.0
   Portable Bit Map 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Poster Edges 13.0
   Radial Blur 13.0
   Radiance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Range 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Read Watermark 4.0
   Reticulation 13.0
   Ripple 13.0
   Rough Pastels 13.0
   Save for Web 13.0
   ScriptingSupport 13.0
   Shear 13.0
   Skewness 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Smart Blur 13.0
   Smudge Stick 13.0
   Solarize 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Spatter 13.0
   Spherize 13.0
   Sponge 13.0
   Sprayed Strokes 13.0
   Stained Glass 13.0
   Stamp 13.0
   Standard Deviation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Sumi-e 13.0
   Summation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Targa 13.0
   Texturizer 13.0
   Tiles 13.0
   Torn Edges 13.0
   Twirl 13.0
   U3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Underpainting 13.0
   Vanishing Point 13.0
   Variance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Variations 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Water Paper 13.0
   Watercolor 13.0
   Wave 13.0
   Wavefront|OBJ 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   WIA Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Wind 13.0
   Wireless Bitmap 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   ZigZag 13.0
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
   Mini Bridge
   Kuler
Installed TWAIN devices: NONE
    Apr 13, 2012 5:36 PM   in reply to Martin Klefas
    While I have not had to use this option it appears you do not need to open images in ACR which would save a huge amount of resources.
    Will this method work for you?
    Copy and paste Camera Raw settings
    In Adobe Bridge, you can copy and paste the Camera Raw settings from one image file to another.
    1. In Adobe Bridge, select a file and choose Edit > Develop Settings > Copy Camera Raw Settings.
    2. Select one or more files and choose Edit > Develop Settings > Paste Camera Raw Settings.
      You can also right-click (Windows) or Control-click (Mac OS) image files to copy and paste using the context menu.
    3. In the Paste Camera Raw Settings dialog box, choose which settings to apply.
    Apr 15, 2012 8:21 AM   in reply to Martin Klefas
    Are you trying to do all 32,000 pictures at once?  May be just too much for resources of computer.
    If you do 100 do you still get the same error and crash?
    If so call up the Event Log in your OS.
    It is mostly gibberish, but try to find an entry for defaulting module.  This is where the error lies.
  • Omke Oudeman
    Nov 27, 2004
    Apr 15, 2012 1:28 PM   in reply to Martin Klefas
    Why on earth would the dialogue not appear with larger numbers, surely the dialogue is the same regardless of the number of images I'm altering??
    Did you try to alter one file and save as a ACR setting, then in Bridge select all files and right mouse click choose the saved setting to apply.
    However without knowing your file size (and your free space on HD) I have to say all files need to recache and this is a big task with this kind of numbers and an even bigger tasks when they are Raw files from 8 MP above. You better leave it overnight for trying
    Be sure to have bridge Cache size set to more then the default and it would not hurt either to increase the cache size for the ACR database.
    And if you use it over a network or a separate disk it is even a bigger task.
  • Omke Oudeman
    Nov 27, 2004
    Apr 16, 2012 1:36 AM   in reply to Martin Klefas
    The files are only 2MP each, and I have the same issue when I apply the changes to RAW files and JPG files. The error occurs though before any changes are applied, before the images would need to be recached, as when the error doesn't occur the dialogue box I mentioned pops up asking what to change.
    Your specs sound more then enough I would think. Do you have set the option to Write cache to folders when possible and if so could you uncheck that option?
    I don't have experience with this kind of numbers but I do dump the Bridge cache manually on a regular base (every new cycle it seems to be more stable so more interval in the periods of dumping cache) but my main folder contains usually around 6 to 7 K of DNG files from 21 MP dSLR. This starts caching without problems but takes a few hours before done.
    Can't use the option cache for folder due to a longstanding problem with error message to replace the CacheT file, hence my question about your setting.
    Also I have set the option to previews Always HQ and in the prefs have set the option to build monitor size previews.
    As said, don't know the large numbers but the 2 MP files are very small and it should be possible for Bridge I would think?
    Did you also try to create a new folder and place the files inthere. Or divide them in to three folders for testing?
    Apr 16, 2012 7:16 AM   in reply to Martin Klefas
    Would it help to use embedded thrumnails are they are the smallest and fastest to handle?
    Apr 18, 2012 7:08 AM   in reply to Martin Klefas
    What it looks like is it takes a lot longer to load the picutres than to apply the settings.  Which sounds right to me as he metadata data is a lot smaller than the image size.
