NutTriooo
Find and replace a combination of character formats
Apr 16, 2012 3:27 AM
Hello all,
Is it possible to find and replace a combination of character formats.
for example:
Search for VA. The V in Arial and the A is Helvetica.
Replace this in V Arial and A in Verdana.
Regards.
    Apr 16, 2012 3:58 AM   in reply to NutTriooo
    Ive been thinking about this, and I don't think it's possible. It certainly isn't doable in one step in Find/Change and I don't think it's doable at all because there is not, as far as I know, a way to use a lookahead or lookbehind to find formatting that is different from the formatting of the string you are trying to locate, and you can't find multiple formats in one step.
    You can certainly find a V followed by an A, and you can even find all Arial V followed by A, or Helvetica A preceded by V, but unless the formatting is restricted to JUST the VA combinations you are looking for you have a problem.  If you can fiund just those combinations, you could replace using formatted contents of the clipboard, but I don't see a way to be sure you are only finding the particular string you want.
    It might be scriptable, though...
    Apr 16, 2012 4:30 AM   in reply to Peter Spier
    Create a new swatch and call it "Red".
    Find V in Arial, replace with character color "Red".
    Find A in Helvetica, replace with character color "Red".
    Replace "VA" in character color "Red" with something else (from the clipboard is fine).
    Delete swatch "Red" and replace with Black.
    A lot of work, certainly, but then again the OP seems to be mixing Arial, Helvetica and Verdana at will, so I guess that's the price to pay.
    Apr 16, 2012 5:17 AM   in reply to [Jongware]
    See, you think more clearly than I do at 4:00 a.m.
    I was convinced I would need to apply the character style only when the two letters are in sequence together, but obviously that's not the case.
    Apr 16, 2012 8:37 AM   in reply to NutTriooo
    NutTriooo wrote:
    Hello all,
    for example:
    Regards.
    If the letter pairs are always the same, change one manually, then copy to clipboard. Find whatever; in the change to pop-up menu under the "@" symbol, Other > Clipboard Contents Formatted.
    HTH
    Peter
    _______________________
    Peter Gold
    KnowHow ProServices
