Hi there,
After I published a PPT with Presenter, I found that the presentation titile was too long to show the whole name, the last few words was lost. I tried to change font size smaller in "Theme Editor", but it can only change the font size in Notes. Is there any way we can change font/font size for outline pane (index) and presentation title (I mean the title on the top of the index, not slide title)?
Hi
You can change the font and font style the following way
1. Go to your published folder
2. Open the data folder and open the vconfig.xml
3. you can change the font here
<uifont name="FONT_PRESENTATIONNAME" value="Monotype Corsiva,60,false,false,true"/>
In the above
<!-- format for uifont value is "font,size,isbold,isitalic,isshadowed" -->
thanks
Mahesh Nayak
Hi
In the above
thanks
Mahesh Nayak
thanks, Mahesh.
I tried your method, but it still cannot work, there is no changes on the font size (see screenshot below). It's a Japanese presentation, does it matter?
Can the height of the top area be changed in order to show all title name?
Hi
I tried the above in 7.0.7 and I got the following output.
is this what you are asking?
Here are my settings
<uifont name="FONT_PRESENTATIONNAME" value="Verdana,12,false,false,true"/>
Hope this helps
Thanks, Mahesh.
I noticed that you had 4 tabs in your sidebar, but I only had 3 tabs (see screenshot below). If you change it to 3 tabs, the result will be the same?
Hi
I tried with 3 tabs and it is working for me
Can you please recheck the vconfig.xml as to whether it has taken the changes?
If you can share your email ID I can send you a blank presentation which I published which is working fine.
thanks
Mahesh Nayak
Hi Mahesh,
That's so strange! OK, please send me your presentation. My email is yxqwf123@163.com. Thx.
Hi Mahesh,
Finally, it works fine now. The reason is I only changed the font size under <language id="en">, but not <language id="cn"> (I'm on a Chinese OS PC).
Thanks for your help!!
