I am trying to import video from our camera (a Sony DV camera from 1997!)
It worked with dv-firewire before, but now it isn't working, and we think there might be a problem with the dv connection on the camera...
We have WinTV 7, which captures and records television to the TV, and is connected with a "Hauppauge! USB-Live|2 Analogivideo digitizer"
So I unplugged the TV inputs from it, & plugged the camera in w/ component cables, and Premiere is able to recognize it, but it imports it with the bottom quarter of the file as a green bar. My project settings are standard definiion (4:3), so I don't understand why the imported video is being squished and has a green bar on the bottom of it.
Any ideas? I tried using the WinTV software and changing settings in there (in case that somehow controls the device's settings to...), I made sure that too is set to 4:3...I tried right-clicking in the capture window and played with the capture settings & device control....nothing!
I've attached a picture.....where you can clearly see the green line I'm referring to.
Help would be appreciated!
We have tried 2 firewire cables, each plugging into a "Dynex FireWire 800 ExpressCard Adapter" and both do not work. They just worked for me for the same process a few weeks ago.
It could be the cable, the card adapter, or the camera's dv output...we'd like to avoid purchasing any new equipment (we will be ordering a different firewire cable, but until that comes, we can't do anything).
At first, I thought the green bar was just showing up in the capture video, so I captured it as-is anyway...but yes, the video file that Premiere creates from that capture has the green bar as part of the file. I tried to add the crop effect to the video, but the image is still distorted (squished down) with the bar.
Does that adapter also have an IEEE-1394a (FireWire400) connector on it? PrE will not be able to Captrue over IEEE-1394b.
If so, does that connector work with another IEEE-1394a device?
Can you Capture through your Hauppauge card via Windows Movie Maker, on some other such software?
Good luck,
Hunt
Also...
Legacy Driver and Capture http://forums.adobe.com/thread/869277
- And a Picture http://forums.adobe.com/thread/727755
