Dear all
I am using Win7 x64 and installed Adobe Creative Suite Standard CS 5.5. Everything works fine except the Illustrator.
When I open it and select File -> New Document a message appears: Can't locate startup profiles.
Can anyone help me with this?
TIA
Thank you for your reply! I checked that and there is no Folder "Adobe" in that location. Also re-installing does not create that folder. The only user account which has this folder is the domain administrator.
Do you have any ideas how I can resolve this? Simply copy the folder does not work
TIA
I tried the cleaner tool with the same result. The problem still persists.
I removed the whole CS with the "remove predefined settings" enabled. Afer a rebot I installed the CS with a user account which has administrative rights. I have not removed any settings folder. Where is it located?
Do you have any ideas?
TIA
The following folder needs Read & Write access:
C:\Users\<username>\AppData\Roaming\
I#f still his doesn't work then copy the Adobe Folder from the domain administrator and paste it on above path and check.
