NZKiwiBro
Can't markup some documents
Apr 11, 2012 11:02 PM
Tags: #problem #adobe #pdf_ipad #ios5
I have been trying out the new version of the Adobe ios reader on my iPad 2 (all updates applied).
Unfortunately the first document that I tested, could not be marked up with the highlighter, the strikethrough or underscore.
I managed to locate other documents that were okay.
There does appear to be a difference, in that the pdf in question was re-pdf'd from another PDF to make the size tolerable (8 MB instead of the original ~180 Mb).
As a test, I created a PDF of just one page (from the original doc), then re-PDF'd that page.  This gave the same results for the re-PDF'd one, but the initially created page was able to be marked up okay.
Now, I must concede that I use PrimoPDF, but have not found any other issue with such PDF's. Std Adobe reader on Vista, is able to select text in either PDF.
I can supply PDF samples to Adobe support - 3Mb & 150k if requested.
    Apr 11, 2012 11:05 PM   in reply to NZKiwiBro
    Hi NZKiwiBro,
    Please share both documents at adobereader-ios@adobe.com
    Gaurav
    Apr 16, 2012 8:02 AM   in reply to NZKiwiBro
    Hello,
    I think we responded to you over email, though do let us know if you need any further clarifications.
    Gaurav
    Apr 17, 2012 2:10 PM   in reply to NZKiwiBro
    We work around the clock =). That said, for most of us, working in the forums is something we do in addition to our regular roles actually building  the product. So occasionally we miss a response. My apologies that you're frustrated.
    The alias adobereader-ios@adobe.com is monitored by several people. It sounds like your last exchange was with that alias, so I'd encourage you to send your request there too.
    Apr 17, 2012 2:27 PM   in reply to NZKiwiBro
    I personally do not have them, but I am not on the adobe-reader-ios@adobe.com alias. Reading Gaurav's post above, it sounds like he got them, responded to you with an answer and was expecting a response from you there which is why I encouraged you to send the request to adobereader-ios@adobe.com. It's possible that his response was filtered by a spam filter. I'd encourage you again to respond to that alias.
    Apr 17, 2012 2:31 PM   in reply to NZKiwiBro
    No, you are posting to the forum, possibly by replying to the emails that the forum sends. You should simply send an email directly to that address.
    Apr 17, 2012 7:31 PM   in reply to NZKiwiBro
    Apologies for getting back to you so late - I thought I had responded to you over email but looks like that wasn't the case.  Yes, we had received your PDF documents and after investigation we'd like to confirm that this a genuine bug in Adobe Reader and we have logged it in our database.  We will try and fix it in a future update.
    Appreciate your time for sharing this issue with us, thanks!
    -Gaurav
