drennan_uk
Repeat Region failing in IE7
Apr 16, 2012 9:11 AM
Hi All,
I've just fnished my first database-driven website and have hit a BIG problem just before it's about to go live! I have a repeat region for each product, which contains a form. There is a 'more info' button (which is actually a submit button) and this passes the product data to a lightbox-style popup. I've been making sure this all works on Safari, firefox and IE8 but have just tested it on IE7 and only the first 'more info' button works. I don't have a clue why. I would be soooo grateful if someone could have a look at my code and tell me what's going wrong. Having a bit of a panic now!  thanks guys
Here's the page  http://goo.gl/5rlgc
    Apr 16, 2012 9:33 AM   in reply to drennan_uk
    Could it be one of the 660 errors you have on the page
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fusers.fluxcre ative.co.uk%2Flisajane%2Fpreview%2Fdresses.php
    Seriously, you need address that. Many of those will cause the problems you are seeing.
    Apr 16, 2012 9:40 AM   in reply to drennan_uk
    What might help is to create the same page but use a query that only returns one item. That will make it easier to find unbalanced tags. Also be aware that you are using the same id more than once on the page - that's no good.
    Apr 16, 2012 10:31 AM   in reply to drennan_uk
    Use a counter in the repeat region  to append to the form name and id. That way they will be unique.
