suraj_0008
Export table data into CSV
Apr 16, 2012 11:26 AM
Tags: #csv #export_to_csv
Hello All, I am new to BC, I wants to export data into CSV file. Quick response will be appreciated.
    Apr 16, 2012 11:45 AM   in reply to suraj_0008
    Hi suraj_0008!
    If needing to export data from your site please create a report (Reports -> Custom Reports) then after generating the report the system will present a series of option to export (pdf, csv, xls) file type.
    See the step by step guide below...
    - http://kb.worldsecuresystems.com/212/bc_2123.html
    Kind regards,
    -Sidney
    Apr 16, 2012 12:26 PM   in reply to suraj_0008
    Oh I see what you are fully after.
    We don't have a "front-end" feature for this as the only option would require you to upload the CSV file to the site.  Then to use the literature feature so clients can download the CSV file.
    - http://kb.worldsecuresystems.com/665/bc_665.html
    -Sidney
  • mario_gudelj
    Oct 13, 2010
    Apr 17, 2012 12:21 AM   in reply to suraj_0008
    Hi suraj_0008,
    There definitely isn't a way to do it. You can not run server side scripts on BC of any kind, and do not have a direct database access. If this your requirement you will need to use a different platform that allows for this.
    Cheers,
    Mario
  • mario_gudelj
    Oct 13, 2010
    Apr 17, 2012 6:11 PM   in reply to suraj_0008
    Hi Suraj,
    We've had this feature before in BC where you were able to create a customer report and publish it inside the secure zone for the logged in customers to download. This feature has been removed. I don't know for which reason. Most likely because it was extremelly underutilised. In any case, you will need to generat those files through reports and publish them on your site.
    Cheers,
    Mario
