I have a crossdomain file and am trying to run the example at http://ntt.cc/2009/08/23/how-to-upload-files-in-flex-ftp.html but I keep getting a sandbox error. All help is appreciated. I am simply trying to allow users to upload images to a common folder, but I don't get permission to manage the folder unless the file is sent via ftp, so I am looking for a simple upload ftp client - which the test example looks like, using the ftp library - but can't get by the security. The crossdomain file is below. The common image folder is under the app folder. Thanks.
SecurityError–>Error #2048: Security sandbox violation: http://myDomain.org/TEST/FlexFTP/FTPflex.swf cannot load data from ftp.myDomain.org:21.
The following statement is included in my Flex app.
Security.loadPolicyFile('http://www.myDomain.org/crossdomain.xml');
The crossdomain file:
<?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
<site-control permitted-cross-domain-policies="all"/>
<allow-access-from domain="*.myDomain.org" to-ports="*" />
<allow-access-from domain="ftp.myDomain.org" to-ports="*" />
<allow-http-request-headers-from domain="*" headers="*"/>
</cross-domain-policy>
The app is running at http://myDomain.org/TEST/FlexFTP/FTPflex.swf.
The image folder is http://myDomain.org/TEST/FlexFTP/uploader
The ftp path is ftp.myDomain.org (there is an ftp folder at the level above "www/ftp" versus "www/html" folder on the server - not sure on the permissions of this folder but don't think I get there before the security error)
The full code is below. The crossdomain.xml file is above.
Thanks for looking. and the help.
// http://ntt.cc/2009/08/23/how-to-upload-files-in-flex-ftp.html/
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
initialize="upLoad()" layout="vertical">
<mx:Script>
<![CDATA[
import mx.utils.*;
import mx.controls.Alert;
private var fileRef:FileReference;
private var fileSize:uint;
private var fileContents:ByteArray ;
//you need to initiate two scokets one for sending
//commands and second for sending data to FTP Server
//socket for sending commands to FTP
private var s:Socket
//responce from FTP
private var ftpResponce:String;
//socket for sending Data to FTP
private var dataChannelSocket:Socket;
//responce from FTP when sending Data to FTP
private var dataResponce:String;
//will hold the IP address of new socket created by FTP
private var dataChannelIP:String;
//will hold the Port number created by FTP
private var dataChannelPort:int;
private var user:String="userName";//FTP usernae
private var pass:String="passWord";//FTP Password
private function receiveReply(e:ProgressEvent):void{
ftpResponce = s.readUTFBytes(s.bytesAvailable)
var serverResponse:Number = Number(ftpResponce.substr(0, 3));
if(ftpResponce.indexOf('227')>-1){
//get the ip from the string response
var temp:Object = ftpResponce.substring(ftpResponce.indexOf("(")+1
,ftpResponce.indexOf(")"));
var dataChannelSocket_temp:Object = temp.split(",");
dataChannelIP = dataChannelSocket_temp.slice(0,4).join(".");
dataChannelPort = parseInt(dataChannelSocket_temp[4])*256+
int(dataChannelSocket_temp[5]);
//create new Data Socket based on dataChannelSocket and dataChannelSocket port
dataChannelSocket = new Socket(dataChannelIP,dataChannelPort);
dataChannelSocket.addEventListener(ProgressEvent.SOCKET_DATA, receiveData);
//few FTP Responce Codes
switch(String(serverResponse)){
case "220" :
//FTP Server ready responce
break;
case "331" :
//User name okay, need password
break;
case "230":
//User logged in
break;
case "250" :
//CWD command successful
break;
case "227" :
//Entering Passive Mode (h1,h2,h3,h4,p1,p2).
break;
default:
//for more please
//http://http://www.altools.com/image/support/alftp/ALFTP_35_help/
//FTP_response_codes_rfc_959_messages.htm
traceData(ftpResponce);
private function receiveData(e:ProgressEvent):void{
dataResponce = dataChannelSocket.readUTFBytes(
dataChannelSocket.bytesAvailable);
traceData("dataChannelSocket_response—>"+dataResponce);
private function showError(e:IOErrorEvent):void{
traceData("Error—>"+e.text);
private function showSecError(e:SecurityErrorEvent):void{
traceData("SecurityError–>"+e.text);
private function createRemoteFile(fileName:String):void{
if(fileName!=null && fileName !=""){
s.writeUTFBytes("STOR "+fileName+"\n");
s.flush();
private function sendData():void{
fileContents=fileRef.data as ByteArray;
fileSize=fileRef.size;
dataChannelSocket.writeBytes(fileContents,0,fileSize);
dataChannelSocket.flush();
//initialize when application load
private function upLoad():void {
fileRef = new FileReference();
//some eventlistener
fileRef.addEventListener(Event.SELECT, selectEvent);
fileRef.addEventListener(Event.OPEN, onFileOpen);
//this fucntion connect to the ftp server
connect();
//send the usernae and password
this.userName(user);
this.passWord(pass);
//if you want to change the directory for upload file
//this.changeDirectory("/public_html/"); //directory name
this.changeDirectory("/html/TEST/FlexFTP/uploader/"); //directory name sample shows /public_html/ show I am using my root path?????
//enter into PASSV Mode
s.writeUTFBytes("PASV\n");
s.flush();
private function onFileOpen(event:Event):void {
private function traceData(event:Object):void {
var tmp:String = "================================\n";
ta.text +=event.toString()+ "\n" ;
ta.verticalScrollPosition += 20;
private function ioErrorEvent(event:IOErrorEvent):void{
Alert.show("IOError:" + event.text);
private function selectEvent(event:Event):void{
btn_upload.enabled = true;
filename.text = fileRef.name;
fileRef.load();
private function uploadFile():void {
createRemoteFile(fileRef.name);
sendData();
private function connect():void{
s = new Socket("ftp.myDomain.org",21); //Socket("ftp.anydomain.com",21);
//s = new Socket("ftp.yourdomain.com",21); //Socket("ftp.anydomain.com",21);
s.addEventListener(ProgressEvent.SOCKET_DATA, receiveReply);
s.addEventListener(IOErrorEvent.IO_ERROR, showError);
s.addEventListener(SecurityErrorEvent.SECURITY_ERROR, showSecError);
s.addEventListener(Event.CONNECT,onSocketConnect);
s.addEventListener(Event.CLOSE,onSocketClose);
s.addEventListener(Event.ACTIVATE,onSocketAtivate);
private function onSocketConnect(evt:Event):void {
//traceData("OnSocketConnect–>"+evt.target.toString());
private function onSocketClose(evt:Event):void {
//traceData("onSocketClose–>"+evt.target.toString());
private function onSocketAtivate(evt:Event):void {
//traceData("onSocketAtivate–>"+evt.target.toString());
private function userName(str:String):void {
sendCommand("USER "+str);
private function passWord(str:String):void {
sendCommand("PASS "+str);
private function changeDirectory(str:String):void {
sendCommand("CWD "+str);
private function sendCommand(arg:String):void {
arg +="\n";
s.writeUTFBytes(arg);
s.flush();
</mx:Script>
<mx:Panel id="up" horizontalAlign="left" width="100%" height="100%">
<mx:Box width="100%" height="100%">
<mx:VBox >
<mx:Form width="449" height="284">
<mx:FormItem label="Selected File:">
<mx:Label id="filename"/>
</mx:FormItem>
<mx:FormItem >
<mx:Button width="80" label="Browse" click="fileRef.browse()" />
<mx:Button width="80" label="Upload" id="btn_upload" enabled="false"
click="uploadFile()" />
<mx:Button width="80" label="Cancel" id="btn_cancel" enabled="false"
click="fileRef.cancel()" />
</mx:FormItem>
<mx:HRule width="100%" tabEnabled="false"/>
<mx:FormItem label="Events:">
<mx:TextArea id="ta" width="260" height="98" />
</mx:FormItem>
</mx:Form>
</mx:VBox>
</mx:Box>
</mx:Panel>
</mx:Application>
I have the exact same problem. I try to connect to an FTP server by using sockets, everything works perfectly locally but I get the same error when I deploy and run it on the server.
SWF location is http://spiix.dommel.be/restaurant/RestaurantSite.swf
FTP location is spiix.dommel.be on port 21
crossdomain.xml location is http://spiix.dommel.be/restaurant/crossdomain.xml
I even added
| Security.allowInsecureDomain("*"); | |||
| Security.allowDomain("*"); |
to the code, to no avail.
error :
Socket security error : Error #2048: Security sandbox violation: http://spiix.dommel.be/restaurant/RestaurantSite.swf cannot load data from spiix.dommel.be:21.
Any help would be apreciated (even disabling the entire security thing completely, in my case it doesn't have to be secure AT ALL).
I got around the issue by not using Flex, but am using php to handle the file/folder functions on the server. My issue was that if I tried to create folders from Flex non-ftp that the permissions on the server were set to Apache which limited my access to manage any uploaded data. If I create the folder through an ftp session then I can upload to that folder from Flex without issue and I am still the owner, so I just check to see if a folder needs to be created and if it does I use the php-ftp functions to create the folder before I process the Flex uploaded file. Seems to be working fine. I would have liked sockets to work but for this project no time to try to figure out the Security problem, when I thought my stuff was correct to start with. Thanks to all, I would like to know what my problem was if anyone knows but now it's more for future reference.
