How do you create pdfs in CS5?
Apr 16, 2012 2:24 PM
My ad department currently uses CS4 along with QuarkXpress. I create pdfs in Quark by using Distiller, converting postscript files to pdfs. However in CS4, If you upgrade Acrobat 9 you will lose the Distiller function. Does CS5 Acrobat X Pro for mac have Distiller? I've searched around this website and it looks like it's provided for PC. Will I be able to use it for a mac? If not how do I create a pdf in CS5? Will there be an Acrobat printer driver? I liked how in Distiller you can set up different printer settings such as how good the resolution would be for a pdf. I'd like to get an answer before purchasing this product and installing it.
    Apr 16, 2012 4:22 PM   in reply to ad designer
    There are beoming more and more reasons to stop using a distilled postscript workflow and Apple inadvertantly negated the abilty with Snow Leopard. (You know that the print industry is evolving. Your clients are going to expect pdf files with live links, bookmarks, interactive elements; all features lost in distilling.)  The "we've done it this way for years" attitude needs to be rethought. If you're print vendor dictates distilling postscript files, they haven't updated either their equipment or their webpage for a decade or both!
    On a PC, you will not lose the ability to create and distill postscript files with any update, and to my knowledge, AA 9 (no  longer available) does not hinder the ability on Mac, but rather an update to OSX 10.6 does.
    Your mention of CS4; is that in reference to the Adobe Creative Suite, or a stand alone product - Acrobat, InDesign, Illustrator, Photoshop. All Adobe products create pdf native from the application. If your daily version of Quark does not offer the same ability, you need to keep current and update or stray in the past.
    Google Search - mac os 10.6 postscript files
    http://indesignsecrets.com/creating-postscript-files-in-snow-leopard-f or-older-print-workflows.php
    http://mymacfixes.blogspot.com/2010/09/how-can-i-still-create-postscri pt-files.html
    Apr 16, 2012 6:09 PM   in reply to ad designer
    Print To always invokes distiller to launch in the background, perform the task, and quit without user intervention which is fine for print ads.
    Step 3 shows the pdf options; they are stored on the computer as .joboptions files, in one or more directories/folders and are the default set which ship and install with any Acrobat installation. I expect they would be selected in the Presets shown in Step 2. I do not run OSX 10.6 so I am not 100% on this;
    .joboption files can also be created locally or imported from a vendor. (Incidentally, I once shared the default options files with a user in this forum via Acrobat.com and was informed by an Adobe employee that they are proprietary works; I would have to remove them, and not share them. The default options set.....ships with every install...go figure...)
