Text wrap
Apr 16, 2012 8:46 PM
Hope you're well.
I'm sure this is very easy but my brain is fried. How do you create some padding between the right and bottom of the picture and the text I've wrapped around it?
Thanks very much!
    Apr 16, 2012 9:56 PM   in reply to graph22
    Window > Text Wrap. It's padding in the web world, and text wrap in InDesign.
    Apr 17, 2012 12:37 AM   in reply to graph22
    In the text wrap panel, the four fields inthe top section are the offsets (the little icons next to them show which edge each field relates to. If the chainlink inthe middle is unbortken, they all change to tewither to the same value. Click on the link to break it so you can set each side independently if needed.
    Apr 17, 2012 11:01 AM   in reply to graph22
    Please post a new screen shot showing the new wrap bounds.
  • jmlevy
    Oct 30, 2004
    Apr 17, 2012 12:06 PM   in reply to graph22
    You must select the picture frame, not the text frame.
  • lilia@
    Jan 31, 2012
    Apr 17, 2012 12:29 PM   in reply to graph22
    the feint blue line you can see on the right side of your text frrame... thats the text wrap you've applied. As jmlevy has pointed out, you applied the wrap to the text frame and it should be on the graphics frame.
