Jens Eckervogt
ExternalInterface: Type? String, Object and any types?
Apr 13, 2012 2:34 PM
Tags: #flex #titanium #4.6 #javascript_bridge
Hello dear guys,
i want know about ExternalInterface - just i have same problem with String or Array - if i like this.
But i am working with AS3 with in-block Javascript like trick by Facebook Api Libraries.
I know same functions for Boolean and Object right..
Code is MyLibrary.as
package ....
          import flash.external.ExternalInterface;
          public class MyLibraray
                     *           MyLibrary Exit
                    private static var _exit:Object;
                    public static function Exit():void
                              try{
                                        if(ExternalInterface.available){
                                                  _exit = ExternalInterface.call(jsBirdge.script());
                                                  _exit = ExternalInterface.call("JSL.jsExit"); //
                              }catch( error:Error) {}
And jsBirdge.as <- It is in-block with Javascript into XML Format and Doement Format like Javascript Version into Actionscript
package ...
          public class jsBirdge
                    private static var NS:String = "JSL";
                    public static function script():String
                              try{
                                                  ExternalInterface.call(script_js);
                                                  ExternalInterface.call("JSL.setSWFObject", ExternalInterface.objectID);
                              return NS;
                    private static const script_js:XML =
                              <script>
                                        <![CDATA[
                                                  function (){
                                                            var curwin = Titanium.UI.currentWindow;
                                                            JSL= {
        setSWFObjectID: function( swfObjectID ) {
        JSL.swfObjectID = swfObjectID;
        /*          Same Functions  */
        jsExit : function(){
  Titanium.exit();
                              </script>;
How does ExternalInterace work with currect type?
If i use custom call like exit for Titanium Desktop than ExternalInterface will check currect type - like function type exit() = Titanium.exit(); as Type "String"
Or another example: File, FileSystem and FileStream are types as object, is it right?
Or Booleam Example true or false as type Booleam. ...
Is it posskible that externalInterface works fine with any types/functions?
I have been tested with ExternalInterface and In-Block Javascript = IT works fine... Look out! http://developer.appcelerator.com/question/135288/how-do-you-know-flas h-and-titanium
But i hate disturbated communication function like GWT external / fscommand...
I want use only AS3 / JS. Just i miss this nice example because i don't forget - where are nice examples? I wish because you would say me about currect result
Thanks i hope because i get nice answer / result for currect types / function for externalinterface via inblock: Javascript.
    Apr 16, 2012 5:30 AM   in reply to Jens Eckervogt
         I am not really clear with your above post. But you can communicate with javascript from flex by the below way.
    Javascript:
    function CallMe()
         alert("Call Me");
    function CallMeWithArg(value)
         alert("This is your value: " + value);
    Action Script:
    ExternaInterface.call('CallMe'); //without argument.
    ExternaInterface.call('CallMeWithArg', 'HelloWorld'); //with argument.
    Apr 22, 2012 9:51 PM   in reply to Jens Eckervogt
    as far as i know, you can only pass strings to javascript. i am not sure about complex data types.
