i have to admit i just started using bridge more often.
before i have used acdsee for viewing my images but because of some issues, that i think will never be solved, i dropped it.
my question is why has bridge no histogram (luminance and RGB)?
personally i don´t need an extra preview window, that screen space is wasted for me as the tumbnails are enough... but if i had a histogram instead of the preview panel, that would be usefull for me.
i know this: http://www.maurodalfreddo.it/software/mdbr-histogram
but really.... why no build in histogram??
Hello, check this thread from the feedback site, someone has created a panel, but it seems to be time consuming: http://feedback.photoshop.com/photoshop_family/topics/histograms_in_br idge
You should vote for that suggestion as well.
EDIT: you edited your post while I was posting my answer...
PECourtejoie wrote:
Part of the issue is that Bridge supports more than photos. Illustrator, InDesign Files, videos, etc.
i think it should not be a big problem to display a histogram or not, based on the file extension or the file header.
i mean the freeware tool xnview displays a histogram for pixel images and also shows .EPS .AI etc. previews.
I guess I miss your point here. Bridge is just an image browser, not an image editor. What good is histogram in a browser?
You can't do anything to the image in Bridge to alter the histogram, so what would you use it for?
Not trying to argue at all, I just want to understand your point. Do you decide whether to open the image in an image editor like Photoshop or ACR based on a histogram? I guess I'm just having a mental block right now.
yes sometimes an image can look fine but the histograms shows that the black and white points are not set.
sometimes it´s hard to see clipping on small thumbail views. clipping in just one channel is also hard to see without an histogram.
you can´t change f-stop or shutter speed in an image viewer yet the info is displayed by most.
for some that info means nothing for others it´s a vital image informations.
