Degree symbol conversion export inx
Dec 1, 2008 12:50 PM
A while ago I exported from Indesign cs2 file to inx. (I may have receved an inx file from a client with CS3 but can't remember exactly)
When I opened the inx file again all the degree symbols/glyphs converted to Dgr or something like that.
I can't find the file that did this but I need to find out why it happened.
Has anyone seen something simlar like this when exporting/opening inx files with glyphs in them.
Can you explain why this happens? I need to explain to people to check this hasn't happened but I need to know why it happens in the first place.
Is it an XML Issue when going from CS3 to CS2 or something?
cp
    Dec 2, 2008 2:55 AM   in reply to (CP1)
    no... <g>
    Dec 2, 2008 5:44 AM   in reply to (CP1)
    Are you fully patched? CS2 should be at 4.0.5 and CS3 at 5.0.4.
    Bob
    Dec 2, 2008 6:23 AM   in reply to (CP1)
    Can you do better than "Dgr or something like that" ?
    If it was ° that is the HTML code for a degree symbol and may well indicate that something in the process has helpfully converted ASCII characters to HTML.
    k
    Calculating status...
    Apr 17, 2012 5:55 AM   in reply to (CP1)
    Here is my work around if anyone wants it...
    What (CP1) has found (special characters enumerations) works in a .jsx file, but don't use it as a string, set your type to number .
    Use it like this in your .jsx file:
    app.findPreferences = app.changePreferences = null;
    var myFound = app.activeDocument.search( "1397909876" );  /* you can put any code in your xml as long as you reference it here */
    myFound[0].contents = 1397909876;
    Here is all the  special characters enumeration codes for CS2
    [Link removed by moderator]
    Enjoy!
    Apr 17, 2012 1:57 AM   in reply to davekinross
    [pirated site reference]
    Enjoy!
    Sorry, but I'm not enjoying that reference you gave. That site is a plain copy of my hard work, unattributed, and with advertisements sprinkled on top. It's a piece of blatant theft. (The site producer even refers to himself "an XML expert" -- ha ha. I would laugh if only it weren't so pathetic.)
    For the original, see http://www.jongware.com/idjshelp.html or its online incarnation at MIT: http://jongware.mit.edu/idcs5js/pe_SpecialCharacters.html
    Apr 17, 2012 5:56 AM   in reply to [Jongware]
    Do you have the Decimal codes on your site? That is why I pointed to [Link removed by moderator]
    Special Characters
    Decimal code
    auto Page Number
    1396797550
    next Page Number
    1397649518
    previous Page Number
    1397780590
    section Marker
    1400073805
    bullet Character
    1396862068
    copy right Symbol
    1396929140
    degree Symbol
    1396991858
    ellipsis Character
    1397518451
    forced Line Break
    1397124194
    paragraph Symbol
    1397776754
    registered Trademark
    1397904493
    section Symbol
    1400073811
    trademark Symbol
    1398041963
    right Indent Tab
    1397909876
    indent Here Tab
    1397319796
    em Dash
    1397058884
    en Dash
    1397059140
    discretionary Hyphen
    1396983920
    nonbreaking Hyphen
    1397645928
    end Nested Style
    1396855379
    double Left Quote
    1396984945
    double Right Quote
    1396986481
    single Left Quote
    1397967985
    single Right Quote
    1397969521
    em Space
    1397058899
    en Space
    1397059155
    flush Space
    1397124179
    hair Space
    1397256787
    nonbreaking Space
    1397645907
    thin Space
    1398042195
    figure Space
    1397122899
    punctuation Space
    1397780051
    column Break
    1396927554
    frame Break
    1397125698
    page Break
    1397778242
    odd Page Break
    1397715010
    even Page Break
    1397059650
    footnote Symbol
    1399221837
