Strange, add page to folio suddenly greyed out..?
Apr 14, 2012 10:25 AM
I'm logged in and can see all my folios. I wanted to add a document as article to my folio but for some reason the add button below the folio panel is greyed out. The folio is 1024 x 768 and my document (yes it is aved) as well. Even a new document doesn't work. Tried this with several folio's, doensn't matter which folio I select innthe Folio Builder panel, the add button stays greyed out..
I can use the Import option however.
    Apr 17, 2012 1:39 AM   in reply to Frans van der Geest
    Is the folio locked by any chance?
    Apr 17, 2012 7:12 AM   in reply to Frans van der Geest
    I do not have this problem.
    I am using 10.7.3 with ID CS5. From Apple menu, software update it seems to be up to date. My Java version from terminal is:
    java version "1.6.0_31"
    Java(TM) SE Runtime Environment (build 1.6.0_31-b04-415-11M3635)
    Java HotSpot(TM) 64-Bit Server VM (build 20.6-b01-415, mixed mode)
    Perhaps an InDesign problem if cannot see active document.
