I'm not sure why .. my compile time just went from approx 20-30 seconds ... to 2:41
All I've done is add some images and minimal code changes.
Any idea why this would happen ? 2:41 compile time is not going to be fun.
Well .. while I'm doing heavy coding .. I'm just compiling in the Flash IDE so I can test basic things. I only compile with ADT when I need to test it on the actual iPad.
This is happening when hitting COMMAND + ENTER in Flash CS5.5 I need to make the SWF before I can use ADT to make the IPA
Check how your 'warnings mode" is set. Turning on "warnings mode" in the actionscript settings will dramatically increase compile times. When we discovered that turning warnings mode off decreased our compiles from 3 minutes down to 15 seconds, we just left it off, and used FB to check for code style issues.
Hi Applauz, trust me, trash the Flash IDE...
I developed Old School Race (oldschoolrace.com) all with Flash CS5.5 spending more time waiting Flash than coding........... and when you include some embedded images the packaging time grow up esponentially.
Now I'm using Flash Builder and all is ok, it's very fast also with lot of embedded images. Don't wait, spend some hours getting closed with FB, you'll re-save this (good spent) hours in a while
I hear a lot from Flash Builder users who are taking 20 minutes to compile a mobile app, where I take a couple of minutes in Flash Pro to compile huge apps. So, FB can be slow too.
Back to the slowness, in the AS3 settings there is a Warnings option, turning that off can sometimes dramatically speed things up.
