Hi
I am trying to invoke a .net webservice method that receives an array of strings an i noticed that if i do this:
<cfscript>
text = arraynew(1);
text[1] = "Hello";
text[2] = "world";
</cfscript>
<cfinvoke method="Hello"
webservice="http://localhost/Service1.asmx?wsdl"
returnvariable="response">
<cfinvokeargument name="array" value=#text#/>
</cfinvoke>
I get this error
Cannot perform web service invocation Hello.
The fault returned when invoking the web service operation is:
''java.lang.IlligalArgumentException: argument type mismatch
however if i do this it works well:
<cfscript>
root = structnew();
text = arraynew(1);
text[1] = "Hello";
text[2] = "world";
root.string=text;
</cfscript>
<cfinvokeargument name="array" value=#root#/>
</cfinvoke>
I know this has to do with the generated java proxy because he generated a structure called ArrayOfString with a property called string (what i am replicating in the "root" variable).... Is there any way around this, or this is the right way to do it? It is a bit painfull to do it like this...
Thanks.
I can imagine that. Run the following code, and you will find that a ColdFusion array isn't a Java array at all, but a Java vector!
<cfscript>
text = arraynew(1);
text[1] = "Hello";
text[2] = "world";
</cfscript>
<cfoutput>
text: #text.getClass().getsuperclass().getname()#
</cfoutput>
One of the methods of the java.util.Vector class is toArray(). So, have a go with
<cfscript>
text = arraynew(1);
text[1] = "Hello";
text[2] = "world";
textArray = text.toArray();
</cfscript>
<cfinvokeargument name="array" value="#textArray#" />
</cfinvoke>
Rockit8 wrote:
I tried calling the toArray() but throws the same type mismatch error
Sorry to hear that. We'll search on of course.
Dumping both the text and the textArray returns the same thing.
Not really. ColdFusion tells you they are both arrays, which is true. However, text is a ColdFusion array (a Java vector), whereas textArray is a Java Object array.
<cfoutput>
text: #text.getClass().getsuperclass().getname()#<br>
textArray: #textArray.getClass().getname()#
</cfoutput>
You are right, i was looking just at the basic <cfdump.../>
The thing is, by decompiling the java stubs generated by the wsdl2java i can see this:
public abstract interface Service1Soap extends Remote
public abstract String Hello(ArrayOfString paramArrayOfString)
throws RemoteException;
He is expecting a structure of the type ArrayOfString. Looking at this class i can see the following property:
public String[] string;
So this is basically the reason i created the structure and property with names that match this description in the first place... this is want i wanted to avoid.
Of course i can do this dinamically for some cases but if there is an out-of-the-box method to do this i would like to know. ![]()
Regarding the hello signature...its a .Net webservice and the method has the following signature:
public string Hello(string[] array);
After looking at the WSDL i think there is not mutch i can do to avoid this:
<s:element name="Hello">
<s:complexType>
<s:sequence>
<s:element minOccurs="0" maxOccurs="1" name="array" type="tns:ArrayOfString"/>
</s:sequence>
</s:complexType>
</s:element>
<s:complexType name="ArrayOfString">
<s:sequence>
<s:element minOccurs="0" maxOccurs="unbounded" name="string" nillable="true" type="s:string"/>
</s:sequence>
</s:complexType>
Thanks.
Message was edited by: Rockit8
Ah, a String[]! You could simulate it using the following, even more compact, code:
<cfscript>
text = toString("Hello,World").split(",");
</cfscript>
<cfinvokeargument name="array" value="#text#" />
</cfinvoke>
True, but that would only work in case of String[]!
I can fix the problem and develop something generic that does that kind of plumbing code for me...which would take me like 10 minutes or less to do.
I just posted this to know if there were any alternatives to my aproach...maybe a specific wsdl2java parameter that i dont know about.
Thanks.
Does it work?
I do believe that you, as client, should not aim to be generic. In the client-server model, the server (in this case, the web service) has the obligation to tell you precisely what type of argument it expects. If the server requires a string array, then you have to pass it a string array.
BKBK wrote:
Does it work?
No, it does not...the java proxy is expecting the structure i specified above.
Exactly...the server IS expecting a string[] as you can see by the signature of the method.
If i call it in a .Net client i invoke the method with a string[] as parameter, from the coldfusion side i cannot do that because of the generated proxy...the problem is in the proxy generation.
I'm guessing there is nothing i can do about that...
Lets forget about the generic part...if there is a way to invoke that method without creating the "root structure" that solves my problem. ![]()
Thanks.
If i call it in a .Net client i invoke the method with a string[] as parameter, from the coldfusion side i cannot do that because of the generated proxy...the problem is in the proxy generation.~
Very clear.
Out of curiosity, what error message did you get when you passed the string array?
Added update: I thought it might be a good idea to add the attribute refreshWSDL = "yes" to cfinvoke, during your tests, to prevent ColdFusion from reusing the cached version of the proxy.
Passing the ColdFusion array (java vector) or the solution you gave with the toArray() method i allways get the same error:
Thanks. I got that. I am now talking about the error you get when you do:
<cfscript>
</cfscript>
</cfinvoke>
<cfscript>
</cfscript>
</cfinvoke>
Its the same argument type mismatch error.
It only works if you change it to this:
<cfscript>
root.string = text; //create structure and property
</cfscript>
<cfinvokeargument name="array" value="#root#" />
</cfinvoke>
Yes, he allways creates a struct wrapping the arrays.
I was playing with the wsdl2java arguments and according to the documentation this one was worth trying:
-w or --wrapArrays: Prefers building beans to straight arrays for wrapped XML array types. This switch is not in included in the Axis documentation.
But the proxy generation was exactly the same and the error still occurred.
Just because i'm curious...you created a webservice using .net or other technology?
I was playing with the wsdl2java arguments and according to the documentation this one was worth trying:-w or --wrapArrays: Prefers building beans to straight arrays for wrapped XML array types. This switch is not in included in the Axis documentation.
No idea if it will work, but I would think you would want the opposite.
Rockit8 wrote:
Yes..that didnt work...made no difference. The opposite would be nice but as far as I know there isnt one.
Did you apply my earlier suggestion, refreshWSDL = "yes", to suppress the use of caching? I expect the following combination to work:
refreshwsdl="yes" wsdl2JavaArgs="nowrapped"
Hi
The "--nowrapped" arg changes the way the wsdl is generated but not in the way i wanted, using the same method as above what it creates in the java is this:
public abstract HelloResponse Hello(hello paramHello)
He creates a new class that wraps the request and response parameters:
public class hello
implements Serializable
private ArrayOfString array;
So the --nowrap actually works like one more level of wrapping..![]()
In my web service test, the following call works as expected! I am looking into it to see if this is by accident or by design.
<cfscript>
strArray = toString("Hello,World").split(",");
</cfscript>
<cfinvoke method="myFunc"
webservice="http://127.0.0.1:8500/workspace/cf_proj/ws_complexTypes/Test.cfc?wsdl"
returnvariable="response" refreshwsdl="true" wsdl2JavaArgs="nowrapped" >
<cfinvokeargument name="arr" value="#strArray#" />
</cfinvoke>
<cfdump var = "#response#">
How is your "myfunc" method described in the wsdl? (post the equivalent of what i posted above in your webservice wsdl).
I copy-pasted your code, changed the webservice and got the same error...so the only difference between what you are using and what i am using is the webservice technology...you are using coldfusion, i am using .net.
<xs:element name="myFunc">
<xs:complexType>
<xs:sequence>
<xs:element maxOccurs="unbounded" minOccurs="0" name="arr" nillable="true" type="xs:anyType"/>
</xs:sequence>
</xs:complexType>
</xs:element>
True, but that is the key. Since there is no direct mapping of the .NET ArrayOfString class in Axis, it is treated as a structure in CF. Just like any other custom/complex type.
Makes sense...my wsdl is enforcing the ArrayOf<type_name>...
So did you ultimately change anything .. or just leave it as ArrayOfString? (Though that is a bit of a misnomer imo, since it is a class not an array.)
In the .net webservice the method still receives a string[] but i think there is nothing i can do to change the wsdl generation...and i do not want to do that since i'll be consuming other webservice done in some other technology.
In the coldfusion side its still expecting the ArrayOfString...
As said before, the transformation of a CF array to the ArrayOf<Type_name> can be one dynamically so i think i'll take that aproach.
The 'root' is just the name of the structure that will contain the array, doesn't matter what name you give to that variable, now the 'string' part is the important part. The 'string' is basically the name of the parameter in the webmethod...the method was something like:
void myFunc(String[] string);
You can know the correct name by looking at the wsdl. In this case since i was creating both the service and the client it was a easier.
If you don't want to look at the WSDL you can use the wsdl2java to generate a proxy and see what's the structure of the objects. what you create in coldfusion has to match what wsdl2java is expecting.
Hope it helps.
