Totally clueless here! Im using DW MX 2004. I recently updated from XP to 7 using the Windows file transfer utility. I thought my "backup" external hard drive was corrupted and I had lost all of my backup, so I reinstalled MX 2004, which obviously has none of my website info. I did end finding some of the MX 2004 files/folders, etc... I didnt export anything, as I apparently should have. I assume that all of my info saved everytime i saved it upon closing, no?
1) In which file(s) is my website info stored? Is it the data files? and,
2) How do I get my website info to the currently installed version of MX 2004?
I appreciate any help I can get with this mess. Thank you in advance!
Do you have your Web site uploaded and viewable on a Web server?
If so, you could download the entire site onto your local machine... save it in a backup folder just in case you can't find all the files on your local machine.
we would have no idea where you decided to create and store your web site.... although there may be a default folder DW uses. Perhaps someone will mention that.
Did you store it on your external hard drive and not on your local drive?
Are they data files?... well that depends on what type of a Web site you have. If it's just a static HTML page, then many of the files would be .html files.... and most likely some image files (.jpg, etc).
You may also have a .css and/or some .js (javascript) files and/or some DreamWeaver template files .dwt
Search your drives for "*.css" and *.js" files. or at the very least, search for "*.dwt" and "*.html". The search should return files you recognize as being from your site. See what folder location they are in and go from there.
But in the future, build the Web site folder structure in a location of your choosing, do not let DreamWeaver choose. Make it a location that makes sense to you and is easy to remember.
Best wishes,
Adninjastrator
If so, you could download the entire site onto your local machine... save it in a backup folder just in case you can't find all the files on your local machine. Lunar pages hosts my website.
Did you store it on your external hard drive and not on your local drive? Yes It Was stored on my local drive. I used the ext HD for the transfer- which is where the files should be now. theyre still on my computer drive as well, but since i changed from Xp to 7, i dont know where to look.
But in the future, build the Web site folder structure in a location of your choosing, do not let DreamWeaver choose. Make it a location that makes sense to you and is easy to remember. Will do! Someone else had set this up for me.
Best wishes,
Adninjastrator
Hi
First, your site definitions for Dw are stored in the registry files, so unfortunately these have been lost forever.
As for the actual site files, providing you did not format your drive before installing Windows 7, you could locate the files on your hard drive and copy these, you will probably have to 'take possession' of these though before you will have access to them, (or just take possession of the entire drive).
PZ
For a backup of your Web site from Lunar Pages, use an FTP program like Filezilla:
Get that installed and set up, log into your Lunar pages account via FTP, then download the entire contents from the "public_html" folder on your server. That will be the entire web site as it stands now on the Internet. Use this as backup in case you don't find your other files.
To find files on your local or ext hard drive, do a simple "search". Open Windows Explorer to view files, double click on your hard drive and in the search box type in the searches I suggested (*.css, *.dwt, *.html, *.js) meaning, search for all files with the file extention .css, etc.
From the results you may be able to recognize files from your site. Note the folder location and then go into that folder and look around.
Of course, downloading a backup copy from your sever will give you everything, neatly organized and in working order.
Best wishes,
Adninjastrator
OK, here's where I am so far..Ive downloaded and ran filezilla. Im able to see my website content. hidden amidst a ton of stuff i dont know, ive found where my images are stored. any idea as to where id look to find each page and the layout instructions? heres a link to one of my pages. i need to find out where the intructions to make this page look like it does, reside. (black background, red writing, graphics, sizes, etc...)in the public_html file reside all my images. is it in there somewhere? Ive opened every file i can see.
im sorry if im not making sense, i just dont know how to describe this stuff.
Download the ENTIRE "public_html" folder to your local machine. This is the "root" of your Web site.
This will contain the entire site... all files.
Once that is done... and on your local machine, then you can use DW to browse to any HTML page in that folder.
There are no magic set of instructions... it's all coded in HTML markup language used on that particular page (and related CSS file), so...
Open the HTML page in DW and view the page in DreamWeaver "Codeview"
All the code (instructions) on constructing the page will be right there, in the code view.
If you need some refresher of HTML and CSS (Cascading Style Sheets):
http://www.w3schools.com/html/
Best of luck!
Adninjastrator
Thanks for the links. OK, I found the "public_html" file and everything that i was lookiing for is in there. There are a bunch of other files besides public-html. do i need to download them also? will i need to use filezilla or can i just click the down arrow in DW, as I used to?
"You will then have to define your site in Dreamweaver, and if you wish to preview your site locally from Dreamweaver install a local web server."
Does this mean i will have to reenter all the website/server info in DW as it used to be? Is that info located in a particular file that i can find? I plan on reading the DW tutorials to help me set it up, tonight. can you point me to any specific ones that would show me how to fill in those fields?
Can all this be done remotely? Im so frustrated at being lost that im willing to pay someone. after this mess, I will DEF learn how to do this stuff. i just need the website up and running asap.
Thanks again guys!
