Hi All,
Need to insert tagging (character style name) surrounding the text which has character styles applied in InDesign document.
Example: This is <italic>an</italic> example of <bold>character style</bold> tagging text.
Please provide JS code for this.
Thanks in advance,
Mon
I think a simple grep find/change will work, look at the image below.
The .+ finds any character, one or more times,
In the Change To field type the code you want to use eg <bold>$0</bold>, the $0 puts back what is found.
Finally, in the Find Format area, select the formating that you are looking for.
Dear All,
I have tried myself. But there is a problem with my code. It selects characterStyle [NONE]. And add <> symbol before and after of every paragraph style. Actually, I need to insert <> symbol before and after character style applied text (see my First Query).
How can we avoid NONE characterstyle in my below code. Please help.
var myAppliedCStyle = [app.findGrepPreferences.appliedCharacterStyle]
app.findGrepPreferences = null;
app.changeGrepPreferences = null;
app.changeGrepPreferences.changeTo = "<$0>";
for (i=0; i<myAppliedCStyle.length; i++)
app.findGrepPreferences.findWhat = ".+";
app.changeGrepPreferences.appliedCharacterStyle = myAppliedCStyle[i];
app.activeDocument.changeGrep();
Mon
Try this. I'm also fresher...
First u have to create tags manually with names b, bi,i, sc (bold,bolditalic,italic, small caps)...
then execute this js...
docObj=app.activeDocument;
xmlObj = docObj.xmlTags;
pageObj=docObj.pages.item(0);
myTextFrame=pageObj.textFrames.item(0);
myText=myTextFrame.parentStory.paragraphs.item(0);
app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
app.findTextPreferences.fontStyle = "Bold";
app.changeTextPreferences.markupTag=xmlObj[0].name;
alert(app.changeTextPreferences.markupTag);
app.activeDocument.changeText();
app.findTextPreferences.fontStyle = "Bold Italic";
app.changeTextPreferences.markupTag=xmlObj[1].name;
app.findTextPreferences.fontStyle = "Italic";
app.changeTextPreferences.markupTag=xmlObj[2].name;
app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
app.findGrepPreferences.capitalization = Capitalization.SMALL_CAPS;
app.changeGrepPreferences.markupTag=xmlObj[4].name;
alert(app.changeGrepPreferences.markupTag);
I have already seen this code that link is provided by Larry. This code is for XML tags whereas there is no XML tag in my document.
I just want to replace text using character style with character style name code i.e., <bold>, <italic> etc.
I write below code, its working but adds code (< and >) before and after every paragraph. How to avoid NONE character style sheet in my code?
Thanks in advance,
Mon
Hi Velprakash,
In my document there are some character styles applied in text i.e., bold, italic, boldItalic, and superscript etc.,
I want to use this character styles name as a code surrounding character style applied text, so that I can use this tags as a XML tag when required.
For example:
This is a <bold>bold</bold> text and <italic>italic</italic> text.
In above example character style bold and italic is used. And I need those styles as a codes before and after styled text.
Please help.
Mon
Try this:
styleCodes = ['Bold', 'Italic', 'Bold Italic'];
styleTags = ['bold', 'italic', 'boldItalic'];
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = '.+';
for (i = 0; i < styleCodes.length; i++)
app.findGrepPreferences.fontStyle = styleCodes[i];
app.changeGrepPreferences.changeTo = '<'+styleTags[i]+'>$0<' + '/' + styleTags[i] + '>';
Peter
Hi Peter,
Firstly, I would like to thanks for all your time and support.
Your JS code is searching fontStyle defined in variable (styleCodes) whereas I need to search any appliedCharacterStyle in the document. There are lots of character style available in the document. Is there any JS code to achieve this?
I also want to admit that Last year, I bought InDesign javascripting book written by you. It helps me a lot. Its great book for learner.
Mon
True, that's what you wanted:
charStyles = app.activeDocument.allCharacterStyles;
// Start at 1 to skip charstyle [None]
for (i = 1; i < charStyles.length; i++)
app.findGrepPreferences.appliedCharacterStyle = charStyles[i];
app.changeGrepPreferences.changeTo = '<'+charStyles[i].name+'>$0<' + '/' + charStyles[i].name + '>';
Peter
