SandyGriffin
Photoshop Elements "Edit" does not open
Apr 16, 2012 9:17 PM
The "Edit" option in Photoshop Elements no longer opens (the "Organizer" option still works ok.)
Suggestions?
Sandy
    Apr 16, 2012 9:23 PM   in reply to SandyGriffin
    OS version?
    PSE version?
    What are the steps you're doing to try and open the Editor?
    Ken
    Apr 17, 2012 6:13 AM   in reply to photodrawken
    Any change if you restart machine? Does it launch at least once after computer restart?
    I assume that you click on Edit button and nothing happens after that. If that's the case, you can try following - http://bit.ly/HUzzBR ... Let's see if you are able to delete preferences or not.
    Apr 25, 2012 11:18 PM   in reply to SandyGriffin
    On the drive on which you have installed PSE,on my machine it is on C:
    Go to c:\Program Files\Adobe\Photoshop Elements 9\Locales\<locale>\Plug-Ins\Import-Exportand you will find twain plug-in. Remove that plug-in from that location and copy it somewhere else.
    Now launch PSE and check if it works.
    Alternatively,
    Try resetting the PSE preferences by
       1. Close Elements.
       2. Launch the Photoshop Elements Welcome Screen and hold down ctrl + alt + shift as you click Edit.
       3. Continue to hold the keys until you see a message box asking if you want to delete Photoshop Elements settings file; click Yes. Elements will open with default preferences.
    - Disable any anti-virus software just to confirm if it is not blocking PSE Editor.
    In case any network printer is attached try to launch without network or printer uninstall.
    try and let me know your comments.
    -Garry
    Sep 5, 2012 8:38 PM   in reply to ukgaurav
    I'm having the same problem as Sandy and I tried your second idea but it doesn't work.
    Sep 5, 2012 9:11 PM   in reply to Shirette
    I just fixed the problem. I searched the hard drive for the editor and found that it was moved to a different location than Adobe Elements 10. I think when I first started the program I accidentally clicked and dragged it to the new location. I've dragged it back and it is fine now.
