No startup profiles
Apr 16, 2012 7:29 AM
Dear all
I am using Win7 x64 and installed Adobe Creative Suite Standard CS 5.5. Everything works fine except the Illustrator.
When I open it and select File -> New Document a message appears: Can't locate startup profiles.
Can anyone help me with this?
TIA
    Apr 16, 2012 7:48 AM   in reply to NathanLutz
    Check whether they actually exist and if you have sufficient file permissions and user privileges on them --> C:\Users\Nathan\AppData\Roaming\Adoeb\Illustrator.
    Mylenium
    Apr 17, 2012 7:16 AM   in reply to NathanLutz
    Nathan,
    What happens if you uninstall, run the Cleaner Tool, and then reinstall?
    http://www.adobe.com/support/contact/cscleanertool.html
    Apr 17, 2012 10:34 AM   in reply to NathanLutz
    Did you install the application so that all uisers can access it>
    When you reinstalled did you first uninstall and remove the settings folder.
    Explain your unistall procedure was it removed from the administrator account?
    Apr 18, 2012 7:27 AM   in reply to NathanLutz
    The following folder needs Read & Write access:
    C:\Users\<username>\AppData\Roaming\
    I#f still his doesn't work then copy the Adobe Folder from the   domain administrator and paste it on above path and check.
