Ron Nichols
CS6 Won't open files - Program Error
Apr 17, 2012 7:16 AM
Tags: #bug #beta #bug_report #cs6_beta
When I try to open files in CS6, I get an error "Could not complete your request because of a program error."     I have restarted PS and rebooted the machine.
Running Mac OS 10.6.8
2.8 GHz   Core i7
12 GB Ram
The same files open fine on CS5.
    Apr 17, 2012 7:23 AM   in reply to Ron Nichols
    Have you tried resetting your preferences yet? FAQ: How do I reset my preferences?
    Apr 17, 2012 7:25 AM   in reply to Ron Nichols
    Did you rest the preferences?  File not affected by a re-install.
    Start PS and IMMEDIATELY hold down the Cmd + Option + Shift keys.  Should get a reset window.
    It is a little tricky, if you see the splash screen first you are too late.
    Message was edited by: Curt Y  Howard is a faster at typing.
    Apr 17, 2012 7:39 AM   in reply to Ron Nichols
    Did you copy/link your plug-ins by any chance? That can also cause issues. If you copied any plug-ins to your plug-ins folder, remove them. If you linked an additional plug-ins folder (In your Plug-ins Preferences), try unlinking it and restarting Photoshop.
    Apr 17, 2012 7:49 AM   in reply to Ron Nichols
    What type of files are you opening? This is happening for all files you try to open?
    Apr 17, 2012 8:02 AM   in reply to Ron Nichols
    If you go to Bridge  and right click do you have option to open in CS6.
    Or if in Bridge CS6 will image open in  PS CS6?
    Apr 17, 2012 9:48 AM   in reply to Ron Nichols
    Can we see your System Info log?
    And can you post the contents of ~/Library/Preferences/Photoshop CS6 Settings/PSErrorLog.txt ?
    Apr 17, 2012 12:58 PM   in reply to Ron Nichols
    In Bridge CS6 edit/preferences/startup scripts do you have them all checked?
    Apr 17, 2012 8:02 PM   in reply to Ron Nichols
    If there was a program error, then the PSErrorLog.txt file should be in the settings folder.
    That file might tell us where the error is occuring. But without that file, we have no idea why your system is giving an error that nobody else is seeing.
