dynamically change the caption to the radio button
Apr 17, 2012 3:44 AM
hello you can change the caption for the radio button dynamically? within a loop?
I tried these 5 education but do not work:
    list.RadioButtonList.nomelist.resolveNode("caption.value.#text").valu e = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    list.RadioButtonList.nomelist.selectedMember().caption.value.text.val ue = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    ListOggetto.resolveNode("caption.value.#text").value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    ListOggetto.selectedMember().caption.value.text.value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    list.RadioButtonList.nomelist.caption.value.resolveNode("#text").valu e = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
this code:
//file xml
var numero = xfa.record.modulo.list.nodes.length;
for(i=0; i<numero; i++){
    var ListOggetto = xfa.resolveNode("list.RadioButtonList.nomelist["+i+"]");
    Apr 17, 2012 7:54 AM   in reply to noos76
    Try this:
    form1.p1.Button1::click - (JavaScript, client)
    var number = xfa.resolveNode("xfa.form.form1.p1.rbl").nodes.length; //figure out how many children the exclusion group has
    for (i=0;i<number;i++) {
    xfa.resolveNode("xfa.form.form1.p1.rbl.rb[" + i + "].caption.value.text").value = "new caption for RB " + (i+1); //assumes all children are named 'rb'
    result should be :
    New caption for RB 1
    New Caption for RB 2
    Apr 17, 2012 8:25 AM   in reply to noos76
    Please look at my sample:
    https://acrobat.com/#d=8WKhVvc-uMnJdnNZj007oQ
    It looks like the context is wrong in your script.
    KJ
    Apr 17, 2012 9:01 AM   in reply to noos76
    Your proble was in the script:
    The below script works in the context of your form. I don't have access to your data xml file, so I changed "record" to "form", and used the form model instead.
    modulo.pagina.Button1[0]::click - (JavaScript, client)
    //list.RadioButtonList.nomelist.caption.value.text.value = xfa.record.modulo.list.nomelist.value;
    var numero = xfa.form.modulo.pagina.list.RadioButtonList.nodes.length;
    app.alert(numero);
    //pippo = new Array;
    xfa.resolveNode("xfa.form.modulo.pagina.list.RadioButtonList.nomelist[ " + i + "].caption.value.text").value = "New Caption" + (i+1);
    Result=
    New Caption 1
    Apr 17, 2012 9:09 AM   in reply to noos76
    By default, the exclusionGroup is set to layout top to bottom, (layout="tb").
    You can modify the layout such that it becomes
    exclGroup name="RadioButtonList" layout="lr-tb
    This will make it layout horizontally.
    However, I would wrap the exclusionGroup in a subform, and set the subform to be flowed and western Text (lr-tb). The radiobButtons will be laid out horizontally.
