dynamically change the caption to the radio button
Avatar
Level 4
hello you can change the caption for the radio button dynamically? within a loop?
I tried these 5 education but do not work:
    list.RadioButtonList.nomelist.resolveNode("caption.value.#text").value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    list.RadioButtonList.nomelist.selectedMember().caption.value.text.value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    ListOggetto.resolveNode("caption.value.#text").value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    ListOggetto.selectedMember().caption.value.text.value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
    list.RadioButtonList.nomelist.caption.value.resolveNode("#text").value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
this code:
//file xml
var numero = xfa.record.modulo.list.nodes.length;
for(i=0; i<numero; i++){
    var ListOggetto = xfa.resolveNode("list.RadioButtonList.nomelist["+i+"]");
Avatar
Employee
Try this:
form1.p1.Button1::click - (JavaScript, client)
var number = xfa.resolveNode("xfa.form.form1.p1.rbl").nodes.length; //figure out how many children the exclusion group has
for (i=0;i<number;i++) {
xfa.resolveNode("xfa.form.form1.p1.rbl.rb[" + i + "].caption.value.text").value = "new caption for RB " + (i+1); //assumes all children are named 'rb'
result should be :
New caption for RB 1
New Caption for RB 2
Avatar
Level 4
thanks for the reply, unfortunately it does not work.
I'm going to take values ​​in a xml file
trying your code I should be in error
TypeError: xfa.resolveNode("list.RadioButtonList.nomelist[" + i + "].caption.value.text") is null
7:XFA:modulo[0]:pagina[0]:Button1[1]:click
Avatar
Employee
Please look at my sample:
https://acrobat.com/#d=8WKhVvc-uMnJdnNZj007oQ
It looks like the context is wrong in your script.
KJ
Avatar
Level 4
http://www.filedropper.com/forumrb2
attached file, the data I take them in an xml file that is inside the pdf
Avatar
Level 4
Another problem I have to put radiobuttons horizontally
Avatar
Employee
Your proble was in the script:
The below script works in the context of your form. I don't have access to your data xml file, so I changed "record" to "form", and used the form model instead.
modulo.pagina.Button1[0]::click - (JavaScript, client)
//list.RadioButtonList.nomelist.caption.value.text.value = xfa.record.modulo.list.nomelist.value;
var numero = xfa.form.modulo.pagina.list.RadioButtonList.nodes.length;
app.alert(numero);
//pippo = new Array;
xfa.resolveNode("xfa.form.modulo.pagina.list.RadioButtonList.nomelist[" + i + "].caption.value.text").value = "New Caption" + (i+1);
Result=
New Caption 1
Avatar
Employee
By default, the exclusionGroup is set to layout top to bottom, (layout="tb").
You can modify the layout such that it becomes
exclGroup name="RadioButtonList" layout="lr-tb
This will make it layout horizontally.
However, I would wrap the exclusionGroup in a subform, and set the subform to be flowed and western Text (lr-tb). The radiobButtons will be laid out horizontally.
Avatar
Level 4
hello thanks for the reply, I solved the problem of objects positioned horizontally, good
unfortunately I could not solve the problem of the caption, I have to force access to data from the xml file
