Fixing images
Apr 17, 2012 8:51 AM
Tags: #linking
Hi all,
I'm a total InDesign novice. I started a document by copying and pasting screenshots into my document, which has now become huge. I think it would be better to save them somewhere and link to them, from what I've learned. Is there a way to do that since I only have these images pasted in the doc?
Paulette
    Apr 17, 2012 8:55 AM   in reply to PauletteP2
    The only possibility I can think of would be to export to PDF and extract them for them there. But screenshots are not exactly high quality to begin with and I suspect the results will be less than stellar.
    Bob
  • Rob Day
    Oct 16, 2007
    Apr 17, 2012 12:38 PM   in reply to PauletteP2
    This sequence will get you a PS file with the original screen capture pixels:
    direct select the capture (white arrow tool)
    in the Transform panel set the horizontal and vertical scales to 100%
    Copy
    In Photoshop, File>New>OK>Paste>Return (PS sets the new file dimensions to the clipboard content)
    You can flatten this PS file, Save and link it into your ID layout.
  • lilia@
    Jan 31, 2012
    Apr 17, 2012 12:46 PM   in reply to PauletteP2
    I would do what bob suggests, however... (not a fan of answering questions without my laptop to check it out, but here goes) are the pasted images in the links panel?
    If they are you should be able to unembed them.
    Extract from the ID help file...
    Unembed a linked file
    1. Select one or more embedded files in the Links panel.
    2. Do one of the following:
      • Select Unembed Link in the Links panel menu. If there are multiple instances of the file, choose Unembed All Instances Of [Filename] in the Links panel menu.
      • Click the Relink button or select Relink in the Links panel menu.
    3. Choose to link the file to the original file or to a folder InDesign creates from the embedded data stored in the document.
  • Rob Day
    Oct 16, 2007
    Apr 17, 2012 1:17 PM   in reply to lilia@
    If you paste an object nothing shows in the Links panel—you can only unembed when a linked file has been embedded.
    The sequence I described works. PS sees the copied capture as a Vector Smart Object—you'll get the same pixels as long as the scale is 100%.
    Left original right copied from ID
  • Rob Day
    Oct 16, 2007
    Apr 17, 2012 2:23 PM   in reply to PauletteP2
    I don't think that will help, a pasted object exported as a snippet is still pasted when you place the snippet—it's not linked.
  • lilia@
    Jan 31, 2012
    Apr 17, 2012 2:45 PM   in reply to Rob Day
    whatever file type you choose... they MUST be linked to do what you need.
    Apr 17, 2012 3:13 PM   in reply to PauletteP2
    I like Rob reply.
    If not, you can click unembed link and click "no", this will give you your embedded image that you can place in a folder and relink to document.
  • Rob Day
    Oct 16, 2007
    Apr 17, 2012 3:25 PM   in reply to 33 Steps
    can't do that with a pasted object.
    Apr 18, 2012 4:26 AM   in reply to Rob Day
    Here is an interesting idea.
    A snippet is still that -- a snippet --, but it gets saved in a fairly easy parseable format: XML. Inline images are saved as Base64 encoded strings; on my Windows machine as a true color BMP, regardless of the "original" format. (I'm willing to bet this is platform-dependent and suspect it will turn out to be a 24-color PNG when saved on a Mac.)
    So it's theoretically possible to write a script that saves a selected image as a snippet, re-reads it into memory, scans for the embedded image, saves that into a separate file, and replaces the selected image with the actual linked file.
  • Rob Day
    Oct 16, 2007
    Apr 18, 2012 4:48 AM   in reply to [Jongware]
    Why jump through the snippet hoop? As long as the scale is 100% copying the pasted image gets you the original pixels.
  • Rob Day
    Oct 16, 2007
    Apr 18, 2012 5:03 AM   in reply to Rob Day
    You can use Photoshop's Difference blend mode to check if two images are identical. Here I've pasted an image into Indesign (no link), copied the pasted image from ID, and layered it over the original in Photoshop—it pastes as a Smart Vector. Difference shows they are identical.
    Apr 18, 2012 6:24 AM   in reply to Rob Day
    Yeah, but I was suggesting a script (which itself only uses a snippet as a temporary file; no further hoops required) because it would be a one-click solution from within InDesign. Compare with your solution: copy, go to Photoshop, paste, save as new file, return to InDesign, replace selected image with file.
    And of course you'd also get 'the original pixels' that way.
  • Rob Day
    Oct 16, 2007
    Apr 18, 2012 6:55 AM   in reply to [Jongware]
    But I wonder if you really need the snippet for a script. With pasted images there's no proxy—it's a vector object—so if you script a copy, the actual image is on the clipboard. With AppleScript you could save the contents of the clipboard via Photoshop or maybe skip PS and use Image Events for a direct save.
    Apr 18, 2012 7:25 AM   in reply to Bob Levine
    When you make the PDF - open it in photoshop - there is an option at the top of the dialogue box called Images - use that.
    And you can open all the images from a PDF using this feature.
    Save them. Then place them again within the document.
  • Rob Day
    Oct 16, 2007
    Apr 18, 2012 8:00 AM   in reply to Eugene Tyson
    That works if you don't need the entire image. If you've cropped it inside if a frame in ID you get a cropped image in PS
  • Rob Day
    Oct 16, 2007
    Apr 19, 2012 1:35 PM   in reply to [Jongware]
    I stumbled upon an AppleScript that saves clipboard data today. Turns out if you copy a pasted image it's a PDF on the clipboard, so it was easy to write an AppleScript that saves any pasted images to a folder as PDFs and links them back in. If JavaScript lets you write clipboard data it would be easy to replicate:
    http://www.zenodesign.com/forum/LinkPasted.zip
  • Rob Day
    Oct 16, 2007
    Apr 23, 2012 5:06 PM   in reply to PauletteP2
    If you're on a Mac the script I posted should work, but make sure to save a copy of your layout before running the script.
  • Rob Day
    Oct 16, 2007
    Apr 24, 2012 2:19 PM   in reply to PauletteP2
    Before you copy the screen capture in ID you have to set the vertical and horizontal scale to 100% in the Transform panel. Are you doing that?
  • Rob Day
    Oct 16, 2007
    Apr 24, 2012 2:32 PM   in reply to PauletteP2
    If you haven't scaled the captures remaking them won't give you higher resolution.
    There are two different scales the scale of the holding frame and the scale of the image are you sure you are selecting the image and not its frame:
    image selected with white arrow tool 51.67%
    frame selected with black arrow tool 100%
