hello you can change the caption for the radio button dynamically? within a loop?
I tried these 5 education but do not work:
list.RadioButtonList.nomelist.resolveNode("caption.value.#text").valu e = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
list.RadioButtonList.nomelist.selectedMember().caption.value.text.val ue = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
ListOggetto.resolveNode("caption.value.#text").value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
ListOggetto.selectedMember().caption.value.text.value = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
list.RadioButtonList.nomelist.caption.value.resolveNode("#text").valu e = xfa.record.modulo.list.nodes.item(i).nomelist.code.value;
this code:
//file xml
var numero = xfa.record.modulo.list.nodes.length;
for(i=0; i<numero; i++){
var ListOggetto = xfa.resolveNode("list.RadioButtonList.nomelist["+i+"]");
Try this:
form1.p1.Button1::click - (JavaScript, client)
var number = xfa.resolveNode("xfa.form.form1.p1.rbl").nodes.length; //figure out how many children the exclusion group has
for (i=0;i<number;i++) {
xfa.resolveNode("xfa.form.form1.p1.rbl.rb[" + i + "].caption.value.text").value = "new caption for RB " + (i+1); //assumes all children are named 'rb'
result should be :
New caption for RB 1
New Caption for RB 2
Please look at my sample:
https://acrobat.com/#d=8WKhVvc-uMnJdnNZj007oQ
It looks like the context is wrong in your script.
KJ
http://www.filedropper.com/forumrb2
attached file, the data I take them in an xml file that is inside the pdf
Your proble was in the script:
The below script works in the context of your form. I don't have access to your data xml file, so I changed "record" to "form", and used the form model instead.
modulo.pagina.Button1[0]::click - (JavaScript, client)
//list.RadioButtonList.nomelist.caption.value.text.value = xfa.record.modulo.list.nomelist.value;
modulo.pagina.Button1[0]::click - (JavaScript, client) //list.RadioButtonList.nomelist.caption.value.text.value = xfa.record.modulo.list.nomelist.value; var numero = xfa.form.modulo.pagina.list.RadioButtonList.nodes.length; app.alert(numero); //pippo = new Array;
xfa.resolveNode("xfa.form.modulo.pagina.list.RadioButtonList.nomelist[ " + i + "].caption.value.text").value = "New Caption" + (i+1);
Result=
New Caption 1
By default, the exclusionGroup is set to layout top to bottom, (layout="tb").
You can modify the layout such that it becomes
exclGroup name="RadioButtonList" layout="lr-tb
This will make it layout horizontally.
However, I would wrap the exclusionGroup in a subform, and set the subform to be flowed and western Text (lr-tb). The radiobButtons will be laid out horizontally.
