haas422
how can I make a smart form like this one ?
Apr 17, 2012 4:10 AM
Tags: #forms #fields #acrobat_9_forms #acrobat_forms #fillable #acrobat_9_pro
hi
according to my business requirements I need to create a PDF form which contains a table with variable number of rows (containing numbers) , so the user should be able to add or remove rows to the table as much as he needs to , and there should be a row showing the total at the bottom of that table.
I'm absolutely sure that this is possible to be implemented in PDF using javascript but I need some help to do it.
I saw a working example - the same concept I required.
>> you could have a look here -
http://www.windjack.com/PDFSamples/ListPrograming_Part1_XFAForm.pdf
any idea how I can do so ?
thank you.
    Apr 17, 2012 4:39 AM   in reply to haas422
    Try the forum for LiveCycle Designer.
  • George Johnson
    Aug 11, 2002
    Apr 17, 2012 9:26 AM   in reply to haas422
    The sample form you linked to is an XFA form created in LiveCycle Designer. If you want to duplicate the functionality of that form, you could add the fields and hide them, and then show a row when a new one is requested. If you use a hierarchical naming convention, it makes it easier to show/hide a row of fields. For example, if you have a row of field with the names row2.col1, row2.col2, row2, col3, the code to show them would be:
    // Dsiplay a row of fields
    getField("row2").display = display.visible;
    Note that a feature of dynamic XFA forms can be a new page is automatically added to the document when the user requests that fields be added but they cannot fit on the current page, or the content that's lower on the page is automatically pushed down as new fields are added. The sample form you linked to does not behave this way, so you can get away with the approach I mentioned.
