Elements 8
Apr 17, 2012 4:46 AM
Can I use Elements 8 on a second Mac, using OSX 10.7.3?
If so how?
If not will Elements 10 work on this version of the Mac?
    Apr 17, 2012 5:53 AM   in reply to Mike Bigwood
    Yes, PSE 8 should work fine in 10.7 and you're allowed two installs. Just install it.
    Apr 17, 2012 10:29 AM   in reply to Mike Bigwood
    Okay,now you've got trouble. You can't transfer PSE that way, not ever. People sometimes think it works but eventually it always creates more problems than it solves. You're going to have to run clean script:
    http://www.adobe.com/support/contact/cscleanertool.html
    and then hunt down all the bits and bobs of PSE that you can find and manually remove them. Don't over look the application support>adobe folders in both your username>library and hard drive>library.
    Apr 17, 2012 10:37 AM   in reply to Mike Bigwood
    If the solution above doesn't help much, try the steps provided here. This might be a littl time consuming but luckily this works
    Apr 17, 2012 11:27 AM   in reply to Mike Bigwood
    Well, I guess you could, but if it were I, I'd still want to clean that up, I think.
