Spry menu bar stuck as unordered list
Apr 17, 2012 8:43 AM
Tags: #spry #menu #bar #list #unordered
I'm completely new to Dreamweaver and am trying to use it to update an existing website.  I exported the website files back onto my PC.
When I open a page in DW to edit it, the Spry menu bar (which works with horizontal drop down on the website) shows as an unordered list.  If I preview it, the list remains, i.e. the menu bar doesn't re-appear.
If I click the 'turn styles off/on' button, nothing happens.
I would be extremely grateful for any advice as to what I can do in order to get the page to open in DW with the menu bar functioning.
Many thanks
    Apr 17, 2012 9:16 AM   in reply to cheekbones1
    it sounds like your DW doesn't find the files situated in the "SpryAssets" directory. Please control your pathes. If there is a deeper nested directory or a file you need these ../ or ../../.
    If not, please load up your website onto your server, no matter how it looks like and give us the link to it.
    Hans-Günter
    Apr 17, 2012 10:48 AM   in reply to cheekbones1
    Hello cheekbones,
    here my "cookbook". First open one of your files, and jump to the place where you want to insert a spry menu.
    next step select the layout:
    If you had used a new DW file as I did for this example, your source code would like this:
    The two files, which you need, takes DW of itself and expects that your files are stored in a folder "SpryAssets". If DW does not find them it will ask you for them.
    Good luck!
    Hans-Günter
    Apr 17, 2012 11:22 AM   in reply to cheekbones1
    here it's now time to look after my family (blue hour), some hours before we have to go to bed.Also dann bis morgen!
    Hans-Günter
    Apr 18, 2012 2:22 AM   in reply to cheekbones1
    Hi cheekbones,
    I copied your source code into my DW and I used my SpryAssets, in the same directory. The spry menu bar worked in this case, by deleting these ../.
    And in this context, the question arises, why did you insert a SpryMenuBarVertical, as I can see here:
    <link href="SpryAssets/SpryMenuBarVertical.css" rel="stylesheet" type="text/css" />?
    In my opinion you can delete it there.
    Hans-Günter
    P.S.
    cheekbones > Wangenknochen?
    Apr 18, 2012 4:38 AM   in reply to cheekbones1
    Hi D,
    sorry no images in your note. Here a screenshot of MY directory:
    what gives with my
    <script src="SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
    <link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
    Hans-Günter
    P.S.
    Blaue Stunde > Blue Hour is today mainly a poetic term for the time between sunset and the twilight darkness of the night and for the time just before sunrise.http://en.wikipedia.org/wiki/Blue_hour
    Apr 19, 2012 8:16 AM   in reply to cheekbones1
    Hi D,
    you welcome, good luck furthermore!
    Let me add to your statement the importance of my suggestions which I expressed already in point 1: "it sounds like your DW doesn't find the files situated in the "SpryAssets" directory. Please control your pathes. If there is a deeper nested directory or a file you need these ../ or ../../."
    Hans-Günter
    Apr 19, 2012 11:05 AM   in reply to cheekbones1
    I would use trial-and-error method, 'cause nobody here knows your tree structure (see above). The best would be you load your website up to your server and publish a link to it.
