Bad Audio .MTS Files Premiere Pro CS4
Apr 16, 2012 10:11 AM
Tags: #mts #adobe_premiere_pro_cs4 #avchd_audio #sony_nex_fs100
Hello, I've looked around and haven't been able to find anything related to this post. I'm importing an AVCHD 29.97 1920x1080 .mts clip shot on a Sony FS100 into an AVCHD 1080p 30 sequence in Premiere Pro 4.2.1. Everything looks fine except the red render bar appears and the audio is nothing but really bad static. If I render the work area it plays fine except for the audio (still static). If I play the clip in VLC it plays fine. Same with Final Cut Express  import via log and transfer (apple intermediate) - looks and sounds great. But I can't get anything but bad static in Premiere CS4 and After Effects CS4.
    Apr 16, 2012 10:28 AM   in reply to mozlucian
    There is a problem with certain audio formats from Sony AVCHD cameras.  I don't recall what (if any) the solution was.  Do some forum searching/browsing.
    Apr 16, 2012 10:36 AM   in reply to mozlucian
    If you have a red bar upon import but no work, that means your project does not match your file
    Are you 100% sure your video is 1080p and not 1080i ?
    http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-bars.html
    Apr 16, 2012 12:45 PM   in reply to mozlucian
    >why would a 1080i sequence be the proper sequence for something shot progressive?
    I am on CS5 and you are on CS4... so my only GUESS is that CS4 is doing something different than CS5... or your camera is really shooting 1080i
    For more information on exactly what is inside your file...
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainspector.massanti.com/
    If you have a red line over the timeline after importing a video and before adding any effects... your project is wrong for your video... read above about codecs
    Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
    Apr 17, 2012 5:13 PM   in reply to mozlucian
    Audio Codec: LPCM
    Yep, that's the issue.  Sony cameras don't write the necessary header information to the file correctly, so PP has trouble with it.
    Like I said, search/browse the forums.  I just don't recall if there was a fix.
    Apr 17, 2012 7:05 PM   in reply to mozlucian
    MTS LPCM sound problem in CS4 http://forums.adobe.com/thread/913935
    Apr 18, 2012 10:23 PM   in reply to mozlucian
    CS6 should be out soon.  5.5 already blows FCP (7 and especially X) out of the water.  After 6 is released, Final Cut will at long last live up to it's name for many, many professionals, I think.
