The problem seems related to the parent[name] object.
Please, see the new attached picture.
I've extended the SOAPEncoder class and overrided the getValue method. Then I set the Operation.encoder property with mine (FixedSOAPEncoder):
When it's called, parent[name].length() is 1, but the l variable is set to 0!!
And finally a workaround (for my particular case: problems invoking some SharePoint web services):
Use name.localName instead of name when name is QName.
I debugged the call to the BlazeDS server (useProxy=true) and the expected SOAP message is sent this time:
DEBUG 2012-04-17 15:43:19,688 : >> "<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:s="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <SOAP-ENV:Header>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:versions xmlns:tns="http://schemas.microsoft.com/sharepoint/dsp">[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:version>1.0</tns:version>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </tns:versions>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:request document="content" method="query" xmlns:tns="http://schemas.microsoft.com/sharepoint/dsp"/>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </SOAP-ENV:Header>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <SOAP-ENV:Body>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:queryRequest xmlns:tns="http://schemas.microsoft.com/sharepoint/dsp">[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:dsQuery resultContent="both" columnMapping="element">[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:Query RowLimit="-1">[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:Fields>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:AllFields IncludeHiddenFields="false"/>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </tns:Fields>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <tns:Where>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <Where>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <Eq>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <FieldRef Name="ID"/>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " <Value Type="counter">1</Value>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </Eq>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </Where>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </tns:Where>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </tns:Query>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </tns:dsQuery>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </tns:queryRequest>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> " </SOAP-ENV:Body>[\n]"
DEBUG 2012-04-17 15:43:19,688 : >> "</SOAP-ENV:Envelope>"
Ooopppss! There are still more issues....
All the Previous posts were related to an awesome bug: the runtime and the debugger differ about some values. Following is a more typical development bug.
The problem: previous workaround worked for elements, but not for attributes because the method:
mx.rpc.xml.XMLEncoder.encodeAttribute(definition:XML, parent:XML, name:QName, value:*=null, restriction:XML=null):void
also calls the same XMLEncoder.getValue(parent:*, name:*):* method. Thus, when parent is XML or XML list following code is used:
var value:*;
if (parent is XML || parent is XMLList)
var node:XMLList = parent[name];
if (node.length() > 0)
value = node;
and no attributes are found: he resulting SOAP message ignores custom attributes and default attributes values are always added.
In this case, parent.attribute(name.localName) should be used.
I did that change (by duplicating the getValue method) and, this time, the resulting SOAP message was the the expected, including the custom attributes.
Pablo.
