As is usually the case with men and IT people, after deploying and upgrading Acrobat and Acrobat Pro, I have just now sat down to read the directions!
I have a few questions regarding Best Practices and potential issues with the deployment and upgrade of 10.x products through GPO. I will be referencing the Enterprise Administration Guide (3/2/12).
A simple description of the environment is as follows:
Windows XP and Windows 7 machines, 32 and 64 bit running on a 2003 mode AD.
Not all client PCs are online at any given time, so it is possible that they will refresh their group policies at different times.
We wish to keep all installations up to date (at least as of the time of a machines latest GP refresh with reboot).
Question 1 - Retention of AIPs:
When creating new patched AIPs of Acrobat, the instructions are to put each new patched version in it's own directory
(p70 6.2 AIP Creation, step 4 - Creating the Distribution Point; p89 9.2 10.x GPO deployments, step 6. Add a new package to
the original GPO without moving existing packages).
As the AIP for Acrobat Pro 10 is nearly 1GB, this means that every patch to Acrobat Pro will result in a new 1GB AIP.
If someone were to have done this for each patch to date, that would be 8 AIPs already.
What is actually necessary to retain? Previously, with version 9, I would only keep the most CURRENT patched
version AIP, which worked swimmingly, but this is not what is detailed in the Enterprise Admin Guide.
This relates to the next question as well, as at some point it MAY seem logical to purge interrim versions.
Question 2 - Keeping everyone up to date
I think I finally understand how to add the individual updated AIPs to the GPO, please correct me if I am wrong:
10.0.1 should be set to 'Upgrade over the existing 10.0'
10.0.2 should be set to 'Upgrade over the existing 10.0'
10.0.3 should be set to 'Upgrade over the existing 10.0'
10.1 should be set to 'Upgrade over the existing 10.0'
10.1.1 should be set to 'Upgrade over the existing 10.0'
10.1.2 should be set to 'Upgrade over the existing 10.0'
10.1.3 should be set to 'Upgrade over the existing 10.0'
When I add a new version AIP to the existing GPO, it already is populated with all prior versions. Should these
be removed in order to adhere to the above? I just tested installing 10.1.2 in a GPO that was set to upgrade 10.1.1
with the defaults (I'm not sure what the default is, Upgrade or Uninstall Previous Version?) It appeared to work,
even though the documentation seems to say it should NOT work. My confusion is further compounded by the following:
Section 6.4 -
Tip: Quarterlies are cumulative to the base release, and patches are cumulative to the last
quarterly. For example, you cannot install 10.1.1 over 10.1. Use msiexec.exe /x
<product GUID> <switches> to uninstall versions which impair your ability to adhere
to the installation
This would appear to make sense if I were installing the patch directly to a machine, BUT
this is in the 'Creation of an AIP' section, thus my confusion. Also, if it is referring to installing
a 10.1.1 to a machine with 10.1. But there are multiple places where the instructions state:
'MSI’s uninstall the product, so save your MST to reuse your customizations for future installs.'
So, does it uninstall the product before installing the new one, or does it only do that if you
specify it should (such as the GPO option 'Upgrade over existing' vs. 'Uninstall the existing
package, then install the upgrade package').
Ben
-Many folks report successful AIP creation using unsupported configuration--but then the install fails later on.-
The creation of the AIP itself was a supported configuration. It was the actual upgarde at the client end where 10.1.1 was already installed
and then upgraded to 10.1.2 from the new AIP that was what I believed was 'unsupported'. See below for more on this.
-There are no new MSIs for Acrobat, so the part about "MSI's uninstall. . . " does not apply.-
The installation is still an MSI installation, it is just an uncompressed and patched install point. I assume what you mean by this is
that the MSI itself is the same as previous versions, and therefore is handled differently than a new MSI would be?
Can you comment as to how my question 2 above relates to section 9.2 (pages 89-92) of the EAG?
The instructions there seem like they would only work when deploying an update that would be allowed in the case of directly applying
an MSP to the client (i.e. 10.0.2 installing to a machine with 10.0, but NOT when deploying to a machine with 10.0.1).
If this is the case, should unsupported upgrade packages be set to 'Uninstall the existing package, then install the upgrade package'
(i.e. 10.0.2 is set to upgrade 10.0, but to remove 10.0.1 and then install fresh)?
(To answer one of my own earlier questions - the default set by the GPO when adding the new package is 'Upgrade')
