Trouble finding a 64bit codec to work with 64bit Premiere Elements 10
Apr 17, 2012 12:36 PM
I cannot get 64bit Adobe Premiere Elements 10 to correctly import videos from my Creative Vado HD camera.  On the Adobe "supported-devices-premiere-elements.html" it clearly lists the Creative Vado HD flip camera as tested & supported.
Creative only supplies 32bit codecs for the camera.  It works COMPLETELY with 32bit Adobe Premiere Elements 10 (when installed on my prior computer which only had a 32bit Windows Vista).
My current workstation runs 64bit Windows 7, and the 32bit Adobe Premiere Elements 10 installer on Disk1 will not permit installation (attempt ends in an error message instructing that the 64it Adobe Premiere Elements 10 must be installed from Disk2).  I've tried K-Lite 64bit codec pack with the successfully installed 64bit Premiere Elements 10, and I now get video, but audio barely registers from video clips recorded from the camera.
I'm open to any means to get 64bit Premiere Elements 10 working with some 64bit codec.  I'm hoping the properties listed by Premiere Elements may provide some insight (I've listed them below).
I'm also open to any means to get the 32bit Premiere Elements 10 installed on 64bit Windows 7 (64bit Windows 7 is fully capable of running either 32bit and 64bit apps).  Adobe tech support first suggested I simply install the 32bit version from Disk1, and has not respond further when informed that the 32bit installer won't run on 64bit Windows 7.  It's been a month now and Adobe is offering me little to no help after 9 requests to support.
properties from Creative Vado HD video clip from 32bit Adobe Premiere Elements 10
File Path: C:\Users\x\Desktop\VID00101.AVI
Type: AVI Movie
File Size: 20.7 MB
Image Size: 1280 x 720
Frame Rate: 30.00
Source Audio Format: 44100 Hz - 16 bit - Mono
Project Audio Format: 44100 Hz - 32 bit floating point - Mono
Total Duration: 00:00:20:11
Average Data Rate: 1.0 MB / sec
Pixel Aspect Ratio: 1.0
properties from Creative Vado HD video clip from 64bit Adobe Premiere Elements 10
Type: AVI Movie
File Size: 20.7 MB
Frame Rate: 30.00
Source Audio Format: 44100 Hz - compressed - Mono
AVI File Details:
Contains 1 video track(s) and 1 audio track(s)
Interleave: 1 : 1.39
Video track 1:
Size is 20.19Mbytes (average frame = 34.56Kbytes)
There are 62 keyframes, 549 delta frames.
Frame rate is 30.000 fps
Frame size is 1280 x 720
Depth is 24 bits.
Compressor: 'H264', ffdshow Video Codec
Audio track 1:
Size is 441.00Kbytes
Rate is 44100 samples/sec
Sample size is 16 bits
Compatible compressor: MS-ADPCM
Compression ratio is 3.98 : 1
properties from Creative Vado HD video clip from 64bit Media Player Classic (much more complete properties listing)
General
Complete name                  : C:\Users\x\Videos\Vado\VID00101.AVI
Format                         : AVI
Format/Info                    : Audio Video Interleave
File size                      : 20.7 MiB
Duration                       : 20s 367ms
Overall bit rate               : 8 505 Kbps
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : Main@L4.0
Format settings, CABAC         : Yes
Format settings, ReFrames      : 1 frame
Format settings, GOP           : M=1, N=5
Codec ID                       : H264
Bit rate                       : 8 318 Kbps
Width                          : 1 280 pixels
Height                         : 720 pixels
Display aspect ratio           : 16:9
Frame rate                     : 30.000 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.301
Stream size                    : 20.2 MiB (98%)
Audio
Format                         : ADPCM
Codec ID                       : 2
Duration                       : 20s 361ms
Bit rate mode                  : Constant
Bit rate                       : 176.4 Kbps
Channel(s)                     : 1 channel
Sampling rate                  : 44.1 KHz
Bit depth                      : 4 bits
Stream size                    : 441 KiB (2%)
Interleave, duration           : 46 ms (1.39 video frame)
    Apr 17, 2012 12:43 PM   in reply to richc314159
    Rich, weren't we already deep into this in this other thread?
    http://forums.adobe.com/message/4329012#4329012
    Why are you starting a new thread when we are already well into a discussion in the other? It's very confusing.
    Apr 17, 2012 6:33 PM   in reply to richc314159
    >K-Lite
    Oops! There have been some reports of that codec pack causing problems that were only solved by formatting the hard drive and installing everything fresh
    If you have Win7 64bit PRO or higher, try Microsoft's Virtual XP... this may work to let you install PrEL 10 32bit in a virtual space
    This is only ONE example of using Virtual XP http://forums.adobe.com/thread/702693
    -And a Tutorial http://windowssecrets.com/newsletter/using-windows-7s-xp-mode-step-by- step/
