I want to use picuters in Premiere Pro and want to change the pixels from 1.0 to .9. I know how to do this in Premiere using interpret footage. But I wanted to do it in photoshop - I thought that would be the place to do it? I know to go under view and pick PAR and then pick what I want. I then try to save as and use it but it reverts back to the 1.0 pixel, as though I never made a change to the photo. I have 300 photos so any way to do this with one command for all would also be helpful.
Thank you for your time.
Pixel aspect ratio is merely a case of tagging. If you save to a format that doesn't support non-square PAR, it is meaningless. I'm not sure what you are trying to achieve, anyway. Just like re-interpreting the files in Premiere, changing the PAR flag in a file does not change any of its pixel data. It has neitehr any advantage nor disadvantage.
Mylenium
In premeire when I make the movie it is set for the pixels to be at.9 meaning the pixels are rectangles not 1.0 which are square pixels. So if the picture par does not match the settings for the movie (as they do not) then the picture will have a skewed look, I beleive the picture will look at bit streched to fit. I don't understand by what you mean of par being a case of tagging.
I hope this makes things a little more clear.
Na, you are misunderstanding how video apps deal with pixel aspect ratios and what it means in this context. Chaninging the PAR in PS won't do anything. You need to setup your timelines correctly and work with equivalent pixel sizes. If you e.g. work with HDV 1044x1080 with 0.9 PAR, any full HD 1920x1080 square pixel image will properly match. That's all there is to it.
Mylenium
