Display Slide X of Y in Playbar ?
Apr 18, 2012 1:15 AM
Captivate v5.5
I use the Superslim Playbar bar without the progress bar as users can drag the indicator button to the end and "skip" all slides.
However I would like to display in the Playbar slide X of Y so the user is aware of which slide they are working on.
I know there is a slide counter widget but I need the information displayed in the playbar not on the slides themselves.
Any ideas how this can be done ?
Noel
    Apr 18, 2012 1:31 AM   in reply to Noel Griffiths
    You'll need a Flash programmer there, Noel to change the playbar.
    I suppose you only want that solution, not a caption on the master slide with that information that is updated on each slide?
    Lilybiri
    Apr 18, 2012 1:45 AM   in reply to Noel Griffiths
    I'm always here ...perhaps didn't answer your questions
    Even for captured slides you can use a master slide that has just that information in a text caption, at least if you can put it where it will not be bothering the user too much (top or bottom somewhere). I will not use the widget myself, just insert this:
    $$cpInfoCurrentSlide$$/$$rdinfoSlideCount
    Lilybiri
    Apr 18, 2012 8:00 AM   in reply to Noel Griffiths
    as an alternative, I think I remember there is a way to show the progress bar/slider component, but disable the ability to drag the slide/playhead.
    I didn't find the answer with a quick search, but I know i've read it here, maybe even from lilybiri
    Apr 18, 2012 7:51 PM   in reply to AndyKingInOC
    Disabling the scrubbing action on the playbars required editiing of the ActionScript code in the playbar to disable the mouse events on that particular component.
    Apr 19, 2012 12:11 AM   in reply to Noel Griffiths
    Perhaps Andy was referring to the Playbar Lock widget by Yves Riel?
    Lilybiri
